Re: Natural alternatives to Fibreglass cloth?
Just buy the darn fiberglass and be done with it!
It'll be much easier to deal with, as strong, and your boat will be
back in the water in no time!
It is summer after all... at least here on Cape Cod...!
Cheers!
--- Inbolger@yahoogroups.com, "Justin Meddock" <jmeddock@n...>
Cheers!
> Not really natural, but I have a couple of old delaminatingmylar off
> Mylar/Kevlar sails laying around. I was thinking of pulling the
> and using the kevlar cloth for FG repair work.
> Justin
Standard concrete like that in your driveway and most structural
concrete is 3000 psi minimum in 28 days. You can buy harder mixes,
up to 6000 psi, if you need it to resist higher point loading like
bulldozer cleats or vibrating machines. There are different types of
cement and many different admixtures.
Structural steel, ASTM A36, has a minimum yield point of 36,000 psi.
Most structural shapes are also available in a high strength steel
that is 50,000 psi minimum.
Charles
but strength
Charles
but strength
> figures for epoxy under 10kpsi. I think with ferro cement, thecement
> might be able to take more of the compression load, as youdescribe,
> and as I recall portland cement is ok in compression and terriblein
> tension. I also seem to recall epoxy has some strength in bothtension
> and compression, but nothing like what you see with glass added.?
The fiber provides compression strength too. The epoxy (or polyester
resin) just holds it in place so it doesn't buckle. And maybe some local
strength across the fibers. I seem to recall typical figures for
strength of laminates in the tens of thousands of psi, but strength
figures for epoxy under 10kpsi. I think with ferro cement, the cement
might be able to take more of the compression load, as you describe,
and as I recall portland cement is ok in compression and terrible in
tension. I also seem to recall epoxy has some strength in both tension
BTW, what was that aircraft that turned into a bag?
>donschultz8275 wrote:snip
>snip
>Actually you have it almost entirely backwards. The resin holds the
>shape and resists some compression loads, while the fibers provide
>the strength in most every tension load.
>This is always true, even in ferro/cement construction. The steel is
>the strength. The cement does little more than keep the water out.
>It is also true that the fibers MUST resist tension loads as even a
>little stretch will crack, crumble, and otherwise wreck the resin.
You probably want to test the bond between epoxy and the salvaged Kevlar
real well before you invest too much labor.
I understand that most fibers for our work are coated with something to
encourage the epoxy to "wet" them. The sail material might be coated
differently. (One can't imagine the many different kinds of glass until
he's visited the Corning Glass Museum in Corning, New York.)
Sent: Wednesday, June 30, 2004 7:21 AM
Subject: Re: [bolger] Re: Natural alternatives to Fibreglass cloth?
> Mylar/Kevlar sails laying around. I was thinking of pulling the mylar off
Justin
Justin
Thanks Lincoln,
I did not think of it that way, the cloth absorbing could actually make the
hull a hell of a lot heavier. Not good!! hey?
Thanks for the answers I appreciate the kindness.
Whenever in stunning Cape Town - South Africa, you know my number!!
Regards
Marius
Marius Lubbe
Creative MindsR HQ
Cape Town, South Africa
Phone: 082 785 7763
w <http://www.minds.co.za> ww.minds.co.za
_____
Sent: Tuesday, June 29, 2004 11:31 PM
Subject: [bolger] RE: Re: Natural alternatives to Fibreglass cloth?
weight can be very significant. Particularly if you have to pick the
boat up. I seem to recall using most of a gallon on a dinghy. Probably 7
or 8 lbs. of epoxy and some additional weight of fabric. I'm not sure,
but I think the total weight of that boat is 60 lbs or less, so a large
fraction is in the coating and in the tapes. . I used 1 oz glass for the
coating, but it's not all that easy to use. Sure is cheap, tho.
strong, comparable to carbon fiber (but not as stiff), 500,000 psi for
e glass (s glass is even stronger) according to a quick web search.
