Re: bottom butt straps?
I staggered two sheets of 1/4" to laminate the bottom of my micro.
I worked fine with no problems. I drilled a few holes to vent
trapped air, and then used sheet rock screws to temporarily hold the
assembly together while the epoxy kicked off. I filled and glassed
the whole hull so the sheet rock screw holes were not an issue.
I recommend glassing the hull prior to putting on the keel!!! do as
much now before the hull becomes a real beast to deal with. Working
upside down is no fun at all.
ammending my quick reply, while 6" is probably adequate, full half-sheet
overlaps (2') would be the strongest - it may mean ripping one of your
sheets in half before cutting out the hull shape, and doing shorter 2'
chunks at either end - probably best to do these smaller pieces as the
second layer, just to make it a bit easier to get the pieces on and have one
less floppy seam to wrestle with on the overturned hull.
Paul Lefebvre
I was thinking (rare) if i stagger the 2 layers of 3/8 inch bottom
panels (on a micro) about 6 or more inches can i do away with the
butstraps? Would make building the bunks much more simple and less
crap on the sole to trip on.
Jason
Paul Lefebvre
Jason
--- "Jason Stancil" wrote:
plans you begin to realize the
genius of Phil Bolger.
The buttstraps on the bottom
of the boat are where the bolts
go to connect the 1 1/2" keel
nailer. Those buttstraps serve
structural double duty as a
stress reduction point for
this bolt heads. Indeed, he
even has added a 'false buttstrap'
at the midpoint of the boat.
The sides of the bunks, and the
sides of the raised floor of the
Navigator upgrade also serve
structural double duty. PB&F has
written [and said] that the flex
of the Micro bottom in offshore
conditions is a concern.
The berth sides are intended as
structural reinforcement to the
bottom.
I know it is hard to resist. But
personally I have learned to chant:
"In Phil We Trust" as a mantra,
everytime I get the urge to
'improve' on a PB&F design.
Not that PB&F doesn't ever make a
mistake, [or that his designs can
never be improved], but it pays to
think twice [and thrice] before
trying to out-guess a genius.
> ...do away with theIf you really study the Micro
> butstraps?
> ...building the bunks much
bottom.
yes, definitely do this if you are laminating the bottom out of 2 layers.
It's the right way to do it, even Bolger said so in his letter to me.
Paul
Sent: Thursday, April 22, 2004 11:14 AM
Subject: [bolger] bottom butt straps?
Jason
(978) 282-1349
Paul
Jason
(978) 282-1349
Jason
Jason
