Re: fir or cedar trim
Yes, I will be using epoxy. I should be able to find some heartwood,
too. I will check the Forest Service Handbook.
Pierre
--- Inbolger@yahoogroups.com, cha62759@t... wrote:
> Hi Pierre, Are you using epoxy? Douglasfir will take the gaff as
> rubrails whereas Western Red Cedar is easily marred even with epoxy
> coatings. I would suggest using Red Cedar for trim other than
rubrails
> but only if you coat it with epoxy. RC has nasty slivers as you
> probably know but if coated these are under control. I generally
> assume that any woood I am likely to use is subject to rot. The
only
> woods generally available that resist decay are Redwood, Western
Red
> Cedar and Cypress from the southeast US---but only heartwood which
is
> not always identifiable. As usual I would suggest you consult the
> Forest Service Wood Handbook. See the message above under "Wood"
for
> the address.
> Bob Chamberland
> -- Inbolger@yahoogroups.com, "Pierre" <myvoj@y...> wrote:
> > I have a plentiful supply of douglas Fir and western red cedar.
> > What's the verdict of using these woods for trim - rubrails,
etc.
> > Any wood boats I have had in the past have had oak, and as you
know
> > it tends to rot easily.
> > Any opinions, or pointers?
> > Thanks.
> > Pierre
coatings. I would suggest using Red Cedar for trim other than rubrails
assume that any woood I am likely to use is subject to rot. The only
woods generally available that resist decay are Redwood, Western Red
Cedar and Cypress from the southeast US---but only heartwood which is
Forest Service Wood Handbook. See the message above under "Wood" for
the address.
Bob Chamberland
> What's the verdict of using these woods for trim - rubrails, etc.
> Any wood boats I have had in the past have had oak, and as you know
> Thanks.
> Pierre
Thanks.
Pierre