Glass fibers are pretty floppy compared to carbon, though. Also, any
such composite (including carbon, kevlar, etc.) will be much weaker than
the individual fibers. My guess is that on really thin coatings (less
epoxy, mind you), the glass helps to prevent checking with its superior
strength. I also guess that a coating with natural fibers would have to
be thicker to do the same job.
glass is as cheap as any other fabric I've seen, or maybe cheaper. I
believe glass cloth and epoxy were invented seperately. I recall hearing
that lots of circuit boards were made out of glass cloth for WW2 and
afterwards all this surplus material was lying around.... I have the
impression that glass cloth was used with polyester resin first.
resilient as epoxy. And even then, in my experience polyester resin and
glass can stand up to some pretty hard knocks. I suspect those "resin"
models are something else entirely. THere are about a gazillion plastics
available these days. Epoxy would probably be too slow to make any money
out of those expensive molds.
(978) 282-1349
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=1299u3e5d/M=296967.5106131.6227187.3294649/D=gr
oups/S=1705065791:HM/EXP=1088619177/A=2181364/R=2/id=noscript/SIG=1304ck1na/
*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=
0002_0015_0178_0002>
<http://us.adserver.yahoo.com/l?M=296967.5106131.6227187.3294649/D=groups/S=
:HM/A=2181364/rand=355267776>
_____
Regards
Marius
Marius Lubbe
Creative MindsR HQ
Phone: 082 785 7763
_____
>however
>Marius Lubbe wrote:
>Hi Guys,
>snip
>I take the point of the writer who said that natural fibres will suck up
>more epoxy and make the work heavier. That makes a lot of sense, and would
>be valid if you constructed a whole boat of just glass and resin. We
>a looking for the most durable, easiest to work and most affordablesolution
>for a single thin skin, that will also not check, (I believe its becausethe
>fibres repel the resin, somewhat)!Actually, for small boats of 1/4" (6mm) plywood, the fabric and epoxy
>or
>My thoughts are (and please I not a scientist) that it seems to me that the
>resin is the thing that actually does the power thing, whereas the glass,
>cloth or whatever seems to be the matrix that hold it all in shape and givewas
>it some bulk all over a large area in a uniform kind of way. My thinking
>impregnated natural fibre would be stronger than glass strands which is (itbase
>seems to me at least) a weak material. For example: If they made a cheap
>stainless steel cloth would that not be a fantastic almost bullet-proof
>cloth?Glass fibers are very different from glass in your window. They are VERY
>Backyard
>You must please excuse my ignorance, but I am sure you will bear with my
>thinking somewhat out of the box. Actually it started with the book
>boatbuilding which suggest using anything that gets a boat together andWell, I don't think anyone has a monopoly anymore, if they ever did, and
>floating. I am not looking to do that, but am wondering whether we are
>conditioned by DuPont & co.to use the glass, without thinking about it. BTW
>what was invented first ? the glass or the epoxy? Was glass fibres invented
>first and then they started looking for a binding agent, to make it useful
>as a construction material?
>still
>I read somewhere about glass fibre boats not standing well up to knocks and
>cracking and crazing. Have you seen the little statuettes and models molded
>of resin. They look like they can stand being fired from a cannon, but
>is not too heavy!I'll bet these boats were made with polyester resin, which is not as
>Hope this is not starting to bore you, but I think we should explore allthe
>alternatives.Bolger rules!!!
>Regards
>Marius
(978) 282-1349
_____
Listen guys,
I want to thank you for sharing, I am learning quickly. Thanks to everyone,
there are too many to name, but I am grateful, and hope to be able to ask
some more "dumb" questions in the future, and being treated in the same kind
and respectful way!
Kind regards
Marius
Marius Lubbe
Creative MindsR HQ
Phone: 082 785 7763
_____
Sent: Wednesday, June 30, 2004 12:27 AM
Subject: [bolger] Re: Natural alternatives to Fibreglass cloth?
