Re: crude foils
Sounds like a good way to go. Particularly if making more than one
board. The method I mentioned doesn't require tooling or a router, can
be used on tapered or even curved foils (though I'm not sure that's
worth it), and if done carefully will get within a few thousandths of
the correct shape. You could even use it to make a jig. If I make a
fancy foil shape, I might be tempted to use wire cut foam though, since
once you are set up for it it's fairly easy to do.
>David Davis wrote:
>--- Inbolger@yahoogroups.com, Lincoln Ross <lincolnr@r...> wrote:
> snip
>>> instructions for sanding accurate foils in Mark Drela's stuff (maybe
>>> Apogee or Allegro plans) at www.charlesriverrc.org.
>The foil shape is easy to get in rudders, centerboard, and leeboards
>with a router. A simple jig that lays over the side of the work and
>is raised near the center of the work can be made from scrap. The
>jig can be made adjustable, or two different jigs may be used for
>the leading and trailing edges. I just made and used one on a 24 X
>78 inch leeboard and finished cutting all 4 edges in one day. I
>just used a jig with a flat incline and curved the surfaces of the
>leeboard with a belt sander, but I see no reason the jig couldn't be
>built with a curved surface if one wanted to take the time.
>David
> There's no need for crude foils on low tech boats. With a thickwooden
> blank and a plane, it ought to be possible to rough out a goodfoil
> shape in less than a day. At least I've done it with balsa woodfor a
> model airplane wing, and working larger ought to make it easier.See
> instructions for sanding accurate foils in Mark Drela's stuff(maybe
> Apogee or Allegro plans) at www.charlesriverrc.org.The foil shape is easy to get in rudders, centerboard, and leeboards
There's no need for crude foils on low tech boats. With a thick wooden
blank and a plane, it ought to be possible to rough out a good foil
shape in less than a day. At least I've done it with balsa wood for a
model airplane wing, and working larger ought to make it easier. See
