Re: Re: [bolger] Concrete Ballast Keels
>Sent: Thursday, April 08, 2004 7:58 AMBetter keep it on the QT or all the tree huggers will
>How about this for a solution? Mercury has a
>specific gravity of 13.5
>compared to lead's 11.3. All you would have to do
>then is just build a
>sealed tank in the keel to hold little less than
>four gallons of Hg and
>Bob's yer uncle! Nothing to melt because mercury is
>liquid at room
>temperature. Just pour it in and drive in the bung!
be camped on your doorstep with intentions of doing
you bodily harm...
Steve
Do I need to start casting lead bricks to sell to you micro folks with keel anxiety? Cast them the correct thickness, with
interlocking, or possibly rough sides. You non-metal melting boat builders could then just epoxy them into your keel.
Sent: Thursday, April 08, 2004 6:58 AM
Subject: Re: [bolger] Concrete Ballast Keels
> How about this for a solution? Mercury has a specific gravity of 13.5
> compared to lead's 11.3. All you would have to do then is just build a
> sealed tank in the keel to hold little less than four gallons of Hg and
> Bob's yer uncle! Nothing to melt because mercury is liquid at room
> I'm a genius!
Not bad! Maybe you quit too soon, though: Why not twin bilge keels, and
pump the mercury into the windward keel? With a little easily-added tubing,
you'd also have a thermometer giving you accurate water temperature!
_____
I'm a genius!
(978) 282-1349
_____
_____
I'm a genius!
(978) 282-1349
_____
I'm a genius!
I'm a genius!
Not to advocate putting a concrete keel on a Micro, but it should be
pointed out that concrete has a history of being used for external
ballast keels on amateur built boats. Sam Rabl shows it in his classic
book _Boatbuilding in Your Own Backyard_, and George Buehler (who could
be considered the ideological descendent of Rabl, as they both stress
low tech, low budget traditional approaches) advocates it in his book
_Buehler's Backyard Boatbuilding_. Buehler's experiences with it
indicate that it is quite strong and durable with the proper mix of
concrete.
Bob
concrete.
Bob