........My thoughts are (and please I not a scientist) that it seems
to me that the resin is the thing that actually does the power thing,
whereas the glass, or cloth or whatever seems to be the matrix that
hold it all in shape and give it some bulk all over a large area in a
uniform kind of way............
30 years ago there was a homebuilt aircraft which became popular
using a polyester varient fabric and epoxy w' foam as a internal
mold. If overstressed, the the epoxy broke up and the plane became a
cloth bag as it fell to earth.
(978) 282-1349
<http://us.ard.yahoo.com/SIG=129v9p4a9/M=296967.5106131.6227187.3294649/D=gr
oups/S=1705065791:HM/EXP=1088634432/A=2181364/R=2/id=noscript/SIG=1304ck1na/
:HM/A=2181364/rand=553225008>
_____
and respectful way!
Kind regards
Marius
Marius Lubbe
Creative MindsR HQ
Phone: 082 785 7763
_____
(978) 282-1349
_____
>Marius Lubbe wrote:
>Hi Guys,
>snip
>be valid if you constructed a whole boat of just glass and resin. We however
>a looking for the most durable, easiest to work and most affordable solution
>for a single thin skin, that will also not check, (I believe its because the
>resin is the thing that actually does the power thing, whereas the glass, or
>it some bulk all over a large area in a uniform kind of way. My thinking was
>stainless steel cloth would that not be a fantastic almost bullet-proof base
>cloth?
>thinking somewhat out of the box. Actually it started with the book Backyard
>of resin. They look like they can stand being fired from a cannon, but still
>is not too heavy!
>Hope this is not starting to bore you, but I think we should explore all the
>alternatives.
>Regards
>Marius
> fabric and epoxy weight can be very significant.
Amen! I overdid it on Dadink and it came out at 100 lbs instead of the 80
lbs it was supposed to. Glassing the inside was a mistake.
> I have the impression that glass cloth was used with
I think it was probably phenolic (which may be the same thing) and the
initial boards used paper, then linen, then fiberglass. I've got some
circuit components from the WW I era, and most steps in between. Anybody in
the market for a few dozen vacuum tube shields?
Yes, and it absorbs epoxy like a sponge! I like most of xynole's
properties, but unless you are very careful in wetting it out it will turn
into a heavy and expensive coating.
_____
Sent: Monday, June 28, 2004 9:27 PM
does not itch like glass. That alone makes it easier to work with.
Charles
(978) 282-1349
<http://us.ard.yahoo.com/SIG=1295ieeuo/M=296967.5106131.6227187.3294649/D=gr
oups/S=1705065791:HM/EXP=1088558856/A=2181364/R=2/id=noscript/SIG=1304ck1na/
:HM/A=2181364/rand=155618755>
_____
_____
>cotton
> 1. What is the reason for using a glass - based cloth?
> why not something that will accept proper impregnation like silk or
> or other natural fibre.You can use a polyester like Xynole. It is not a natural fiber but it
Charles
(978) 282-1349
_____
Hi Guys,
This has been very interesting; especially those replies that says we use
glass because its better......???
cloth?
is not too heavy!
alternatives.
Regards
Marius
_____
Sent: Monday, June 28, 2004 9:28 PM
Glass fibers are extremely strong, fairly elastic, and don't break down
easily. If the proper type is used (especially don't use mat), they wet
out just fine with epoxy. I'm sure "natural" fibers are MUCH weaker. I
have used very small amounts of glass cloth with nitrocellulose dope
with good results, but I'd guess this is weaker than epoxy. In my
experience, 1 oz. glass and epoxy are enough to prevent checking and are
very light when applied carefully..
Some people have reported successful use of flour. You want something
very fine and smooth, like white wheat flour. I'm guessing mechanical
properties are much worse than fumed silica, but maybe enough if the
fillet is glassed over.
