Re: MDO - The Good, The Bad, and The Ugly?
--- Inbolger@yahoogroups.com, "William_Benham"
<william_benham@y...> wrote:
> Hi List,
> I picked up some MDO from a local wholesaler for a boat building
> project I'm getting ready for (an instant boat style cat-yawl scow
by
> Conrad Natzio). The only unprimed MDO in 3/8" they had on hand
was
> Olympic Guardian, with the overlay on a single side. The overlay
> side looks good, but the back is C grade with bunches of knots
(some
> open/missing), splits, etc. I'm thinking that I'll probably have
> fill all the holes and the put a layer of 4 oz. glass and epoxy on
it
> to make it look halfway decent. The condition of the back veneer
> sorta makes me worry about voids in the core, although the edges
look
> good void wise.
> So, did I buy the wrong stuff? If so, what should I have been
> looking for?
> Is there something else I can do to make that C face look better,
> other than glass it? The reason I wanted to try the MDO was so I
> could get a good finish without having to resort to epoxy and
glass.
> I'd appreciate any feedback.
> Thanks,
> Bill
Not all MDO is created equal:
"Guardian" is Olympic's bottom-of-the-line MDO;
"Two-step," which I believe used to be called
"Crezon," is the next step up- the improvements
being mainly in that the faces recieve extra
sanding. The cores of these two are about the same.
"Signal" is the best, with better veneers/cores,
but Signal is only available down to 1/2", I
believe, while Guardian and Two-Step are availble
down to 5/16"
All of the above are made "single-sided" and also
"two-sided," but don't hold your breath while
looking for a lumber yard that stocks the thin
sheets in double-sided.
Interestingly, Olympic's web site specifically
mentions that Guardian has been used for "boat hulls."
Back before Olympic bought them out, predecessor
Simpson used to advertise that Crezon (Two-step) was
sometimes used for "boat hulls."
Max
Well, what you bought doesn't gybe with my experience. About five years ago
I bought several sheets of 1/2" and 3/4", paying about $46 USD per 1/2"
sheet, and I was delighted with the stuff. It was about half the price of
BS1088 Okume and it was fine, double-sided material.
As I understand it, fiberglass is to make the epoxy better stand up to
abuse. If the C side isn't going to see high traffic, simple filling with
thickened epoxy might do. Then again, is the core fir? If so, the glass
might be needed to prevent checking.
> project I'm getting ready for (an instant boat style cat-yawl scow by
> Conrad Natzio). The only unprimed MDO in 3/8" they had on hand was
> side looks good, but the back is C grade with bunches of knots (some
> open/missing), splits, etc. I'm thinking that I'll probably have to
> fill all the holes and the put a layer of 4 oz. glass and epoxy on it
> sorta makes me worry about voids in the core, although the edges look
> good void wise.
> looking for?
> could get a good finish without having to resort to epoxy and glass.
I used the two sided olympic 3/8" MDO on my micro and i saw nary a
void while cutting. Good cores throughout. However i did have three
spots where the overlay was slightly bubbled (delaminating?). I
worked around two of them and the third didn't get noticed untill it
was the rear port quarter of the hull.....this really pissed me off
and i swear next time it will be marine fir and okumme all around.
Long story short i ground out a 12" diameter spot.....good bit
larger than the problem area. That face under there was hideous and
knotty but solid. I then laid dynel in the hollow then coated with
micro ballons, looks good now but it may show through the paint.
Jason
My local lumberyard (not a chain) carries 2 sided MDO which is
pretty nice stuff. Also amazingly void free.
Steve H
> Hi List,
by
was
(some
it
look
> good void wise.
> looking for?
glass.
> Thanks,
> Bill
Bill,
I've used that stuff for a bottom and, yes, the C side looks scary; I filled
the open knots with thickened epoxy (this was the exterior face) and glassed
over it with xynole and epoxy. So far, it's been bulletproof. I never
found a void in any of the cuts I made.
_____
Sent: Friday, July 16, 2004 4:32 PM
Subject: [bolger] MDO - The Good, The Bad, and The Ugly?
Hi List,
good void wise.
looking for?
Bill
(978) 282-1349
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=129h5d26a/M=296967.5172439.6288214.3294649/D=gr
oups/S=1705065791:HM/EXP=1090096305/A=2196952/R=2/id=noscript/SIG=1304ck1na/
*http://www.sodaclubusa.com/referrer.asp?redirect=rv_boat_camp.asp&referrer=
0002_0015_0178_0002>
<http://us.adserver.yahoo.com/l?M=296967.5172439.6288214.3294649/D=groups/S=
:HM/A=2196952/rand=100108491>
_____
Hi List,
good void wise.
looking for?
Bill
