Re: [bolger] Re: Harbinger Questions for Hugo Tyson
Smooth hulls do look good, but many people on seeing Dad's Harbinger catboat "Dolly T" ask 'is the hull fibreglass?' whereby he has to tell them and explain that its wood. Some can't believe it as the finish is so smooth and fair. A clinker built hull on the other hand immediately in most people's mind can only be made out of wood, even though thats not entirely true as we all know!
Dennis <pseudodion@...> wrote:Hugo, the clinker ply construction on Spartina is probably the way
that I will go. As I mentioned, I'm playing around with the idea of
strip planking only and primarily because I saw a pic of a cold
molded Spartina and liked the looks of the smooth hull. I like the
smooth lines of the "Dolly T" as well. When it comes down to it, I'm
not one to stray too far from the plans, though since I am in the
fiddling rather than building stage at the moment, it is rather
interesting to play around with possibilities.
Dennis
Dennis
--- Inbolger@yahoogroups.com, Hugo Tyson <hhetyson@y...> wrote:
> Dennis,
> I have no idea about formulas to caculate weight ratios of glassed
wood composite hulls. Sorry I can be no help there.
> Why not the clinker ply for the spartina? Very stiff and strong for
weight, you could Fibreglass/dynel sheathe the bottom and first plank
for more durability without added much extra weight. Clinker ply
construction generally requires few if any ribs, just a few bulkheads
etc.
> Dennis <pseudodion@s...> wrote:
> Hugo, Thanks for the reply. I ask those questions about strip
> planking because I am playing around with the idea of strip
planking
> Spartina. This design requires 1/2" clinker ply topsides and the
> finished hull weighs in around 500lbs. I understand that strip
plank
> construction can make a boat lighter by as much as 25%, but in this
> case I am not interested in a lighter boat--nor would Bolger. Are
> you -- or anyone else here -- aware of any formulas that help
> determine weights of wood/glass composite that would enable me to
get
> an idea of the feasibility of going this route?
> Dennis
> > Dennis,
> > My father actually built the "Dolly T" and as far as I can
remember
> the dimensions of the planking and frames etc. would be exactly the
> same or so close to the ones specified by Bolger in the plans
> for "Harbinger" in the "Folding Schooner ..." Book by Bolger.
> > The strip planking was 13mm x 20mm Celery Top pine,(very
> good "hard" softwood.light but far stronger than cedar) so after
> fairing it would be 1/2" Thick.
> > She is fully sheathed on the deck and hull with dynel cloth set
> in epoxy resin as well as the hull being impregnated with epoxy
> before painting on the inside.Note that each plank was fitted as in
> carvel planking for a perfect seamless fit and edge nailed with
> silicon bronze anchorfast nails as well as epoxy glue. My father
has
> never used the tongue and groove method of strip planking, though
it
> would work perfectly well on a hull like a "Harbinger" catboat.
Hulls
> with extreme shapes such as plunb stens, lots of flare and hard
> bilges require steaming of the planks, even with the strip-planked
> method.
> > The weight(Not really sure, maybe 800lbs fully fitted out, but
I'm
> only guessing) should be about the same as the original. The ribs
are
> laminated and while providing extra strength are not really needed
in
> a strip planked, dynel sheathed hull of this size. The number of
ribs
> was reduced by about 1/4 - 1/3 I think, by respacing their centres.
> They were put in mainly for looks, to keep up the traditional
> appearance.
> > She may weigh fractionally more than the original, but no more
> than 30lbs or so, and due to the dynel/epoxy sheathed hull, she
won't
> gain weight with age as a carvel boat will by soaking up some
water.
> > Anyhow Bolger says that up to 500 lbs of ballast can be added,
> but this will make for a slower boat, albeit a bit more stable. and
> a "sinker" if swamped.
