Re: [bolger] Re: Gudgons for Teal
My local farm supply store has galvanized (really, not just zinc plated)
shoulder eye bolts just like the ones Jamestown used to sell, and they
aren't expensive. They also have galvanised "gudgeons and pintles" for gates
and barn doors, consisting of a big lag bolt pintle and a strap gudgeon,
IIRC, the reverse of usual boat practice, but they'd probably work fine if
your project is big enough.
On Sun, 06 Jun 2004 15:08:44 -0000, Bob Chamberland wrote:
> By the way the lag screw was set in epoxy. I seem to remember that the
> shoulder eye bolt I bought was galvanized but I don't see that in my
> latest catalog. Rather it is stainless and expensive. I think you
> could use the regular galvanized eye bolt and use a loose washer for a
> shoulder. You really want the shoulder to prevent the bolt from going
> to deep into the wood when you tighten it up.
John <jkohnen@...>
http://www.boat-links.com/
Many a man has fallen in love with a girl in light so dim
he would not have chosen a suit by it. <Maurice Chevalier>
Bob Chamberland-
-- Inbolger@yahoogroups.com, cha62759@t... wrote:
> I had the same problem when I built my Teal.
> I used the pintles from Jamestown.I don't remember the size but they
> were the pintles listed under the WC46---- series but appropriate for
> the thickness of the rudder. For gudgeons I used a shoulder eye bolt
> for the top gudgeon and a eye lag screw (also with a shoulder though
> not listed that way)also from Jamestown. The inside diameter was way
> big for the gudgeon. I got some delrin or nylon bushings from Home
> Depot and cut them to about 3/8" in length and forced them into the
> eye. This worked very well. I'm not sure what these nylon fittings are
> meant for but there is a whole section of various sizes.
> Bob Chamberland
> --- Inbolger@yahoogroups.com, "stoo_mcdoo" <stoo_mcdoo@y...> wrote:
> > I am looking for gudgeons to fit my twenty year old Teal.
> > Jamestown Distributers, where I bought the originals, only has
> > them for a flat transom. Help!
> > Thanks,
> Stuart McD
Bob Chamberland
> Thanks,
Stuart McD
Try a catboat builder such as Marshall Marine in South Dartmouth,
MA. They have gudgeons for their catboats that attach to the keel
and rudder. I think I paid about $60 per set.
I bought custom cast bronze pintels and gudgeons for my double-ender
from Lunenburg Foundry in Nova Scotia. www.lunenburgfoundry.com
They were not cheap ($400 Canadian), but I had been frustrated
trying to find another source.
Doug
Thanks, Stuart McD
Thanks, Stuart McD
Thanks, Stuart McD
