Re: Brick Project
Dave,
That kind of double bottom is a rot trap. Better to just lay on another sheet of ply if
you want it for the armor and the ballast. I have a pair of 1 1/2" x 1 1/2" x 8' stringers
laminated as per Bolger's plan, making the good quality 1/4" ply bottom plenty stiff.
2" x 6" x 3' ( or a little longer) keels well faired ought to be both a good start on area
and heavy enough, with some extra heeling as per David and Paul.
With moderate hesitation, I'm going to shorten my rudder by about eight inches in order to
have good bearing for a kick-up pivot. A shoaler option might be a "barn door" type,
especially with an endplate.
Dave wrote
> The
> 1/4" Ply on the bottom sure seems thin. I might laminate 1/4" X 4"
> strips of Douglas Fir over the Ply,Then maybe another sheet of 1/4"
> ply over that?? This of course will make it heavy. {Too Heavy??} Any
> Ideas on this? I know that the "Shoes" Will stiffen it some, Maybe add
> "Shoes" on the inside too and skip all the Laminating?? This is my
> first Boat.
> I am still working on the "Bilge" Keel Idea, Shallow Lakes where
> I will be Sailing around here. Maybe make them-2" X 6" X 3'? And
> thank You All for your input on the "Twin Bilge Keels" Very helpful
> information. You Guys are Greeat!!
