Re: got my navigator sail plan/ tabernacle/ modification sheet today!
Jason, the link shows up fine on my pc, but when I get there it says
page not available. I think a password must be required to enter.
As far as I'm concerned, just rang my mooring guy, who dragged the
bottom to find where he had stored it last week....and not there! He
is having another look this afternoon after I told him my wife would
kill me because Oink is in front of her garage forever.
Maybe I will get into the water before you guys yet,
DonB
DonB
DonB
DonB
> Try this:http://www.ofoto.com/BrowsePhotos.jspUcollid=993802791105&Uphotoid=24
> 2832274105&collid=993802791105if
> to get to the photos you may have to cut and paste it into your
> navigation bar as it is to long to show up as a link. Let me know
> it doesn't work.
> I'm a bit ahead of this point now.
> Jason
Jason, this must be an off-wind sail only...a sort of reacher.
Thanks for the link.
DonB
DonB
> --- Inbolger@yahoogroups.com, "dbaldnz" <oink@w...> wrote:staysail.
> > Does he mean the jib to be used to windward?
> > I cant get into your webphotos with no code,
> > DonB
> I have no idea Don. I learned how to sail in sturdy cat, simple
> dingies and my dad's stonehorse...club footed self tending
> and a 90% roller reefer that you really didn't have to tend to asit
> swung when you tacked.in
> Best i can explain is that the sail we are talking about has a club
> with a jaw on one end that bites the main mast down low the other
> held to the forward sail tack. The it's about 8 ft long. The footof
> the jib is about 9 foot the leech 14'6" and the luff 16'.http://www.ofoto.com/BrowsePhotos.jspUcollid=993802791105&Uphotoid=24
> Since the club intersects the foot and the foot extends 12" or so
> behind the mast at the foot. Has one sheet not two like the jibs
> i've used I don't see how you can tack with this arrangement.
> I hope that makes sense. As i am a dummy i have no idea with
> something like this, that's why i'm building a box that i thought
> had one sail to contend with.
> Try this:
> it doesn't work.
> Jason
dingies and my dad's stonehorse...club footed self tending staysail.
and a 90% roller reefer that you really didn't have to tend to as it
with a jaw on one end that bites the main mast down low the other in
held to the forward sail tack. The it's about 8 ft long. The foot of
Try this:
navigation bar as it is to long to show up as a link. Let me know if
it doesn't work.
Jason
> Does he mean the jib to be used to windward?I have no idea Don. I learned how to sail in sturdy cat, simple
> DonB
Try this:
it doesn't work.
Jason
DonB
DonB
>is
> > If the battened mizzen is larger than the triangular mizzen
> > the jib might be necessary for 'balance'.
> That's one of the questions i've got for PCB&F. From what Bolger
> told me he increased the mizzen to keep the balance of moving the
> main mast forward......micro is 16'1" now. The 65 square feet jib
> roughly twice the size of the mizzen and it is 98% forward of the
> mast and the club jin pole thingy is about 8 foot forward of the
> mast. Seems to me it could only be managed downwind. I really don't
> want to fly a jib/flat spiniker if i can avoid it, i'm not in that
> big of a hurry. Micro loses a bit of simplicity piece by piece.
> Jason
Jason
> What are the dimensions of the new main sail?Same as the old one.
Jason
> If the battened mizzen is larger than the triangular mizzenThat's one of the questions i've got for PCB&F. From what Bolger
main mast forward......micro is 16'1" now. The 65 square feet jib is
Jason
> I really like...the battened mizzen< (I may pass on the jib)
Well i decided against the forward companionway as the surgery is'nt
worth the benifits to me. I'm lanky enough to easily throw myself
out the hatch and into the well to deploy anchor/bow lines.....roomy
up there now with no mast step/partner.
I took the sawzaw to the bow transom tonight after work and already
started piecing together the tabernacle parts......going to have to
order another sheet of ply for the aft tabernacle partner/bracing.
DOH! lot's of parts but looks to be an easy job.
