Re: [OT] Glassing Suggestions
I don't know about how much plywood you should use, but consider the
weight of a glassed-plywood camper and the height of that weight. I
suspect it may make your pickup feel somewhat less stable than it was
with the plywood laying in the bed on the trip home from the lumber
store. It seems like 1/4" would suffice for the sides, especially
with glass over it.
There are reasons why aluminum skin is used on commercial campers;
primarily cost and weight.
-Jerry
with glass over it.
-Jerry
--- Inbolger@yahoogroups.com, "Ken" <renueden@e...> wrote:
> On my way to boat building, I've made a long detour into building a
> cabover truck camper. I have decided to sheet ply and glass the
> exterior instead of using aluminum or other siding.
> I'm looking for suggestions on the following:
> -What thickness ply for the exterior? (I've been feeling 3/8" for
> sides and ½" for the roof so I can walk on it.)
> -Should I tape the ply where the sheets butt together, or is the
cloth
> itself enough protection? (I'll be covering the entire exterior with
> cloth).
> -What weight cloth and tape should I use? I'm thinking of using a
> second layer of tape on the seams like roof to sides etc.
> Thanks for any suggestions,
> Ken
On my way to boat building, Ive made a long detour into building a
Im looking for suggestions on the following:
-What thickness ply for the exterior? (Ive been feeling 3/8 for the
sides and ½ for the roof so I can walk on it.)
-Should I tape the ply where the sheets butt together, or is the cloth
itself enough protection? (Ill be covering the entire exterior with
cloth).
-What weight cloth and tape should I use? Im thinking of using a
Ken
cloth).
Ken
