Re: Light Schooner/scooner
found a reference in the Boatdesign group:
http://www.seapearlboats.org/
--- Inbolger@yahoogroups.com, "senorian" <senorian@h...> wrote:
> Hi
> The Sea Pearl 21 had crossbeams and floats (amas?) added and the
> result was successful enough for the manufacturer to make it an
> option.
> I think that Hugh Horton may have some knowledge about them as I
> believe that one or more showed up at his Cedar key meets.I
searched
> the Sailing Canoe group but could not locate a reference
> --- Inbolger@yahoogroups.com, "pauldayau"
<wattleweedooseeds@b...>
> wrote:
> > . Does anyone have ideas for making the
> > > boat more seaworhty and easier to sail short/single handed.
> > > I'll be sailing in a somewhat exposed area and worry about
water
> > > coming over the deck and getting swamped, can the boat be
> righted
> > > bailed and sailed home?
> > > What about adding some ballast/water ballast?
> > > Wish me luck, I'm heading to the Post Office
> > This is quiet a common enquiry about the schooner.
> > David ryan had a bad experience doing just that, maybe he could
> help
> > us with the appropriate archive reference..
> > The common response is to refer you to the single handed
> schooner,
> > plans from both Bolger and Payson.
> > whatever you choose you'll love your schooner.
> > cheers paul Day AUS3 folding schooner 'Waltzing Matilda'
Hi
option.
believe that one or more showed up at his Cedar key meets.I searched
--- Inbolger@yahoogroups.com, "pauldayau" <wattleweedooseeds@b...>
> > I'll be sailing in a somewhat exposed area and worry about water
righted
help
schooner,
One idea I've seen mentioned for the LS is to re-rig it as a cat-schooner
(ketch?) with two 59 ft^2 leg o'mutton sails taken from Brick, Gypsy, Teal,
et. al. in place of the powered up schooner rig. I think this would make a
nice boat, if a bit too docile in light winds.
Bolger also published a recent re-design of this boat as a cat schooner with
two identical gaff sails of about 75 ft^2 each that might be a little easier
to handle. If you are buying plans from PCB&F, you might get the sheet with
the new sailplan as part of your purchase price.
JB
Sent: Thursday, June 10, 2004 1:00 AM
Subject: [bolger] Light Schooner/scooner
> I'm girding my loins to mail off a cheque to buy the plans and
> actually do this.
> I still have reservations. Does anyone have ideas for making the
> coming over the deck and getting swamped, can the boat be righted
David ryan had a bad experience doing just that, maybe he could help
The common response is to refer you to the single handed schooner,
actually do this.
