Re: Sharpie / trolling motor
sorry didn't address my experience with it...with the 2 hp, no
vices, no weirdnesses. With the june bug in general, a nice
sailor, but keep everyones butts planted on the floor...good initial
stability, but didn't take much to roll it, once past that point.
never rowed it, so can't speak to that.
Adam
i had a junebug that i ran a 21 lb Yamaha 2 hp outboard on. moved
it along at about 5 mph, anything more than that and the bow would
start to climb upward ( i ran a 7.5 hp mercury on it just for grins
once, and saw that happen).
Adam
--- Inbolger@yahoogroups.com, "ginkepink" <pa.venus@w...> wrote:
> Anyone any experiences/advices related to june bug propelled by a
> trolling motor??
> Paul
> trolling motor??
> Paul
I found that although trolls moved the boat along quite well they
were heavy to transport and tend to leave lingering smells .I changed
over to dwarves. they stow really well under the.
deck when not in use and can sing really well whilst rowing.
the two I used knew a really cute blonde
Paul.
trolling motor??
Paul
--- Inbolger@yahoogroups.com, craig o'donnell <dadadata@f...> wrote:
> Bolger's slab-sided sharpies are well known. The Peero, at 12', is
about
> the smallest and they go up to the AS39 and beyond.
> A boat with lots of flare, like a dory, is good for load carrying
because
> as you add each pound it gets harder and harder to increase the
draft. But
> it is a very tender sailing hull without ballast. (This is not to
say that
> there haven't been dory racing classes, but that's the case).
> The slab-sided boats are very stiff even without ballast and given
> sufficient freeboard are virtually unswampable. You can swamp a
Peero
> because it's so small. But try that with an AS29.
> Craig O'Donnell
> Sinepuxent Ancestors & Boats
> <http://freepages.genealogy.rootsweb.com/~fassitt/>
> The Proa FAQ <http://boat-links.com/proafaq.html>
> The Cheap Pages <http://www.friend.ly.net/~dadadata/>
> Sailing Canoes, Polytarp Sails, Bamboo, Chinese
Junks,
> American Proas, the Bolger Boat Honor Roll,
> Plywood Boats, Bamboo Rafts, &c.
> _________________________________
> -- Professor of Boatology -- Junkomologist
> -- Macintosh kinda guy
> Friend of Wanda the Wonder Cat, 1991-1997.
Bolger's slab-sided sharpies are well known. The Peero, at 12', is about
A boat with lots of flare, like a dory, is good for load carrying because
as you add each pound it gets harder and harder to increase the draft. But
it is a very tender sailing hull without ballast. (This is not to say that
sufficient freeboard are virtually unswampable. You can swamp a Peero
Craig O'Donnell
