[bolger] Re: Stability/Knockdown Study Bolger Hulls -PRIVATE POSTINGS
The shape of the hull and self righting ability don't have
much effect on each other. As long as the center
of gravity/mass has a decent lever arm over the
center of flotation it is going to try to right it's self.
A bulb keep made of lead has a great deal more effect
than water ballast that is only a foot or so below the
center of flotation when knocked down.
While it is true that it make no difference if the ballast is
water, lead or feathers it does make a difference that
the more dense them material the greater the lever
arm from the center of flotation can be made. A piece
of railroad iron for a keel has a lot more righting moment
than the same weight of water inside the hull.
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
To: <bolger@egroups.com>
Sent: Wednesday, March 15, 2000 1:26 PM
Subject: [bolger] Re: Stability/Knockdown Study Bolger Hulls -PRIVATE
POSTINGS
> I can note from experience that the Micro will recover nicely from a 90
> degree knockdown.
> Gregg Carlson
> >The discussion of the ultimate stabilty of box-sectioned boats isn't
going
> to deter me from builidng one, though. My current project, building
> Michalak's IMB has been canceled. It was really too small for my needs.
> Instead, I've decided to go ahead and build a much more substantial
boat --
> Micro. I sent my order to PCB&F for plans on Monday. I do believe Micro to
> be a special case of the box-boat, though, becuase of the heavy external
> ballast. I doubt it has has a negative righting moment anywhere below 70
> degrees of heel. I hope I never find out first hand what 70 degrees of
heel
> feels like!
> DON'T HATE YOUR RATE!
> Get a NextCard Visa, in 30 seconds! Get rates as low as
> 0.0% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
>http://click.egroups.com/1/2120/5/_/3457/_/953148544/