> > We'll be putting her on the trailer this coming weekend with a
bit
> of luck, so weather depending ( It is winter here after all and
we've
> been having an awful lot of rain this year ) we might get to raise
> the sail, so hopefully I'll be able to post some more photos of her
> next week, most likely the new photos will have to go into the
> Bolger4 Photos group in the files section.
> > Hugo Tyson, Launceston, Tasmania. Australia.
> > Hugo, I've been admiring the "Dolly T" and have a few questions.
> > First, what were the original scantlings for the planking?
Second,
> > what size strip planking did you use and how did you decide on
> > size? Third, do you have any idea what the boat weighs? Is it
> lighter
> > or heavier than the plan specs? Finally, when do we get to see
pics
> > of her sailing? Thanks, Dennis.
> posts
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> 01930, Fax: (978) 282-1349
> > Yahoo! Groups SponsorADVERTISEMENT
> > var lrec_target="_top";var lrec_URL = new Array();lrec_URL[1]
= "http://us.ard.yahoo.com/SIG=129qf0ghe/M=296967.5106131.6227187.3294
649/D=groups/S=1705065791:HM/EXP=1089118728/A=2196952/R=0/id=flashurl/
> SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?
> redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002 ";var
> link="javascript:LRECopenWindow(1)";var lrec_flashfile
= 'http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_1.swf
> ?clickTAG='+link+'';var lrec_altURL
649/D=groups/S=1705065791:HM/EXP=1089118728/A=2196952/R=1/id=altimgurl
> /SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?
> lrec_altimg
= "http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_320x250_0
> 61504.jpg";var lrec_width = 300;var lrec_height = 250;
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> >http://groups.yahoo.com/group/bolger/
> > To unsubscribe from this group, send an email to:
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> > Find local movie times and trailers on Yahoo! Movies.
posts
= "http://us.ard.yahoo.com/SIG=129kc16go/M=296967.5106131.6227187.3294
649/D=groups/S=1705065791:HM/EXP=1089123553/A=2196952/R=0/id=flashurl/
649/D=groups/S=1705065791:HM/EXP=1089123553/A=2196952/R=1/id=altimgurl
lrec_altimg
Service.
var lrec_target="_top";var lrec_URL = new Array();lrec_URL[1] = "http://us.ard.yahoo.com/SIG=129g0crko/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089125476/A=2181364/R=0/id=flashurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";varlink="javascript:LRECopenWindow(1)";var lrec_flashfile = 'http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_263_060804.swf?clickTAG='+link+'';varlrec_altURL = "http://us.ard.yahoo.com/SIG=129g0crko/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089125476/A=2181364/R=1/id=altimgurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";varlrec_altimg = "http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_300x250_060804.jpg";varlrec_width = 300;var lrec_height = 250;
Dennis
Dennis
> Dennis,
etc.
planking
plank
get
> Dennis
> > Dennis,
remember
has
it
Hulls
> method.
I'm
are
in
ribs
> appearance.
won't
water.
bit
we've
Second,
> lighter
pics
> posts
> lrec_altimg
> > Yahoo! Groups Links
> Service.
posts
lrec_altimg
Service.
Dennis,
I have no idea about formulas to caculate weight ratios of glassed wood composite hulls. Sorry I can be no help there.
Why not the clinker ply for the spartina? Very stiff and strong for weight, you could Fibreglass/dynel sheathe the bottom and first plank for more durability without added much extra weight. Clinker ply construction generally requires few if any ribs, just a few bulkheads etc.
planking because I am playing around with the idea of strip planking
finished hull weighs in around 500lbs. I understand that strip plank
determine weights of wood/glass composite that would enable me to get
Dennis
Dennis
> Dennis,
> My father actually built the "Dolly T" and as far as I can remember
silicon bronze anchorfast nails as well as epoxy glue. My father has
never used the tongue and groove method of strip planking, though it
would work perfectly well on a hull like a "Harbinger" catboat. Hulls
method.