I really like the looks of the new rig the battened mizzen is a
sharp match. Also i think that "jib" is what folks call a flat cut
spiniker? May pass on that for a while as i'm pretty lazy when it
comes to sailing. I'm going to contact PCB&F with a couple of
questions about the anti-kerphlumper not sure from the drawing how
far aft it extends but all the talk about slapping at anchor has me
sold on trying it.
Jason
sold on trying it.
Jason
> Ok-me!
> here goes the run down.
> The sail plan: 35 square foot fully battened chinese gaff mizzen,
> the boomkin now runs on deck and foots into the back of the pilot
> house. Main sail is the same 176 sqft. with a different mainsheet
> arrangement, traveler on cabin top and the vanging is a bit
> different......more lines.....doh! Jib! I two sails is enough for
> 65 square foot loose footed on a 8' sprit(?)gin pole(?) spinikerpole
> (?)like thing jawed onto mast. That's alot of sail.transom
> Look in the files section for the fiji sail plan........same thing
> but smaller.
> Tabernacle: Still digesting this thing, there is, some serious bow
> transom hacking to be done. Tabernacle sides riun up fron of
> shaped to the sides of the boat the hinged drop down lockstaff ison
> a lanyard like LMicro but rounded and flush to tabernacleuprights,
> so now it's a pointy bow.....or at least 4" round up there. Mastvia
> strikes down ontop of pilot house and is now 19' 6" long.
> Bow well and bulkhead #1: I've go some work to do if i follow the
> new plan, because this is all completed. Forward deck extends on
> crown to cover the front side floatation chambers. There is now a
> false floor in the well that can be accessed and used as stowage
> hole in #1 bulkhead. Well now drains through side instead ofbottom
> like LM. Front hatch moved forward a hair to now seal a drop boardbetween
> for the new forward compainionway(big hole up there) to alllow
> access to forward well. Ventilator is gone of course. Oh, yeah the
> keel is etended to the very tip.
> Interior:
> The vaugeness is lessened. There is a drawing of the bulhead
> bunks and front dressor's that extends from sole tokerphlumper!
> roof.....replaces the beams the three of us have built to
> date......also a bookshelf in the bulkhead.
> Below the water line:
> Rudder is longer with 8" endplate now. Finally the anti
> Kinda vauge on the drawing i'll have to go poke around my bow tointo
> clairify this thing but it appears to be 2 pieces of ply fillet
> place running from stem to just below water line and attached toif
> chines runs to somewher aft of station 14.......pretty much micro
> has a "V" entry now when runny or lying flat.
> There are some more details to discover but i've got a deadline to
> meet so i've hidden the plans from myself. I can answer questions
> there are any. I could post some low res scans if i get aconsenses
> that it's ok to do so. The 2 new sheets are part of the stock planme.
> set in Mass.....you order the navigator sheet (old nav sheet has
> been replaced by new sail plan and bulkhead sheet and the second
> sheet is for the tabernacle) and you get them.
> The tabernacle and sails will be changed on my boat as well as the
> rigging. The new bulkhead.....nahh requires too much surgery for
> The new companionway i have to think about. I've already finished
> out all that stuff and spent alot of time laminating that strip
> hatch.....gut feeling is that i'll do it just for ease of anchor
> handling and access and the likes.
> Jason
Ok-
different......more lines.....doh! Jib! I two sails is enough for me!
65 square foot loose footed on a 8' sprit(?)gin pole(?) spiniker pole
but smaller.
transom hacking to be done. Tabernacle sides riun up fron of transom
shaped to the sides of the boat the hinged drop down lockstaff is on
a lanyard like LMicro but rounded and flush to tabernacle uprights,
false floor in the well that can be accessed and used as stowage via
hole in #1 bulkhead. Well now drains through side instead of bottom
Interior:
The vaugeness is lessened. There is a drawing of the bulhead between
Rudder is longer with 8" endplate now. Finally the anti kerphlumper!
clairify this thing but it appears to be 2 pieces of ply fillet into
meet so i've hidden the plans from myself. I can answer questions if
there are any. I could post some low res scans if i get a consenses
rigging. The new bulkhead.....nahh requires too much surgery for me.
Jason
but smaller.
Interior:
Jason
