Re: scaling up a boat?......attn: lincoln ross
See below:
surfing will find the contact info), which I believe sells back issues.
I bet if you snail mail MAIB they can tell you which issue. Or there may
be indexes on line someplace.
designed for that size would be better.
it's a pram. Maybe too many chines. I think about 12 feet long, as I
recall. And I think Bolger has some other boats of that sort which might
be worth looking into. Isn't there something called the Supermouse?
(also a pram). One of the boats at bateau.com is a big pram, and not
ugly, IMHO. It's not just you, a lot of Michalak boats are funny looking.
>Jason Stancil wrote:Probably MAIB (Messing Around in Boats, and I'm sure a bit of web
>snip
>You're on to me i'm thinking about making a nymph micro cruiser. Can
>you remember where you saw that bolger article or how i can get my
>hands on it?
>More importantly do you remember why bolger rejectedI don't remember exactly. I seem to recall it might be ok but a boat
>the idea?
>I know i could just build a micro or old shoe, but i likeJapanese Beach Cruiser is in Boats with an Open Mind. Quite pretty, and
>screwing around withthings a working with minimal amount of
>directions....assuming i don't compromise safety or totally screw up
>why the design originally worked in the first place.
> snip
>I like dory and pram hulls.....i've built a michalak boat and they
>are well done but....for the most part i find them UGLY, but that's
>me. What is the Japanese Beach Cruiser?
> snip
>________________________________________________
Fundamentally, the way you determine the
shape of flat plywood, which will
curve correctly to fit the boat is to
break down the surface shape into
triangles. I think that Sam Rabl first
described this. See also:
Jim Mickalak's article at =>
http://marina.fortunecity.com/breakwater/274/2000/0101/
If you dust off your memory of high school
trigonometry, you can also do it relatively
quickly using a spreadsheet.
In essence, you know the shape of each quadrahedron
with four corners being:
station 1 chine,
station 1 sheerline,
station 2 chine,
station 2 shearline.
Connect corners diagonally to break it into triangles.
Repeat....
These triangles can then be 'unfolded' into a flat
shape.
station 1 chine,
station 2 chine,
Repeat....
shape.
Right. Not lofted but _expanded_ . Bolger doesn't need a computer for it, either. You can
use the method described in Chappelle's 'Boat Building' or get Greg Carlson's free Chine
Hull Designer program.
http://www.carlsondesign.com/hulls.zip
Another option, unless you are really interested in design work, is to send $65 to Karl
Stambaugh for a thoroughly worked out version.
cha62759@...wrote:
> My reading of the discussion is that you do not "loft" side panels. I
> understand the spiling process but was hoping perhaps that the
> accumulated knowledge of this board could tell me how to draw and cut
> out one panel from information gained through lofting. I assume that
> Mr Bolger uses the computer to arrive at his panel extensions.
> The Chappelle camp skiff is a hard chine sharpy stink boat. Think
> "Redwing" which is derived from Mr Chappelle's design.
> The next question is, what computer program? Is there a relatively
> simple program which can take the lofted information and produce the
> panel extension?
> My last experience with this sort of problem led me to nailing a 4'x
> 24" panel to the building molds and cutting to fit. This was a
> decidedly dicey proposition single handed.
> Bob Chamberland
For that sort of boat, Greg Carlson's "Chine Hull Designer" works very well.
It's free and it generates the panel's expanded shapes.
http://www.carlsondesign.com/#Fun_Shareware
It took me some thrashing around to figure out that there are no
user-friendly error messages and that when the help files say six chines
maximum, it means six chines maximum. (I was plotting out the lapstrakes
for Chebacco and that wants seven "chines." I'm happy enough with the
results I got by putting the hull in twice, once with a very broad sheer
strake and once with a very broad garboard strake.)
I decided that it wouldn't run on Win2K, but that was before I realized the
six strake limit, so maybe it will. It works well on Win98SE which my other
two computers use.
It yields files which are ASCII text and can be input to other graphic
programs or printed out and drawn by hand on the plywood. It allows you to
specify the size of your plywood panels and shove the strakes around for
efficient nesting. It also prints out pictures of the pieces.
derbyrm at starband.net
http://derbyrm.mystarband.net
two computers use.
> panel extension?
Hi Peter,
This process doesn't result in the "expanded" panels" but rather in
the "elevation" of the hull. It does not represent the curvature of
the hull fore and aft.
