Re: saving weight?
Do both! Your boat will be more durable that way, too. Also, in some
boats, such as Nymph, it makes sense to beef up the gunwhales and remove
the bulkheads afterwards. I don't know if it's lighter, but the interior
is more friendly this way. It also might give you something to sit on if
you want to hike out.
>Jason Stancil wrote:
>Is it reasonable to build a boat designed as nail and glue to a
>stitch and glueto save weight? I'd leave the chine logs but thinking
>about doing the bulkheads and seating with filets.
>What do nyou folks think?
>Thanks,
>Jason Stancil
>____________________
I would suggest that the fillet method produces a joint which is stronger
overall.
We aren't pushing the limits like the aircraft people do, but the usual
"nailing sticks" produce a "hard spot" at their edge which causes higher
stresses in the adjoining panel. The ideal is to transfer the load as
smoothly as possibly.
Roger (if you knock the ell out of a fillet, you end up boned and sliced)
overall.
> >Thanks,
> >Jason Stancil
-Get out the hole saw and start perforating all that plywood. But not
the bottom!
Bob Chamberland
-- Inbolger@yahoogroups.com, "smithriverranger" <jasonstancil@h...>
the bottom!
Bob Chamberland
> Thanks,
> Jason Stancil
>Is it reasonable to build a boat designed as nail and glue to aSure. No problem with that.
>Thanks,
>Jason Stancil
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
Jason Stancil
Jason Stancil
