Re: [bolger] Re: seabird beam and length?
--- Roger Derby wrote:
> The discussion was on pouring lead
> in multiple melts
> and having a failure of
> the layers to bond.
I poured in multiple layers,
and I found that if the layer
going on top had sufficient
thermal mass, it melted itself
into the bottom layer. IE,
I poured in three equal
layers, and they adhered to
each other.
I also poured a small 'make-up'
layer of about a pint of lead
and found that it cooled to
quickly to melt in. Still,
no problem, I just nailed it
tight to the casting with a
hammer and nails. I suppose
that epoxy glue could stick
layers together too.
See also Bolger2/Photos/Seabird for some shots of the boat in the
water, and looking very pretty.
Excellent. Thank you very much. How does she sail?
In going thru the pictures (nice site! nice boat!) I was struck by an idea
that had nagged at me in one of the earlier threads.
The discussion was on pouring lead in multiple melts and having a failure of
the layers to bond. Isn't there some flux one could throw in after the
first melt to encourage the two to bond? Rosin, acid, peanut oil?
http://derbyrm.mystarband.net
Subject: [bolger] Re: seabird beam and length?
> Where? Thanks. bob
> Here:http://ca.geocities.com/nohnpages/
Where? Thanks. bob
> Pictures? Where? Thanks. bob
There original is in BWAOM, and the others in back issues of MAIB.
In a message dated 3/13/2004 8:08:58 AM Central Standard Time,
pvanderwaart@...writes:
There are two rigs (dipping lug, gaff sloop) for the standard
version, as well as a Navigator version
> How big is that thing (Seabird '86)?
23' x 7'9" x 2' 6". It was originally conceived as a motorsailor,
hence a shoal, not very aggressive, keel.
version, as well as a Navigator version.
I was just out surfing the web out of boredom and saw some photos of
a bolger seabird, looks like a multichine long micro with the bow of
a storm petrel. How big is that thing?
Jason
