Re: [bolger] glass/dynel and epoxy?
I don't really know since I've only used System Three. My bet is that they
are both good. I do like the Gougeon Brothers' book on "Boatbuilding."
When I ordered the System Three "Test Kit," S3 products were slightly
cheaper than West Systems. I was "off-put" by West System's marketing
technique, but I don't remember why.
I like System Three, it works, Kern Hendrix answers questions well -- why
should I change and re-do my learning curve?
> Roger, I have been thinking about switching from West System to System
three
> because of the fact that you can still get a chemical bond if you recoat
> within 72 hours. How do the two compare? I have only used West System.
> Grant
> on 6/5/04 11:20 AM, Roger Derby atderbyrm@...wrote:
> > From System Three's "Epoxy Book" (free at
> >http://www.systemthree.com/m_register.asp) Yes, you do have to
register to
> > get the book. It's in pdf form.
> > Fiberglassing
> > (sealer, wet-out & fill coats)
> > square feet of coverage per gallon
> > first subsequent
> > coat coats
> > 4 ounce cloth 150 300
> > 6 ounce cloth 130 250
> > 10 ounce cloth 100 170
> > Biaxial Tape 32 40
> > So one and one-half gallons should do
> > 1.5 x 130 x 250/(250 +260) = 96 sq. ft.
> > If you put on three coats.
> > That's assuming Raka is not too different from System Three in coverage.
> > Roger
> >derbyrm@...
> > From: "Jason Stancil" <jasonstancil@...>
> >> I just cleaned out and inventoried the basement and realized i used
> >> a hair more than a gallon of Raka Resin and a hair more than a half
> >> gallon of hardener! laying the 6 oz dynel sheath......Did i use way
> >> too much or is that about right? I was kinda worried it was'nt
> >> wetting out.....the dynel does'nt go clear like glass so it's tough
> >> to tell. Doh! got to order more....again. 6 gallons and counting.
> >> Jason
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
Fax:
> > (978) 282-1349
> > Yahoo! Groups Links
(978) 282-1349
Roger, I have been thinking about switching from West System to System three
Grant
>http://www.systemthree.com/m_register.asp) Yes, you do have to register to
> Fiberglassing
> first subsequent
> coat coats
> Biaxial Tape 32 40
> Roger
>derbyrm@...
>> Jason
> (978) 282-1349
Fiberglassing
first subsequent
coat coats
Biaxial Tape 32 40
> Jason
Jason
