Re: Micro (Roger KEyes) Plywood Dodger for Offshore Sailing
--- Inbolger@yahoogroups.com, "mannthree" <johnmann@i...> wrote:
He says that the bottom (foot) of the
> main might just touch the top of the doghouse during a tack, but as
> this doesnt happen a lot its nothing to worry about!! He has a
> yuloh (hope thats how you spell it. As I mentioned he doesn't
> believe in motors.
> He does venture out into the strip of "ocean" on his way to a place
> on Eyre Peninsula (Port Lincoln) and those waters receive the full
> brunt of southern ocean winds.
Wow! So he goes that far out! I would think that qualifies as "off
shore cruising" - in my book. Nice to hear about the yuloh as well. I
bet Jason will like to find out more about that - as he has built one
for his MICRO.
I find it really exciting to hear what some of the Bolgerados are
doing in my favorite small boat.
Thanks, Nels
--- Inbolger@yahoogroups.com, "graeme19121984"
<graeme19121984@y...> wrote:
adjustment.
The tiller is still in the same position but he can reach it from
the aft section of the doghouse. He can lay across this aft section
and "rest" in protection in rough or windy conditions.
I'm not sure fo the deatil of cooking and chart table facilities.
Mr Bolger was consulted on the change and roger built a
cardboard "mockup" of the doghouse. There are no drawings that I
know of
John
Great photo John.
> Graeme,I think he has a forward hatch to facilitate anchor and rig
adjustment.
know of
John
Great photo John.
> Roger's boat keeps changing. Do you know if Roger's boat has aMr
> forward hatch or are there side decks along the cabin extension to
> access the bow? Can he steer/sail from inside? Has the extension a
> chart table/galley? Can you cook standing up in there? As you say
> Bolger was involved do you know if either he or Roger would haveKeyes
> drawings of this up grade?
> Best Regards
> Graeme
> > Greetings,
> > I have just placed a picture in the photos section of Roger
> > Micro with a plywood dodger he designed )after some discussiontakes
> with
> > Bolger) to give hime more protection for his offshore sailing
> > expeditions. Roger is in his late 60's (at least) and still
> > his Micro out into the waters of South Australia. He doesn'tgo.
> > believe in motors and relies on sail to get wherever he has to
> > The photo is named as per the subject of this posting.
> > Regards,
> > John Mann
assured me that he hasn't. His main looks a bit higher than mine so
I'm not sure how it works. He says that the bottom (foot) of the
believe in motors.
I'm not sure of how many Micros have been built in Australia and
sailed regularly. I'm sailing on Sydney Harbour, and I have a
convert who is building another in Sydney. There are a few
scattered around New South Wales and South Australia has a healthy
wooden boat community, and numerous Bolger type boats have been
built and sailed there.
John
If you look closely at the picture you can see the
> --- Inbolger@yahoogroups.com, "mannthree" <johnmann@i...> wrote:I asked him if he had re-cut his main to clear the doghouse be he
> Nels,
believe in motors.
John
> > snotter arrangement. Also note the large scuppers in the sternhe
> > transom - to exhaust water from a wave over the stern or cockpit,
> > Cheers,
> > John
> Hi John,
> The second snotter line really looks like a good idea. I wonder if
> raised the sprit location a bit to clear the dog house, or isthere
> enough room without? I know there was a LONG MICRO built with aSt
> somewhat similar house and he could not use the sprit, which of
> course severely affected the sail shape off the wind.
> I had also noticed that Roger had completely closed off the stern,
> where the motor would normally go and put a scupper/ step at each
> corner of the transom. Also looks like there might be a sculling
> attachment at the upper edge of the transom. True innovation!
> I looked at the map and see that area around Adelaide is somewhat
> sheltered from the complete openenss of the Southern Ocean (Gulf
> Vincent) - still most would prefer I boat larger than MICRO Iwould
> imagine.how
> That area seems to be a hot bed of Bolgerados. Any estimates of
> many MICROS there are Down Under?
> Thanks for all the information.
> Cheers, Nels
Great photo John.
chart table/galley? Can you cook standing up in there? As you say Mr
Best Regards
Best Regards
> Greetings,
> I have just placed a picture in the photos section of Roger Keyes
with
> expeditions. Roger is in his late 60's (at least) and still takes
> believe in motors and relies on sail to get wherever he has to go.
> Regards,
> John Mann
John,
Thanks for the clarification...now I understand.
Jim
Jim
> --- Inbolger@yahoogroups.com, findleyjh@e... wrote:
> > Sorry,
> My nomenclature may be incorrect. I was referring to the raiased
> cabin which extends aft of the original Micro cabin to the edge of
> the forward part of the cockpit footwell. I thought this may be of
> some interest to prospective Navigator builders as one sailor's
> solution to protection at sea for Micro sailors,
> Cheers,
> John
> Greetings John,
> > This is a nice picture, to be sure. But could you help a
relative
> > newcomer like me understand what you're refering to? I can see
> that
> > the cabin appears to be built prouder than the original plans and
> > there apppears to be some superstructure aft. I'm just not sure
I
> > see the dodger.