> The weight(Not really sure, maybe 800lbs fully fitted out, but I'm
only guessing) should be about the same as the original. The ribs are
laminated and while providing extra strength are not really needed in
a strip planked, dynel sheathed hull of this size. The number of ribs
appearance.
than 30lbs or so, and due to the dynel/epoxy sheathed hull, she won't
gain weight with age as a carvel boat will by soaking up some water.
> We'll be putting her on the trailer this coming weekend with a bit
of luck, so weather depending ( It is winter here after all and we've
> First, what were the original scantlings for the planking? Second,
> what size strip planking did you use and how did you decide on the
lighter
> or heavier than the plan specs? Finally, when do we get to see pics
posts
lrec_altimg
Service.
var lrec_target="_top";var lrec_URL = new Array();lrec_URL[1] = "http://us.ard.yahoo.com/SIG=129kc16go/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089123553/A=2196952/R=0/id=flashurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";var link="javascript:LRECopenWindow(1)";var lrec_flashfile = 'http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_1.swf?clickTAG='+link+'';varlrec_altURL = "http://us.ard.yahoo.com/SIG=129kc16go/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089123553/A=2196952/R=1/id=altimgurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";var lrec_altimg = "http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_320x250_061504.jpg";varlrec_width = 300;var lrec_height = 250;
Dennis
Dennis
> Dennis,
method.
appearance.
lighter
posts
lrec_altimg
Service.
Dennis,
My father actually built the "Dolly T" and as far as I can remember the dimensions of the planking and frames etc. would be exactly the same or so close to the ones specified by Bolger in the plans for "Harbinger" in the "Folding Schooner ..." Book by Bolger.
The strip planking was 13mm x 20mm Celery Top pine,(very good "hard" softwood.light but far stronger than cedar) so after fairing it would be 1/2" Thick.
She is fully sheathed on the deck and hull with dynel cloth set in epoxy resin as well as the hull being impregnated with epoxy before painting on the inside.Note that each plank was fitted as in carvel planking for a perfect seamless fit and edge nailed with silicon bronze anchorfast nails as well as epoxy glue. My father has never used the tongue and groove method of strip planking, though it would work perfectly well on a hull like a "Harbinger" catboat. Hulls with extreme shapes such as plunb stens, lots of flare and hard bilges require steaming of the planks, even with the strip-planked method.
The weight(Not really sure, maybe 800lbs fully fitted out, but I'm only guessing) should be about the same as the original. The ribs are laminated and while providing extra strength are not really needed in a strip planked, dynel sheathed hull of this size. The number of ribs was reduced by about 1/4 - 1/3 I think, by respacing their centres. They were put in mainly for looks, to keep up the traditional appearance.
She may weigh fractionally more than the original, but no more than 30lbs or so, and due to the dynel/epoxy sheathed hull, she won't gain weight with age as a carvel boat will by soaking up some water.
Anyhow Bolger says that up to 500 lbs of ballast can be added, but this will make for a slower boat, albeit a bit more stable. and a "sinker" if swamped.
We'll be putting her on the trailer this coming weekend with a bit of luck, so weather depending ( It is winter here after all and we've been having an awful lot of rain this year ) we might get to raise the sail, so hopefully I'll be able to post some more photos of her next week, most likely the new photos will have to go into the Bolger4 Photos group in the files section.
size? Third, do you have any idea what the boat weighs? Is it lighter
var lrec_target="_top";var lrec_URL = new Array();lrec_URL[1] = "http://us.ard.yahoo.com/SIG=129qf0ghe/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089118728/A=2196952/R=0/id=flashurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";var link="javascript:LRECopenWindow(1)";var lrec_flashfile = 'http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_1.swf?clickTAG='+link+'';varlrec_altURL = "http://us.ard.yahoo.com/SIG=129qf0ghe/M=296967.5106131.6227187.3294649/D=groups/S=1705065791:HM/EXP=1089118728/A=2196952/R=1/id=altimgurl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002";var lrec_altimg = "http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_320x250_061504.jpg";varlrec_width = 300;var lrec_height = 250;
