Re: epoxy and finishing
i have done this many times in my 30 years of working on boats.
what is important is the chemistry of the products not the brandname.
easypoxy is a THIN non epoxy paint formulated to put a high shine on a fiberglass hull. same with the interlux one part, this is not epoxy either.
If you are getting amine blush you are doing something wrong. most likely
epoxying late in the day as blush is caused by high humidity mostly.
the coating is degraded if you get it. sometimes old resin that has picked up mosture from the air will do it. the term epoxy in paints has the same meaning as turbo in electronics. hard to find true epoxy paint as it has a mek base. tough as nails but chalks easy. email me off list if you want specifics.
mike
>Have you actually tried this? it sounds great but I've had trouble in
>other areas when mixing different brand names of supposedly
>compatible products. I've always waited until 9-10 summer days have
.passed and the most of the amine has bled out before painting with
.alkild paints such as Pettit Easypoxy or Interlux one part epoxy.
Just Curious.
Don
--- Inbolger@yahoogroups.com, <mkriley@f...> wrote:
> use a good 2 part epoxy primer and it can be put on as soon as the
epoxy gets hard enough to paint. It bonds through chemical action and
need no sanding as long as it is done before the final cure. It
becomes part of the structure not just a coating. you are always
better of staying with the same chemistry in the paint as the
substrate. awlgrip 545 make a ex. epoxy primer amd rustolium make a
good industrial 2 part primer.
> if applied with a foam roller and proper thinning it can leave a
nice stippled fimish that will hide a multitude of sins.
> mike
use a good 2 part epoxy primer and it can be put on as soon as the epoxy gets hard enough to paint. It bonds through chemical action and need no sanding as long as it is done before the final cure. It becomes part of the structure not just a coating. you are always better of staying with the same chemistry in the paint as the substrate. awlgrip 545 make a ex. epoxy primer amd rustolium make a good industrial 2 part primer.
if applied with a foam roller and proper thinning it can leave a nice stippled fimish that will hide a multitude of sins.
mike
