Re: [bolger] Re: Chebacco progress
The hatches came off ebay. Mike Rogers (ironman@...) "recycles"
boat stuff and has some of the inventory from a factory that went bust. I
bid on and won a small one, then e-mailed him to see if he had its twin for
the other side. No, but he had two about 12 x 24 which are perfect. Yes,
the latches fold flat after you twist/cam the lid down. Quite elegant with
rubber gaskets inside. $100 USD for the pair including shipping..
I built the hatch cover for Dadink and it was a real pain. (
http://derbyrm.mystarband.net/Dink.htmlnear the bottom center -- on the
fore deck) Wood isn't a "stable" material, so of course it sticks every
time its closed. (maybe that's the lousy paint I used, but it's been six
years) Besides, these hatches are pretty much flush which I like for this
application.
A lot of the inside of these compartments will be filled with pink foam
board for flotation, but one does need access to the motor mount bolts.
I figure to build the seat-hatches (inside the cockpit) since they don't
need to be so water tight.
The modular approach came partly from watching GD build F-16s in Fort Worth.
Build pieces, then stick them together. It really does reduce the number of
"bend-overs." Also, when I'm glassing a surface, I can make it horizontal
to reduce runs. On the Ohio River, a motor boat wake might flood the after
decks, but it's not likely to fill the cockpit.
Roger (I'm NOT racing and "done" is a very subjective state.)
> Hmmmmmmmmm! Different strokes, different folks. Interesting
> approach Roger. The hatches look like you cut them off an ice chest.
> Where did they come from, do the latches fold down, and is there a
> good gasketing to the seat? I've been thinking of a chunk of
> plywood, a piano hinge, several deadbolt like latches that force the
> plywood down snug onto a rubber gasket....
> Since I started my Chebacco (the sheet plywood version) way back when
> (like in '00 or '01 -- a true oldtimer and meandering slow poke), and
> am at the point of almost roofing the cuddy, I'd say we're in a race
> to the finish...if you handicap me with a year or two.
> Dick
Dick
> A few pieces are going together.
http://derbyrm.mystarband.net/Dayawl.html
> (No, the hatches won't be secured until much, much later.
> Roger
> derbyrm@s...
A few pieces are going together.http://derbyrm.mystarband.net/Dayawl.html
