Re: Sneakeasy Stem
As I remember the plywood sides attach to the outside of the stem
and go all the way to the front-almost touching each other at the
front. Then you round off stem and plywood together to the shape you
want. Only the narrow front of the stem is visible when finished.
Charles
> > I just cut out the stem for the sneakeasy that I am building
> I've
> > run into a problem/question? The stem is too narrow to be
notched
> for
> > the sheer and chine logs.
> > Do the logs simply get fastened to the outside faces of the
stem?
> > Tom
> > - no cursing, flaming, trolling, spamming, or flogging dead
horses
> > - stay on topic, stay on thread, punctuate, no 'Ed, thanks,
Fred'
> posts
> > - Pls add your comments at the TOP, SIGN your posts, and snip
away
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> 01930, Fax: (978) 282-1349
> > - Open discussion: bolger_coffee_lounge-
> > Yahoo! Groups Links
Thanks Jeff.
I'll probably do the same...
Tom
--- Inbolger@yahoogroups.com, "Jeff" <boatbuilding@g...> wrote:
> I brought the chine logs together at the stem, trimmed them off
flush for the stem to be mounted. I guess you'd say the stem was
attached in front of the chine logs. Like you, I was not sure so
more or less winged it but it's very solid.
> Jeff
> From: Tom Rund
> To:bolger@yahoogroups.com
> Sent: Monday, March 15, 2004 7:36 AM
> Subject: [bolger] Sneakeasy Stem
> Hi Group,
> I just cut out the stem for the sneakeasy that I am building and
I've
> run into a problem/question? The stem is too narrow to be notched
for
> Do the logs simply get fastened to the outside faces of the stem?
> Tom
posts
I brought the chine logs together at the stem, trimmed them off flush for the stem to be mounted. I guess you'd say the stem was attached in front of the chine logs. Like you, I was not sure so more or less winged it but it's very solid.
Hi Group,
I just cut out the stem for the sneakeasy that I am building and I've
run into a problem/question? The stem is too narrow to be notched for
Tom
Hi Group,
Tom
