TB3 glue
> That TB III sounded real good until I ran across this warning:In fact ANSI/HPVA Type I Specification attests to water resistance only. Small, wet
structures probably need good coatings anyway though.
At least stronger than TB2.
Lower temp
Apply on only one side of the work piece.
Water cleanup
$38 / gal
Hard to beat
> No reason, with a name like Titebond 3, to expect it to act all thatThat's why not to glue to a hard epoxy surface with it. Since wet epoxy seems to stick to
> different from Titebond, which is a glue for porous surfaces, especially
> wood! If it's really as waterproof as they say, it will be nice to have
> anyway.
just about anything, the reverse may not be true. So no problem taping over edges.
Mark (after having recently cleaned up miles of PL premium joints with mineral spirits one
some white melamine shelves, really favoring the water cleanup.)