(978) 282-1349
<http://us.ard.yahoo.com/SIG=129vre0il/M=296967.5106131.6227187.3294649/D=gr
oups/S=1705065791:HM/EXP=1088525542/A=2181364/R=2/id=noscript/SIG=1304ck1na/
:HM/A=2181364/rand=281067506>
_____
cloth?
is not too heavy!
alternatives.
Regards
Marius
_____
>Marius Lubbe - Creative MindsR HQBolger rules!!!
>Dear Friends,
>I am a novice in these things and therefore ask that you bear with me if my
>thoughts seem weird.
>why not something that will accept proper impregnation like silk or cotton
>2. In the same area of thought. can one use something like corn flour or
>some other plant flour as a thickening agent for epoxy fillets, if not why?
>Thanks
>Marius
(978) 282-1349
_____
>cotton
Charles
Sure, but glass is a fluid, and in a few thousand years, your hull shape
will be quite pear shaped.
> And glass would be unattractive to micro-organisms (e.g. bacteria,
> fungi), whereas certain kinds might like to eat plant material or
> silk. Glass is also more-or-less unaffected by most chemicals.
> Same possible problem with using wood flour to thicken epoxy, both
> chemical and biological. Limestone could be attacked by acids,
> possibly even mildly acidic rainwater/ Think of how limestone caves
> are formed.
> Howard
> > From: "Marius Lubbe - Creative MindsR HQ" <marius@c...>
> > Strength! Glass which is free of impurities and small fractures is
> one of
> > the strongest materials on earth. With fibers, the flaws have
> already
> > broken. The combination of incredibly strong glass fibers with the
> elastic
> > nature of the cured epoxy is what makes the result better than
> either
> > element alone.
> or cotton
> > Pretty weak stuff. Why add something that won't make the final
> product
> > better? Fiberglass cloth from an epoxy vendor is coated to promote
> the
> > bond.
> flour or
> if not
> > why?
> > Wood flour would seem to fall into this category, and it is my
> favorite
> > filler. Other fillers offer different characteristics; e.g. lime
> for a hard
> > coating, silica thickener for colorless coating, silicon carbide for
> > incredible hardness, ...
> > One purpose for a filler is to provide thixotropic properties.
> Unthickened
> > epoxy runs and runs and runs. (A model railroader cast a fine lake
> of
> > unthickened epoxy. The next morning, all of the epoxy was on the
> floor.
> > He'd left a pinhole in the lake bed.) Not all additives provide
> this.
> > Quoting from System Three's "The Epoxy Book:"
> > SECTION VI C
> > USING FILLERS WITH EPOXY RESIN
> > System Three epoxy properly mixed is intended for both coating and
> > fiberglassing. When used "right out of the jug", the mixture is
> said to be
> > "unfilled" and it is too thin to be used as a gap filling adhesive
> or for
> > fairing and filleting compounds. For these applications certain
> fillers are
> > added. These materials change the flow and density characteristics
> of the
> > epoxy system.
> > All fillers sold for use with System Three epoxy products are solid
> > materials, falling into four general classes: thixotropic agents,
> bulking
> > agents, fibrous fillers, and pigments. There is some overlapping as
> to
> > function of certain fillers. For example, plastic minifibers is
> both fibrous
> > and acts also as a thixotropic agent.
> > Silica thickener (Cab-O-Sil), plastic minifibers and wood flourare
> > thixotropic agents. They turn the epoxy into a thixotropic fluid.
> Most
> > people are not familiar with the term "thixotropic" though everyone
> is
> > familiar with the properties of these fluids. They flow under
> shear stress
> > but do not flow once the stress is removed. Ketchup and latex house
> paints
> > are thixotropic fluids. Adding these agents to the mixed resin and
> hardener
> > produces a fluid which will easily flow under the spreading stress
> of a
> > putty knife. Once the stress is removed the thickened epoxy retains
> shape.
> > In short, these fillers make the epoxy non-sagging, being added to
> restrict
> > drainage and make gap filling adhesives.
