Re: [bolger] Bow fillets [was 23' Diesel Cruiser.]
Actually they don't slap as much as you might think. The bow rises just
enough to clear the waterline but no higher. This stops a lot of the wave
from entering under the hull. Bolger comments that putting a cutwater on
the Wyoming would just make for miserable sleeping.
Sent: Monday, March 01, 2004 6:10 AM
Subject: Re: [bolger] Bow fillets [was 23' Diesel Cruiser.]
> So then on a flat bottom like the original sneakeasy it will slap with no
mercy? Could one just raise the chines up on the stem a little to present a
vee while anchred?
> Don
> sctree <sctree@...> wrote:
> The box cutwater itself (at least as on Microtrawler) doesn't cause any
> slap, it's the sponsons, the upper hull of a Bolger power step sharpie
> that catch the ripples and thump... Sneakeasy box cutwater version
> would be the same. It was AS-29 owners that first wanted a bow
> modification to stop slapping at anchor, enter the fillet pieces.
> Somewhere I saw Bolger drawings, and maybe photos. Then there was a
> Micro with fillets added, Oink if I recall correctly. Not sure if that
> was owner or Bolger designed... W.D. Jochems takes a different bow
> treatment, a cutwater that runs down the stem and under the hull a ways
> to split the water and reduce, but not eliminate the slap. Topaz has
> fillets, but I believe designed in from the beginning... Then there is
> Windermere. If my reading of Windermere is right her fillets will
> totally eliminate slap, plus as Peter has so elegantly stated the rivers
> and oceans will flow so smoothly under her bottom.
> Corrections to the above welcome...
> Rick
> Peter Lenihan wrote:
> > --- Inbolger@yahoogroups.com, Don Tyson wrote:
> > > So Peter, the piece your calling the fillet is the piece missing on
> > a slapping box-cutwater version of the sneakeasy?
> > > Don
> > It would appear so,Don........that is, unless Bolger really had
> > another brainwave up his sleave :-)
> > Peter Lenihan
(978) 282-1349
(978) 282-1349
Have the fat guy sit on one side. Seriously, if you look at the PCB layout
on many of the sharpies, they always seem a bit asymmetric to me, until it
hit me: PCB is heeling the at-rest hull! Well, that COULD be the
reason.....
David Romasco
_____
Sent: Monday, March 01, 2004 8:11 AM
vee while anchred?
Don
that
So then on a flat bottom like the original sneakeasy it will slap with no mercy? Could one just raise the chines up on the stem a little to present a vee while anchred?
Don
Rick
> > Don
> Peter Lenihan
Rick
> > Don
> Peter Lenihan
Well certainly Sneakeasy does not have this fillet. I am going through all the mental contortions of trying to decide how to make Tennessee work for me. I would like to flatten the run (Seth) and add the box cutwater and cockpit roof. By the time I figure it all out it will probly resemble the original since Bolger knew why he did what he did and I'm just guessing.
Don
> Don
So Peter, the piece your calling the fillet is the piece missing on a slapping box-cutwater version of the sneakeasy?
Don
> Peter and others,
> When I read about the sharpie designs slapping at anchor in BWAOM
Bolger says that its even worse with the step hull upgrade and that
he had an idea on how to fix it. Anyone chance a guess on how?
> I went to the NJ boat show today and was surprised how few factory
boats are comfy.
> Don
Don,
I'm not sure this is what Bolger had in mind at the time but if
you go here:
http://groups.yahoo.com/group/Bolger3/files/
and then to the file named WINDERMERE and rifle around abit, you'll
see his idea,in living colour, for a fillet piece which should make"
slapping" a task best practiced in the master stateroom of his newer
sharpie hulls :-)
Peter Lenihan,Windermere builder and old school slapper :-)
> Peter and others,
boats are comfy.
> Don
Don,
you go here:
sharpie hulls :-)
I imagine the bow modifications you mention would be the filletted
bow, which you can see in Peter's file.
Don't forget that the flat backside of a sharpie will also slap at anchor.
I have not read this thread, but the 23ft cruiser looks a very able boat.
DonB
> Peter and others,
Bolger says that its even worse with the step hull upgrade and that he
boats are comfy.
> Don
> Peter Lenihan <lestat@b...> wrote:
> --- Inbolger@yahoogroups.com, "Frank Bales" wrote:
> > Any photos anywhere of this boat? I've never heard of this
> design. --Frank
> Frank,
> If you haven't already,then you just gotta get yourself a copy
> of Boats With An Open Mind.This is where you'll find Bolgers write
> up on her along with reduced plans.
> Sincerely,
> Peter Lenihan
Fax: (978) 282-1349
Peter and others,
When I read about the sharpie designs slapping at anchor in BWAOM Bolger says that its even worse with the step hull upgrade and that he had an idea on how to fix it. Anyone chance a guess on how?
I went to the NJ boat show today and was surprised how few factory boats are comfy.
Don
design. --Frank
Frank,
design. --Frank
Frank,
Any photos anywhere of this boat? I've never heard of this design. --Frank
--- Inbolger@yahoogroups.com, "Langmuir" <llangmuir@v...> wrote:
> Greetings all,
> I am considering building a version of Bolgers 23' Diesel Cruiser,
design no.574.
> If you have experience building or running this vessel I would be
grateful for your comments.
> Please contact me via the list or directly on llangmuir@v...
> Regards, Gavin Langmuir.
Gavin,
As far as I can tell from the book,there may only be one which
has been built and that by Warren who commissioned the design.
She is a handsome cruiser,with 6'5" headroom where it is most
useful(galley,helm),plywood construction throughout,economical diesel
power and the possiblity to tow the boat.
Bolger does state that being able to fully loft the boat first
is needed with this design,especially forward for the bilge panels.If
this is not something you are comfortable with,perhaps you could find
someone close by who does know how to loft.
Don't let the possiblity of being the second builder of this
robust cruiser deter you from actually building one:-)
Gavin,
I'm thinking of building tennessee or Idaho or minnesota but also like diesel cruiser, that is if it is the one I'm thinking of in BWaOM.
I was hoping that some of the regulars of this site might tell me how they would add standing headroom to one or another of these designs but they instead tried to talk me into more practical designs like topaz and champlain and windmere. Be careful with the advice you get here. You might end up builing a canoe or something.
Langmuir <llangmuir@...> wrote:
Greetings all,
I am considering building a version of Bolgers 23' Diesel Cruiser, design no.574.
If you have experience building or running this vessel I would be grateful for your comments.
Please contact me via the list or directly onllangmuir@...
Greetings all,