> > Confused as usual,
> > Jim
> Cheers,
> John
Hi John,
The second snotter line really looks like a good idea. I wonder if he
raised the sprit location a bit to clear the dog house, or is there
sheltered from the complete openenss of the Southern Ocean (Gulf St
Vincent) - still most would prefer I boat larger than MICRO I would
imagine.
That area seems to be a hot bed of Bolgerados. Any estimates of how
Cheers, Nels
at sea. Roger uses one mechanical block for the mainsheet but the
halyard and snotter lines all pass through blocks of wood through
which holes have been bored. Roger's philosophy is that the less
moving parts a boat has the less is the chance for something to
jam. He has two snotter lines running through a thimble at the
mast. When he needs to reef, the releases the main snotter and
after re-adjusting the clew at the end of the boom, he pulls on the
second snotter line which is attched to thumb cleats at the
appropriate distance further aft on the sprit boom. I have rigged
this on my boat and it works, but doesn't necessarily give good
purchase. If you look closely at the picture you can see the
John
You'll find it in the photo section of this group under the
> --- Inbolger@yahoogroups.com, "mannthree" <johnmann@i...> wrote:wrote:
> > --- Inbolger@yahoogroups.com, "Roger Derby" <derbyrm@s...>
> > > Nels,The main modification to the rig is to allow ease of reefing whilst
John
> > heading of the subject of this posting,is
> > Cheers,
> > John
> This looks to me like a completely enclosed small doghouse with a
> sliding hatch on the top and a companionway? Also looks like there
> a foredeck hatch as well!
> Also I am curious about rig mods and if there is a remote steering
> station?
> Any info on these John?
> Cheers, Nels
the capital (Adelaide). There are three peninsulas the Fleurieux
Peninsula, York Peninsula and Eyers Peninsula and a largish Island
named Kangaroo. Roger sails right across these waters stopping at
the many coastal towns and ports along the way. My uinderstanding
is that his trips can be 2 - 3 weeks at a time. I asked him if his
mainsail has been recut to clear the cabin but he informed me that
it has not,
John
Greetings,
> --- Inbolger@yahoogroups.com, "mannthree" <johnmann@i...> wrote:Goto a map of Australia. Find the state of south Australia. Find
> > Nels,
it has not,
John
Greetings,
> >Keyes
> > Micro with a plywood dodger he designed )after some discussionwith
> > Bolger) to give hime more protection for his offshore sailingtakes
> >of
> > Regards,
> > John Mann
> Hi John,
> Any chance of getting any further information on the exploits of
> Paloma Blanca? I know Roger has taken her offshore on the Southern
> Ocean. I was wondering how far offshore and/or the length of any
> his voyages? Would love to hear anything at all actually!install.
> Here is a link to what the boat looked like before the dodger
>http://www.ace.net.au/schooner/keyes.htm
> Cheers, Nels
John
Greetings John,
> Sorry,My nomenclature may be incorrect. I was referring to the raiased
John
Greetings John,
>that
> This is a nice picture, to be sure. But could you help a relative
> there apppears to be some superstructure aft. I'm just not sure I
> see the dodger.
> Confused as usual,
> Jim
Hi,I cant find pictures, Are you sure they are in this group?
Dick
Dick
> Greetings,
> Micro with a plywood dodger he designed )after some discussion with
> Regards,
> John Mann
sliding hatch on the top and a companionway? Also looks like there is
station?
Cheers, Nels
> --- Inbolger@yahoogroups.com, "Roger Derby" <derbyrm@s...> wrote:This looks to me like a completely enclosed small doghouse with a
> Cheers,
> John
station?
Cheers, Nels
John
Which group would that be under?
> You'll find it in the photo section of this group under theheading of the subject of this posting,
John
>Keyes
> Roger
> derbyrm@s...
>http://derbyrm.mystarband.net
> From: "mannthree" <johnmann@i...>
Ocean. I was wondering how far offshore and/or the length of any of
Here is a link to what the boat looked like before the dodger install.
Cheers, Nels
> Greetings,Hi John,
> Regards,
> John Mann
Cheers, Nels
Jim-
A dodger is like a little hood like protrusion off the deck that
offers some protection of the cockpit from spray, wind, rain, sun
and etc. That picture is kind of a wierd looking example because of
the small window and square look to it......alot of boats will have
a canvas doger on a ss frame that you can errect quickly if the
weather turns foul. Where a pilot house would have a sealed aft end
with a hatch or door. A dodger is open to the elements on the aft
end.
There are better photo examples out there somewhere maybe someone
knows of a good one.
Jason
end.
Jason
Greetings John,
newcomer like me understand what you're refering to? I can see that
see the dodger.
Confused as usual,
Jim
see the dodger.
Confused as usual,
Jim
Greetings,
John Mann
John Mann
