Re: tapered masts and reefed sails
>the
> So, do you try to pull the slack out of the lacing after setting
> reef?That's what I did when reefing my Brick. A hassel, but without doing
> Peter
it the sail set like S___. Well you get the idea. I'd just pull the
extra lacing line in and cleat it off to a small cleat on the mast.
The invention of track and slides certainly solved that difficulty.
Reed
>Let us suppose that the lacing between the top reef's tack and theContinuous lacing or "forth & back" or the X-style Bolger has written up
>head of the sail is a fixed length, i.e. tied off at both ends. Then
>it is either loose when the sail is at full hoist, or too tight with
>the reef in. No?
should work fine if the luff is kept taut with downhaul and halyard.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
> If one goes with a "over-over-under" lacing pattern or followsLet us suppose that the lacing between the top reef's tack and the
> the one suggested somewhere by Bolger.ie;lashing succesive loops up
> along the mast AND lays out and rigs the lacing while the mast and
> sail are on a clean lawn then one can see that the moment
> tension is taken off the main halyard, these loops will
> open up considerably and lossen their grip on the mast.
the reef in. No?
So, do you try to pull the slack out of the lacing after setting the
reef?
sail are on a clean lawn then one can see that the moment tension is
taken off the main halyard,these loops will open up considerably and
As for reefing a Micro,or at least the way I used to do it,it is
really very simple; 20 feet of stainless steel sailtrack from
Defender Industries. Amazingly elegant :-)
>Hi Peter V.,
> If one has a tapered mast with a laced-on sail, what happens when
> reefing? I'm thinking that the lacing near the head of the sail has
> to enlarge to accommodate the larger mast diameter at a lower
> altitude.
> For that matter, how do you Micro guys handle the snotter when
> reefing?
> Peter
altitude.
reefing?
altitude.
reefing?