Bob Chamberland
Bob Chamberland
--- Inbolger@yahoogroups.com, "Peter Lenihan" <lestat@b...> wrote:
> Hi Bob,
> I was refering only to the "expanded" panels that Bolger
> usually shows for his plywood hulls.
> I'm not familiar with "Camp Skiff" but if it is a Chappelle
> work,does he call for the sides to be out of plywood or just planks?
> The full lofting of side "panels" would involve,if I recall,laying
> out on the loft floor all the stations and base line.Then using the
> information provided in the table of off-sets,for each
> frame/station/mold,you plot out the height of the chine and shear for
> each.Once all your points are down,lay a fairing batten down and
> strike a fair line.The resulting shape should be your"expanded" panel
> shape.
> Of course,if you have already lofted out the half breadths,then
> you do not need to go back to the table of off-sets.Instead just pick
> out the respective heights,for chine and shear,and transfer these to
> their respective station lines layed out previously.
> This will only work for flat,straight-sided,hulls.
panel extension?
Bob Chamberland
panel extension?
Bob Chamberland
> CanIt was in MAIB. As I remember, he felt the design got too fussy, and
> hands on it? More importantly do you remember why bolger rejected
> the idea?
the cuddy was not big enough for the intended use.
> I've seen an article somewhere by Bolger where he considers (andYou're on to me i'm thinking about making a nymph micro cruiser. Can
> rejects) a little cruiser based on a scale up of the Nymph.
the idea? I know i could just build a micro or old shoe, but i like
> Structural calculations probably not simple, tho I suppose youcould guesstimate. Panel expansions won't fit on plywood either, so
you'll probably use a lot more wood and maybe have more scarphs to
do.
I'm in no hurry I just enjoy straining my brain on this kind of
stuff.....notice i'm not attempting anything "large"
Are you sure you don't like the larger plans that are already
available? Windsprint, Featherwind (is that the name?), and the
Japanese Beach cruiser come to mind, though I'm sure there are
others.
> course, you'd probably be the only one around with an oversizedNymph.
Exactly!...just hope it'll float :)
Thanks for any info on that article,
Jason Stancil
Keep in mind that the displacement would go up more than 100%! (Cube of
1.3 is about 2.2)
Structural calculations probably not simple, tho I suppose you could
guesstimate. Panel expansions won't fit on plywood either, so you'll
probably use a lot more wood and maybe have more scarphs to do. Are you
sure you don't like the larger plans that are already available?
Windsprint, Featherwind (is that the name?) , and the Japanese Beach
cruiser come to mind, though I'm sure there are others. Bateau.com and
Michalak have some pramlike boats in a larger size range, too. But of
course, you'd probably be the only one around with an oversized Nymph.
1.3 is about 2.2)
>Trying to get a grasp of how to exactly scale up a boat from
>existing plans.
>Say for a 30% enlargement would i just multiply everything by 1.3
>including the 12 inches between station lines?
>Been thinking of scaling up a nymph or a elegant punt if i don't
>build an oldshoe. I know i would need to beef up the framing a bit
>but that seems easy enough.
>Bought a really neat little contractor's calculator that does math
>in feet, inches, quarters, eights, sixteenths and
>thirtyseconds....it just got me thinking.
>Thanks, Jason Stancil
end,fat and low in the middle,and slightly narrower and higher at the
other end) you will indeed get different widths needed for each
plank.These widths need to be transfered onto your planking
stock,faired up with a batten,and trimmed to those lines.The look of
the plank before offering it up will appear somewhat skinny toward
the stern,swelling in the middle and slightly tappering toward the
stem.
Depending on how much shear is in the hull,alot of adjustment must be
done with the garboard plank to ensure you get the planks off on the
right foot.
You do not have to transfer your chain girth measurements to each and
every plank since,one you have established the number of planks you
will need(sometimes best determined once you know what size planks
are available) and establish the correct shape of your garboard
plank, it is just a simple matter of spiling the rest of your planks
up to the shear.
Some hull shapes,however,will require the use of stealer planks if
they have alot of shape to them(the hull,that is) since your plank
ends will begin to be tapered so much that they are too narrow to
drive a fastening into. Similarly,if you run your planking paralle to
the water line,you'll have to "cheat" a bit toward the ends with long
slivers of planking stock,just to meet the shear(or else have a very
wide shear strake and be prepared to waste a lot of wood).
you yet another means of cross checking the fairness of your
previously laid down lines......very useful right in the turn of the
bilge!
