Re: Wm Garden Livaboard Scow
--- Inbolger@yahoogroups.com, "boatnut202" <pmmusic@p...> wrote:
Pretty much the entire text,as it appears in Gardens book Yacht
Designs II,is what you see in the files over in Bolger2.
Her specs are as follows:
Length on Deck 24'6"
Load Water Line 20'0"
Breadth 8'0"
Draft of Hull 1'4"
Draft with Board down 2'6"
Displacement 3600lbs
Sail Area 400 sq.ft.
Displacement and trailer weight are pretty much the same thing. As
for getting a set of building plans,you might try either writing
directly to the designer(now retired) or checking out a web site
dedicated to the designs of William Garden.(Do a google search for
this site.)
It is a very neat looking sailing scow! Another one which would be
worth a peek is the sprit sailing barge HARRY,designed by Tad
Roberts.Now if only someone could get Mr.Roberts to show this design
on his web page......WOW!!
> Hello again,Patrick,
> Was browsing the files in Bolger 2 and came across this one...Wm
> Garden livaboard scow..
> Does anyone have any information on this design?...Where one could
> obtain plans?...Displacement? Trailer weight?...
> Thanks in advance...
> Patrick
Breadth 8'0"
Draft of Hull 1'4"
this site.)
This thread should answer most of your questions:
http://groups.yahoo.com/group/bolger/message/29959
Best of luck
Mat
Best of luck
Mat
Hello again,
Patrick
watching the slowly growing piles of fluffy water building up on the
shores of the mighty (mostly stiff)South Saskatchewan River.
Patrick
