Re: looming 8 mi. "Surf" cruise to Cat Island Miss.
--- Inbolger@yahoogroups.com, "sterlingjb" <sterlingjb@y...> wrote:
> Two questions: Did the Surf oarlock placements as shown on the
plans
> work out for you (I weigh 205lbs)?
> Also, were you able to hang the rudder at sea, while single handing?
> Thanks again, Richard Baker
Hi Richard,
The seat worked just fine especially since its' fore and aft
placement permits some range of adjustment regarding where you plant
your fanny perpendicular :-) I'm 6' and a few pounds North of you
and found it worked well.
I built a tilting rudder blade to avoid having to ship the
thing while away from shallow water or a quay.A relatively quick and
easy thing to do while you are still in construction mode.
Don't forget to post some pics for us to admire !
Thanks, Peter, for your comments. Your cautious encouragement has
been taken to heart.
The end chambers in my Surf have been sealed, and 8in. screw-in
inspection ports have been installed in them. I will sit on a
floatation cushion, and will of course wear a life-vest. The sail is
from Payson...glad to hear that yours was so good. Your comments on
Surf's stability are also encouraging, and I will plan to row in
winds above 15kts.
Two questions: Did the Surf oarlock placements as shown on the plans