If only I could remember correctly everything I was taught during a
course in lofting so many moons ago:-)
> Peter, is it as simple as 'divide by theBruce,with a fairly typical hull shape(narrow and pointy at one
> number of planks'? Because that calculation
> only gives you the width of each plank at
> each station. [Not the distance of each edge
> of the plank from the center line of the plank
> at each station.]
stem.
right foot.
up to the shear.
> Lofting the stations, halfbreaths and waterlinesDiagonals are beautiful for really tweeking ones lofting as they give
> makes sense to me, but lofting the diagonals
> does not!
bilge!
Bruce,
I, too, languished in ignorance for many years until I was shown the light
("Eureka!") By Richard Cullison, who was teaching a lofting class at the
Chesapeake Bay Maritime Museum (all three have my enthusiastic
recommendations, BTW).
The diagonals are arrived at by starting with the half-breadth lines and
taking the intersections of the diagonal line with each of the frames and
carrying that point over to the profile drawing, where the points are marked
on the frame stations. Spring a batten through those points and trace in
the line. Hey presto, and you've just drawn a diagonal! This line actually
helps define the three-dimensional nature of the lofting process, and you
can add as many as you like to further smooth the frames into line. The
process, once you get your arms around the function, is the magic that makes
lofting work.
Larry Pardey talks about adding waterlines and diagonals in his book about
traditional building methods (he goes a little overboard, but to be honest,
I get a severe case of inferiority neurosis every time I read one of his
books...).
David Romasco
_____
Sent: Thursday, March 04, 2004 10:43 AM
Subject: Re: [bolger] Re: "Lofting" side panels
--- Peter Lenihan wrote:
confounded me, trying to figure out how
to loft a lapstrake or planked boat.
at each station.]
In other words, it doesn't give you the
lengthwise curve of the plank, IE, is it
curved like a banana, and just how much?
Spiling, from one plank to the next,
I guess, gives that information.
That is unless, and this is where I get
confused, it appears that the lengthwise
curve of the plank could be 'read' through
the lofting of the 'diagonals' in the lofting
diagram. But I never figured that out.
does not!
(978) 282-1349
_____
lofting work.
books...).
David Romasco
_____
> If the hull is round,This 'chain girth' question has always
> then you have to figure out the"chain
> girth" at each station, divide this figure
> by the number of planks you intend on
> using to get the correct shape of each plank
> so that the finished boat does not have all its
> planks"frowning",ie;with> the seams curving
> downward,opposite to the sweep of the
> shearline.......
at each station.]
does not!
(978) 282-1349
_____
My guess is that most boatbuilders will abandon the loftwork as soon
as the frames have been fabricated and set up. At that point, it's no
longer a matter of what the designer had in mind, and more a matter
of what size and shape the frames actually are. In other words, the
shape would be taken from the frames, not from the planking. You
might try to get your hands on the WoodenBoat article on the building
of the Whittholz-designed Downeaster v-bottom powerboat. It shows how
to build a non-instant plywood boat about as well as anything.
I would set up the frames, rightside up, or upside down, as prefered.
To get the shape for the planking, I would take the shape from the
frames by making up a plank about 4" wide that is stiff enough and
pliable enough to make a fair curve. (e.g. 3/8" ply) It should be
long enough to go from stem to stern. Mount it temporarily along the
mid-point of the side plank. Then, at each frame, draw a line across
the 4" piece showing the angle at which the frame crosses it, and
measure the length from some mark to where the edge of the plank
needs to fall, both above and below.
Then to mark the planking, lay the marked piece on the stock. Extend
the lines marking where the frames will cross, and measure to where
the edge needs to fall. You can then draw a fair line along the
edge. ("Voila!," Peter might say.) I would leave an allowance for
find adjustment later.
This is basically the way a plank would be spiled for lap or carvel
construction. Perhaps you need a book? Chapelle's Boatbuilding or
Sewards' Boatbuilding Manual.
Rather than try to explain it, let me suggest you get a copy of Ian
Oughtred's excellent book on lap ply construction.
> > shearline.......
> at each station.]
