Re: MDO delamination
The recent soaring lumber prices have produced another bad effect.
I've seen quite a bit of exterior plywood lately that delaminated due
to poor manufacture. I took two sheets of 1/2" ply back to Lowes a few
weeks ago.
And if you pick up a sheet of OSB now you may notice that it doesn't
weigh very much. I have some old pieces that have been laying outside
for two years that are still intact. A new sheet I used to cover some
construction work began to disintegrate in about two weeks.
Doug
--- Inbolger@yahoogroups.com, craig o'donnell <dadadata@f...> wrote:
> It must be defective plywood. MDO is exterior glue ply as used for
road
> signs etc. This is the first complaint I've seen about problems with
it.
>Do you think this is a defect in the plywood or the result of getting the
>boat wet? I only just joined this group so I may have missed something but
>did you say its not marine plywood. What makes this the “better wood”? Is
>the glue waterproof.
It must be defective plywood. MDO is exterior glue ply as used for road
signs etc. This is the first complaint I've seen about problems with it.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
did you say its not marine plywood. What makes this the �better wood�? Is
Thanks;
Robert Gainer
>From: "Jason Stancil" <jasonstancil@...>
>Subject: [bolger] MDO delamination
>Date: Wed, 02 Jun 2004 00:53:57 -0000
>So after leaving town for week, the micro AKA ark has dried out
>enough for the glassing fun to begin.
>Today, after work i sanded all the seams and rounded the chines to
>prepare for tommorrow's dynel sheathing.......and there it was that
>little bulge just above the rear port chine. I figured i would kick
>my self in the rear if i let it be until after i finished it.
>I put the grinder to it and now i have a 6" x 8" "hole" thru the MDO
>sheathing and the first ply and a half of plywood. Kinda pissed i
>sprung for the better wood and i'm having this problem. Olympic is
>going to get an earful tommorrow!
>The repair? Should i just slather it full of micro ballons and fair
>or should i lay a little bit of 6 oz glass in there and then
>fair?.....it looks like a litle bit of delam goes a bit farther than
>what i've ground out. Should i just empty a syringe full of epoxy
>down in there.....or keep grinding?
>Can't say for sure till i finish out the top sides, but as of now i
>wish i would have gone with the marine fir.
>Thanks
>Jason
_________________________________________________________________
Check out the coupons and bargains on MSN Offers!http://youroffers.msn.com
Thanks
Jason
