Re: water logged hull AKA premature launch
Suggest fan and dehumidifier in area where boat is, and maybe a source
of heat, at least for any time you will be there. Failing a
dehumidifier, maybe you can kind of tent in the boat and blow a dryer
source of air into the tent. The longer you wait, the dryer.
If you have a strong vacuum pump, you might be able to figure out how to
pull out lots of moisture with a vacuum bag in a very short time (matter
of hours, I bet), if you can set it up for a really low pressure, like
1/2" Hg. But don't crush any hollow spaces! Look up the vapor pressure
of water (about .37psi at 70F, I think) at your temp, and try to get
below that. But if you don't have the pump it's probably not worth the
trouble. I used to put little cups of water in a bell jar and watch them
boil until they cooled off.
Lincoln Ross
Lincoln Ross
Jason,
That is indeed a good story. And it's understandable that it's taken
you a bit of time to appreciate the humor. You had better put a push
on and finish that boat. It obviously wants to go sailing, and shows
every evidence of being willing to go without you, if you're going to
dawdle.
Seriously though, I agree that you probably don't have a huge problem.
The one suggestion I'd make - having dealt with similar situations in
my architectural millwork business - is to move as much air past the
hull as you can. Don't let the mold/mildew get a foothold. If it just
sits in still air in a stuffy basement, it might (likely) begin to
mildew. Borrow, rent, or beg some fans and leave them on as much as
you can stand. Leave as many doors/windows/makeup air vents open as
you can. The key is to maximize air movement.
Good Luck,
David Graybeal
Portland, OR.
where we know that summer is coming - the fog is getting greener
> So here's my problem water has soaked into my hull panels because********************************************
> i've been too damn lazy to flip it (again) and glass it. I'm leaving
> town for a week and am going to flip it so it can dry out. Then when
> i get back i want to glass it. Do you folks think it will be dry
> enough.....rot problems, mildew, mold?.....my basement is always a
> bit on the dank side. What can or should i do? Can i treat the
> endgrain with some kind of perservitive?
> Jason
Jason,
dawdle.
Good Luck,
David Graybeal
Portland, OR.
I think you will be OK, it takes some time for the water to soak in to any
real depth. The surface water will dry in a short time. Thanks, now I have
something for the dinner conversation at home.
All the best;
Robert Gainer
Watch LIVE baseball games on your computer with MLB.TV, included with MSN
Premium!http://join.msn.click-url.com/go/onm00200439ave/direct/01/
All the best;
Robert Gainer
>From: "Jason Stancil" <jasonstancil@...>_________________________________________________________________
>Subject: [bolger] water logged hull AKA premature launch
>Date: Wed, 26 May 2004 15:21:26 -0000
>I've been silent about this beacause i've been so pissed but now i'm
>seeing the humor in it. Torrential rains hammered Dellslow,
>WV.....were i live, on saturday. The culvert beside my house got
>clogged with debris and the water begain to rise. I was upstairs and
>heard a tknocking down in the basement. I thought the barn doors had
>blown open so i ran down stairs. The doors were shut but water was
>pouring out from under them. I unlatched the hasp and was allmost
>run down by the micro, which was trying to float it's way down the
>drive way. That's right folks my micro has been launched......only
>took 2.5 inches of water to float the almost bare hull. DOH!
>endgrain with some kind of perservitive? Am i being overly
>weary.....it is a boat after all, and alot of boats never even get
>glass. I just don't want to trap moisture in the hull.
>If you are going to tell me i'm screwed and the bottom is going to
>rot out in a year or two....DON'T....just lie to me and tell me it
>will be OK :)
>Jason
will be OK :)
Jason
will be OK :)
Jason