> > Phenolic microballoons, quartz microspheres, and wood flour are
> bulking
> > agents. They "bulk out" the epoxy making a lightweight putty like
> mix.
> > Although all these thicken the epoxy, only wood flour will make it
> > thixotropic. Attempting to add sufficient microballoons or
> microspheres to
> > make a non-sagging fairing putty will result in one that spreads
> poorly.
> > These materials should be used along with a thixotropic agent.
> Silica
> > thickener is the best choice because it produces the smoothest
> compound.
> > Chopped glass strands, milled glass fibers, and plastic minifibers
> are
> > fibrous materials that can be incorporated into structural
> filleting putties
> > to improve tensile strength, and are listed above in descending
> order of
> > tensile strength improvement.
> > Lots of good stuff in this free publication, and it applies to most
> epoxy
> > vendor's products.
> > Roger
(978) 282-1349
are formed.
Howard
are formed.
Howard
one of
already
elastic
either
> element alone.
or cotton
product
> bond.
flour or
if not
> why?
favorite
for a hard
Unthickened
floor.
this.
> SECTION VI C
said to be
or for
fillers are
of the
> epoxy system.
bulking
both fibrous
Most
is
shear stress
paints
hardener
of a
shape.
restrict
bulking
mix.
microspheres to
poorly.
Silica
compound.
are
filleting putties
order of
epoxy
> vendor's products.
> Roger
I'm not sure what your source is, but I don't believe this figure. I
just did a quick web search and got a figure of 200,000 psi. Then the
same site says it's several times that of steel. Not true. If you take a
piece of fine music wire, you can expect it to be stronger than that.
(Small Parts claims min. 220kpsi on their music wire). I recall Kevlar
and glass fibers are even stronger than that. And spider silk is very
stretchy, so the epoxy may fail first. THere are reasons we use glass
cloth on boats. (Kevlar, besides being expensive, is lousy in compression)
>snip Something like 200+ times(total guess i read this a
>while back) stronger than steel
>Glad to see biodegradable fishing line but kind of a scary way to go
>about it.
>Jason
>Dear Friends,
>Thanks
>Marius
Scott Calman
> They have put a spider gene in goats, so as the silk is produced inKind of brings a whole new meaning to belly button lint...8^0
> the goat's mammary glands. When the goat is milked the "silk"
> somehow precipitates into strands out of the milk.
Scott Calman
> They have put a spider gene in goats,..The cow idea was too close for comfort.
But, if they put it in a fish, maybe it could net itself!
I guess my first question would be why not use fiberglass cloth as it is a
proven effective product. Aside from the fact that fibers can be irritating
if used carelessly it works well in boat building. To get away from the
itch dynel fabric is an excellent but more expensive alternative. Strong,
reliable and no itch.
Grant in Vermont about two weeks away from launching my repro 1929 cabin
cruiser (I hope)
on 6/28/04 6:12 AM, Marius Lubbe - Creative MindsR HQ at
cruiser (I hope)
marius@...wrote:
> Dear Friends,
> Thanks
> Marius
> Marius Lubbe
> Creative MindsR HQ
> Phone: 082 785 7763
> www.minds.co.za
> (978) 282-1349
somehow precipitates into strands out of the milk. Folks are looking
at develping this stuff for biodegradible fishing line and as a
suture material. Something like 200+ times(total guess i read this a
about it.
Jason
about it.
Jason
> > Don't you need some kind of special tree to encourage/optimizedo
> silk worm
> > production?
> Mulberry bushes, IIRC from elementary school.
> There was an annoucement lately about artifical silk production. I
> forget if it was straight chemical or if, more likely, it had to
> with putting a silkworm gene in a spider (or some other, more
> tractable animal). I hope they don't put it in a cow!
> Peter
> Don't you need some kind of special tree to encourage/optimizesilk worm
> production?Mulberry bushes, IIRC from elementary school.
forget if it was straight chemical or if, more likely, it had to do
Silk does ring a bell, but I've no idea where to look further After pricing
vinyl for smoothing, I'm going to experiment further with Peel-Ply ... but
that's the approach we don't want for reinforcing..
