Re: Another MDO question
If I was doing it and had a table saw, I'd be tempted to rip some strips
of any old half decent, gluable wood and glue them on the plywood edges.
Then I'd just use latex house paint.
>b_owen_ca wrote:
>This is about MDO, Crezon to be specific - but it's a bit OT.
>One of my Honey-dos is to prep a 4'x4' piece of Crezon for - of all
>things - a highway sign. I figure whatever anyone would do for above
>waterline treatment would work well here. What would you recommend
>for sealing edges, priming, painting? And I need to keep this cost
>effective (cheap) so I'm not using 2 part epoxy paint!
>Bryant
I have been using epoxy on the edges of MDO and it seems to penetrate and
seal the raw edges nicely.
Grant
on 3/28/04 8:38 PM, doug6949 atprototype@...wrote:
> --- Inbolger@yahoogroups.com, "b_owen_ca" <mariner@n...> wrote:
>> Thanks Dave. All good points. I like the bondo idea, never thought
> of
>> it. I'm leaning towards a brand name acrylic latex primer and finish
>> so that seems in line with what you said.
> The bondo should work fine for the edges, as you are not concerned
> about a perfect seal (no metal to rust under the bondo). Thinned epoxy
> would probably work better, and if you have some, only a few ounces
> would be needed.
> Latex primer and house paint will last forever in this application.
> Doug
> (978) 282-1349
would be needed.
Doug
Thanks Dave. All good points. I like the bondo idea, never thought of
Bryant
all
> above
recommend
cost
> > Bryant
> Hi Bryant,
> At Arbor Woodworks, we have done several similar projects. We have
> treated the raw edges w/Bondo (polyester based automotive filler
> compound) before painting. The specification - received from the
> architects involved - seem a little on the under-engineered side to
> me. That may just be my ignorance and aversion to callbacks
speaking.
> At any rate, the details are as follows. First, we sand the raw
edges
> to eliminate sawmarks. Then, we break the edges heavily (paint
> doesn't like to adhere to sharp corners/edges). Then we slather on
> heavy, thorough coating of Bondo. After it cures, we sand the Bondo
> smooth. Then we paint. We've used both oil & latex paints, with no
> problems so far (the newest is about 3 years in service). It's
> important to prime the surfaces well. We use either the primer that
> matches the topcoat, or a good fresh 2 pound cut TINTED shellac.
> After the first, light primer coat, we sand very carefully. After
> second coat of primer, we sand lightly. Then we follow with 3-5
coats
> of topcoat.
> Depending upon the aesthetics, I might be tempted to fiberglass
tape
> & epoxy treat the edges - if I were doing it for myself. Based upon
> our experience to-date, it's likely overkill.
> Hope that's helpful.
> David Graybeal
> Portland, OR.
> "Moderation in all things, especially moderation"
above
> Bryant
Hi Bryant,
me. That may just be my ignorance and aversion to callbacks speaking.
At any rate, the details are as follows. First, we sand the raw edges
doesn't like to adhere to sharp corners/edges). Then we slather on a
After the first, light primer coat, we sand very carefully. After a
second coat of primer, we sand lightly. Then we follow with 3-5 coats
of topcoat.
Depending upon the aesthetics, I might be tempted to fiberglass tape
David Graybeal
Portland, OR.
Bryant
