[bolger] Re: mj, freedom of speach, and a panic button
Date sent: Sat, 11 Mar 2000 22:54:12 -0800
To:bolger@...
Send reply to:bolger@egroups.com
Subject: [bolger] mj, freedom of speach, and a panic button
Sorry, but that's all a bit complex for me Alex.
I just believe in free exchange of information about a pastime all
people in this group are interested in, for the betterment of all.
Don
To:bolger@...
Don
> If yours was a private letter to PB&F I would have no quarrel
> with it. Although waiting until PF&B had sufficient time to
> address the more immediate needs of MJ owners would not have
> been too much to ask.
> However, publishing it in the most concentrated group of PB&F
> current and future clients, makes it a different matter.
> I am sure you would understand should anyone do the same to
> you in the presence of your current and future clients.
> The particular points in your last couple posts I objected
> to were:
> You appeared to be:
> Mentoring PB&F on proper behavior with you as the model;
> >> I am a design professional in another field. If this worry
> >> surfaced regarding some of my work, I would respond as soon
> >> as possible.
> Suggesting PB&F is not fulfilling designer's obligations to
> educate and reassure clients, and, as a result, PB&F reputation
> could be damaged;
> >> Not only to protect my reputation, but also to educate and
> >> reassure my clients.
> Implying that PB&F is hidings designs flaws;
> >> Several of your boats are designed on similar principles to
> >> Martha Jane, and if certain cautions of ownership should be
> >> observed, I wish to know before I select my next design.
> Speculating that PB&F is not responding because of a fear of
> litigation, and, finally:
> >> If we have not got free speech, I wonder why we have this
> >> Group
> which I naively mistook for a troll. While you apparently were
> sincerely concerned with freedom of speech. If that's the case,
> please accept my deepest apologies.
> Again, if yours was a private letter I would not have taken
> an issue with it, althought waiting for a while to allow the
> designer time to assess & respond to the situation instead of
> pushing a panic button would be more appropriate. Something
> that we often ignore in our quest for instant satisfaction.
> alex
> GET A NEXTCARD VISA, in 30 seconds! Get rates
> as low as 0.0% Intro APR and no hidden fees.
> Apply NOW!
>http://click.egroups.com/1/975/5/_/3457/_/952844103/
> -- Check out your group's private Chat room
> --http://www.egroups.com/ChatPage?listName=bolger&m=1
Don,
to were:
You appeared to be:
could be damaged;
alex
to were:
You appeared to be:
>> I am a design professional in another field. If this worrySuggesting PB&F is not fulfilling designer's obligations to
>> as possible.
could be damaged;
>> Not only to protect my reputation, but also to educate andImplying that PB&F is hidings designs flaws;
>> Several of your boats are designed on similar principles toSpeculating that PB&F is not responding because of a fear of
>> If we have not got free speech, I wonder why we have thiswhich I naively mistook for a troll. While you apparently were
>> Group
alex