Spider webs do well too, and here in Southern Indiana we have many, many,
very industrious spiders drifting around on their one strand parachutes.
You may be onto something here.
Don't you need some kind of special tree to encourage/optimize silk worm
production?
Roger (Dow-Corning doesn't have the only effective spinerets.)
production?
> > Strength!
> They do say that silk is very strong. However, the has to be a match
> between the tensile and compressive strength coefficients between
> the fiber and the resin. And I don't know if it would wet out
> properly, or if there is chemical compatibility.
> > 1. What is the reason for using a glass - based cloth?They do say that silk is very strong. However, the has to be a match
> Strength!
From: "Marius Lubbe - Creative MindsR HQ" <marius@...>
Strength! Glass which is free of impurities and small fractures is one of
the strongest materials on earth. With fibers, the flaws have already
broken. The combination of incredibly strong glass fibers with the elastic
nature of the cured epoxy is what makes the result better than either
element alone.
Pretty weak stuff. Why add something that won't make the final product
better? Fiberglass cloth from an epoxy vendor is coated to promote the
bond.
why?
Wood flour would seem to fall into this category, and it is my favorite
filler. Other fillers offer different characteristics; e.g. lime for a hard
One purpose for a filler is to provide thixotropic properties. Unthickened
epoxy runs and runs and runs. (A model railroader cast a fine lake of
unthickened epoxy. The next morning, all of the epoxy was on the floor.
He'd left a pinhole in the lake bed.) Not all additives provide this.
SECTION VI C
fiberglassing. When used "right out of the jug", the mixture is said to be
"unfilled" and it is too thin to be used as a gap filling adhesive or for
fairing and filleting compounds. For these applications certain fillers are
added. These materials change the flow and density characteristics of the
epoxy system.
materials, falling into four general classes: thixotropic agents, bulking
agents, fibrous fillers, and pigments. There is some overlapping as to
function of certain fillers. For example, plastic minifibers is both fibrous
thixotropic agents. They turn the epoxy into a thixotropic fluid. Most
people are not familiar with the term "thixotropic" though everyone is
familiar with the properties of these fluids. They flow under shear stress
but do not flow once the stress is removed. Ketchup and latex house paints
are thixotropic fluids. Adding these agents to the mixed resin and hardener
produces a fluid which will easily flow under the spreading stress of a
putty knife. Once the stress is removed the thickened epoxy retains shape.
In short, these fillers make the epoxy non-sagging, being added to restrict
Phenolic microballoons, quartz microspheres, and wood flour are bulking
agents. They "bulk out" the epoxy making a lightweight putty like mix.
thixotropic. Attempting to add sufficient microballoons or microspheres to
make a non-sagging fairing putty will result in one that spreads poorly.
These materials should be used along with a thixotropic agent. Silica
thickener is the best choice because it produces the smoothest compound.
Chopped glass strands, milled glass fibers, and plastic minifibers are
fibrous materials that can be incorporated into structural filleting putties
to improve tensile strength, and are listed above in descending order of
Lots of good stuff in this free publication, and it applies to most epoxy
vendor's products.
>1. What is the reason for using a glass - based cloth?Strength, I imagine. You could use any cloth. Burlap, for example.
Note that epoxy is heavier than the cloth, so you want something that will
fill with epoxy without soaking it up. Soaking the cloth only means more
weight and more $ spent for epoxy.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
>2. In the same area of thought. can one use something like corn flour orAny flour will work. Cornstarch, powdered limestone, wood flour.
Craig O'Donnell
Dear Friends,
Thanks
Marius
Marius Lubbe
Creative MindsR HQ
Phone: 082 785 7763
www.minds.co.za
Thanks
Marius
Marius Lubbe
Creative MindsR HQ
Phone: 082 785 7763
www.minds.co.za
