Re: Antifouling and Masking Tape
right -
I do watch out for gaps in the tape prior to touching a brush to it.
I use a flexible putty knife to lay it out smooth. The other masking
tape sounds like a good buy if you can find it!
Happy building,
Catboat - Magnificat
I use the Kleen-Edge brand of masking tape. Masking tape, including
the 3M Blue, can leave a ragged edge since the paint can seep under
the slightly wrinkled edge. Kleen-Edge doesn't have the wrinkles. I
believe Wal-Mart carries it, but I know it's at HD and Lowe's. I've
also started using it for things like caulking. Leaves a very crisp
caulk line.
--- Inbolger@yahoogroups.com, "dbaldnz" <oink@w...> wrote:
> Hi David, thanks for your thoughts and advice. The tape which
caused
> the problem is probably the same blue shiney? stuff you use, and I
> had no trouble before. But this roll, still in it's plastic sealed
> package, must have suffered by being in the garage over summer. And
> it seemed really sticky, I should not have kept on with it. Yes, I
> always remove the tape straight away.
> I will try the penetrol you mention...the man in the boat shop was
> raving about it, but I thought he was adding value to his sales!
> My anti-fouling is Interlux Micron Extra, which is semi-hard but
> ablative, and suitable for shallow warm water, which is where Oink
> will start out being moored.
> Donb
Good thought, but the price of copper has rocketed worldwide, since
the chinese construction boom. Wiring a house in copper now costs a
lot more I believe, then there is hot water piping...it goes on!
How goes the boat Bruce?
DonB
http://oink.kiwiwebhost.biz/
> > > Antifouling,
> Doesn't Bolger favor copper sheathing?
Hi David, thanks for your thoughts and advice. The tape which caused
Donb
--- Inbolger@yahoogroups.com, "dnjost" <djost@m...> wrote:
> Congrats on getting to the fun part. Here is where patience and
> attention to detail will really pay off (literally). It can mean
> hundreds of dollars in resale value.
> I use 3M Blue tape for painting jobs. Never, ever leave it on too
> long as it becomes a mess to get off. When painting with alkyd,
or
> oil base paints, squirt a little Penetrol into the batch to make
it
> easier to apply. Sand with 180 grit in after you are sure its dry
> (rub your hand over it, if it is dry your hand will glide). It
> really makes a difference in the overall quality of the final
job.
> Yes, there are a couple of jobs worse that applying antifouling.
> 1. Taking off old antifouling paint because some poor sap applied
> the cheap stuff over many many years. (I like either the hard
epoxy
> formulas for racing sloops, or the ablative stuff that I use now.)
> 2. Applying barrier coat epoxy over old tired gelcoat. This is a
> minimum of 3 coats with sanding in between. This is actually an
> essay entitled "How I Spent My Spring Vacation." I have become a
> believer, wooden boats rule. What would that be in Latin? I think
it
> would be a good bumper sticker!
> David Jost
> "still itching and scratching"
Good reply Peter! Yes, I admit removing is worse, far worse.
Thanks also for your unflaggingly optomistic comment too. Launching
in winter is no problem here, indeed, the weather is often more
settled than summer, and especially spring when it blows like crazy.
I'm getting annoyed with this obstruction to my garage......cars are
rusting in protest! And work has slackened off a little, so the push
is now on, ready or not! (I have a backup in that the anti-foul is
good for 12 months before immersion!) Nope, she must be launched
soon.
The gentle tape works very well, from Sellotape, but don't know the
particular description because the wrapper was chucked, but on
another trip to a shop, there seems to be lots of similar products.
It's a horrible mid-purple color, and I was expecting the neighbours
to complain! You will need lots for your gold on black filigree
decor for Windermere.
DonB
> > Antifouling, is there a worse task in the world than applying
this
> > muck!
> Sure,removing the darned stuff:-)
> Glad to hear that you are getting closer to a launch time
> Don....must be just about driving you nuts watching beautiful
> sailing days go gliding past with OINK on the hard! I know I can't
> wait for the day when you've got some pics up on your wonderful
web
> page.
> Now,quit skimping on the cheap stuff,use only new tape,brushes and
> paints and save the aging for some high octane wacky juice
> sundowners from on board OINK!
> Oh,and before I forget,just how "gentle" is this new tape of yours
> Don and does it come in different colours? Never too late to think
> about supplies for the "toy box" in the master stateroom on board
> WINDERMERE :-)
> Sincerely,
> Peter,"no stranger to wacky juice",Lenihan,who can only dream,at
> this point,of the day when his worries will concern only anti-
> fouling paints,straight waterlines etc......
> > Antifouling,
long as it becomes a mess to get off. When painting with alkyd, or
oil base paints, squirt a little Penetrol into the batch to make it
really makes a difference in the overall quality of the final job.
the cheap stuff over many many years. (I like either the hard epoxy
believer, wooden boats rule. What would that be in Latin? I think it
> Antifouling, is there a worse task in the world than applying this
> muck!
wait for the day when you've got some pics up on your wonderful web
page.
WINDERMERE :-)
muck! I did the first 2 coats on Oink this weekend. One to go.
But a huge annoyance when I stuck on an old roll of masking tape to
mask the waterline. It seemed extra sticky, and after pulling it
off, it took patches of topside paint with it. I have never had this
trouble before, and the hull had been well sanded before the
topsides were painted, months ago.
Today at the shop I found special 'gentle' tape, at twice the cost
of normal, and had no trouble with the second coat. It was also much
easier to adjust when applying.
One lives and learns!
DonB