> does not!
(978) 282-1349
at each station.]
does not!
> shearline.......
at each station.]
does not!
shape.
This will only work for flat,straight-sided,hulls.If the hull
is round,then you have to figure out the"chain girth" at each
station,divide this figure by the number of planks you intend on
using to get the correct shape of each plank so that the finished
boat does not have all its planks"frowning",ie;with the seams curving
downward,opposite to the sweep of the shearline.......
At any rate,I hope I have it right and haven't forgotten some
critical bit of information.Hopefully,someone who knows better will
jump in and correct my mistakes :-)
> I am building Howard Chappelle's 18' "Camp Skiff". I have lofted theHi Bob,
> major lines and have the molds done and I am now struggling with the
> transom. How does one loft the side panels? or does your note only
> apply to previously expanded panels a la Bolger instant boats?
> Bob Chamberland
shape.
Bob Chamberland
Bob Chamberland
> This would,of course, require some extra waste in plywood and your
> willingness to"loft" the expanded side panels out to a length needed
> for a 10 foot version.Everything else,like the transom and frames
> would remain pretty much as is.
> Peter Lenihan
>I've read about how the volume increases significantly with a slightUp to 20% is typically OK, just move the stations further apart. Scows are
>increase in scale, but that's the point the current boat as drawn is
>too small. I'm talking about scaling up an 8' boat to 10'......no
>elephant here.
>Thanks for the input,
>Jason Stancil
a different case as are sharpies and you can "scale up" more. A scow is a
scow is a scow.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
--- Inbolger@yahoogroups.com, "smithriverranger" <jasonstancil@h...>
Maybe,just maybe,since you are refering to a very basic shape and
only wish to add two feet to her length,then you might be able to do
just that without touching any of the other dimensions.
Try it out,to the same scale as on the plans, with a model made
out of some heavy construction paper(cardboard) and see if you like
the looks ....adjust to taste :-)
> I've read about how the volume increases significantly with aslight
> increase in scale, but that's the point the current boat as drawnis
> too small. I'm talking about scaling up an 8' boat to 10'......noJason,
> elephant here.
> Jason Stancil
elephant here.
Jason Stancil
elephant here.
Jason Stancil
> Yes, and no.
> Note that adding 30% to the linear dimensions doubles the volume.
Surface
> area is 70% greater. Stiffness is some high power of the thickness
(figure
> the beam's moment of inertia, but that was 50 years ago), so
scantlings are
> Drop a kitten six feet and he grins, drop an elephant the same
difference
> and you have a mess to clean up.
> Roger
> From: "smithriverranger" <jasonstancil@h...>
> Sent: Wednesday, March 03, 2004 5:27 PM
> Subject: [bolger] scaling up a boat?
> > existing plans.
bit
math
--- Inbolger@yahoogroups.com, Don Tyson <tysond99@y...> wrote:
> so avoid building an elephant?yup........especially white ones........:-)
> Yes, and no.doubles the volume. Surface
> area is 70% greater. Stiffness is some high power ofthe thickness (figure
> the beam's moment of inertia, but that was 50 yearsago), so scantlings are
> ????elephant the same difference
> and you have a mess to clean up.boat from
> Roger
> From: "smithriverranger" <jasonstancil@...>
> > existing plans.everything by 1.3
> > including the 12 inches between station lines?punt if i don't
> > build an oldshoe. I know i would need to beef upthe framing a bit
> > but that seems easy enough.calculator that does math
> > in feet, inches, quarters, eights, sixteenths andflogging dead horses
> - stay on topic, stay on thread, punctuate, no 'Ed,thanks, Fred' posts
> - Pls add your comments at the TOP, SIGN your posts,and snip away
> - Plans: Mr. Philip C. Bolger, P.O. Box 1209,Gloucester, MA, 01930, Fax: (978) 282-1349
> - Unsubscribe:bolger-unsubscribe@yahoogroups.combolger_coffee_lounge-subscribe@yahoogroups.com
> - Open discussion:
Yes, and no.
Note that adding 30% to the linear dimensions doubles the volume. Surface
area is 70% greater. Stiffness is some high power of the thickness (figure
the beam's moment of inertia, but that was 50 years ago), so scantlings are
Drop a kitten six feet and he grins, drop an elephant the same difference
> existing plans.
existing plans.
existing plans.
