Re: [bolger] Re: June Bug stuff
I built an Elegant Punt with BC Pine. Although the sheets did not lay
flat, they were fine once they were part of the boat assembly. No
checking, however, the boat is less than a year old and is stored
inside. Also, as noted previously, it is very heavy. I have not
weighed the punt, but it is significantly heavier than my Michalak Toto
built of a similiar amount of Luaan ply.
Bill
I agree that the BC pine looks better than a lot of fir. The BC 1/4 " sheeets I've seen around here are all warped; the 1/2 " seems to lie flat. Has anyone built a boat out of BC pine ply? How did it turn out? Any experience with checking?
John T
Sent: Tuesday, August 10, 2004 9:37 AM
Subject: [bolger] Re: June Bug stuff
--- Inbolger@yahoogroups.com, "maddogg9000" <maddogg9000@y...> wrote:
> I just got all my June bug stuff.
> 1 1/2 qts Rake epoxy
> 36ft 4in 9 ounce fiberglass tape
> two 6" cleats
> one 2"cleat
> 1/2in Gudgeons and Pintles
> 1 gal clear wood seal
> 2qts prime
> 2qts burgandy paint
> 2qts cream paint
> 56 ounces of PL Premium
> three 16ft fir 2x4s
> now all I need is the 4 sheets of 1/4in ply. My lumberyard has AC
> exterior for $36 a sheet.
> they have BC exterior for $19 a sheet. they said its just as good as
> AC. one side is excellent. the other side isnt as good, but ok.
> could I use the BC and just finish the not-so-good side extra?
> ive already spent $280 and i really am a little on the broke side so
> im leaning towards the BC, but if its not useable, I guess ill go
> with the AC.
I think BC yellow pine plywood is an excellent choice. I would use it
over Fir AC. The AC I have seen has been full of voids with a very
bad C surface. Most yellow pine BC has very few voids and a much
better C side. It also is harder and more durable. The only drawback
is that it weights about 30% to 50% more. This is due to the fact
that yellow pine is more dense along with the fact that it has fewer
voids and is slightly thicker. I know many people who use BC. BC ply
in many parts of the country has replaced AC Fir due to its superior
quality.
Just my two cents.
Yahoo! Groups Sponsor
> two 6" cleats
> one 2"cleat
> 2qts prime
> 2qts burgandy paint
> 2qts cream paint
> three 16ft fir 2x4s
> with the AC.
quality.
Just my two cents.
--- > now all I need is the 4 sheets of 1/4in ply. My lumberyard has
AC
as
so
> with the AC. Go the AC as the outside of the hullneeds to be good.
My JB is in AC and was left to rot. wherever water got into a knot
we had to do repairs, but all the knots are on the inside so can be
hidden. we bog and paint the outside every 2 years now. The bottom is
AC but was coated in epoxy. After this boat dies I intend to cut the
perfect bottom off and build something else out of it.
cheers Paul
as
It seems whichever one you use you still end up with a 'not-so-good'
C side.Most of the time in AC ply , it seems the A side veneer is
real thin but in BC they are all the same thickness.Maybe I'm wrong
here but it also seems most of the time AC is fir and BC is pine.The
quality of ply varies from manufacturer to man. and also batch to
batch.A good way to tell how many voids to expect is to look at the
voids in the edges of the whole pile,if the pile they're selling at
the moment looks crappy but the one "in storage" above looks good,
come back in a day or two when they're selling that pile.Look around
in different stores,one place's BC might be better than another's AC.
>with the AC.
I know the feeling well. There's more to life than boats, and higher priorities too.
I'd like, if I may, to share my experience of building and using a June Bug for 4 years. I used 1/4" lauan ply and Weldwood-type glue. The fir bits were pretty poor wood and rather undersized in section.
The recurring problem I had with it was failure of the joints between the fir and the ply - probably because of the Weldwood glue - This occurred along the gun'ls, and where the thwart-frame joins the bottom. I also boxed in the ends and suffered with leaks when the box ends parted company with the bottom. Similarly the ply butt joint on the bottom gave out eventually.
Maybe the Weldwood was a bit old - but it seemed to mix OK and held up for a while. Also, with the undersized fir, flexing was pretty excessive and gluing surfaces not as big as they should have been.
The ply, despite being dirt cheap and painted (no epoxy coat), lasted just fine.
Anyway, despite these cautionary words, I'd like to sing the praises of the design - light, fast, burdensome, stable and great under oars.
Build it strong, and it'll last you a lot longer than 4 years!
Bill Samson
Plywood isn't all the same, one manufacturers BC might be as good as another
ones AC, no way to tell without seeing, look for voids and patches which
will show through your paint job unless you glass it.
Shame to do all that work and then decide you should have bought the best
you could afford.
Grant, going to launch my boat tomorrow at 6:30 AM
> two 6" cleats
> one 2"cleat
> 2qts prime
> 2qts burgandy paint
> 2qts cream paint
> three 16ft fir 2x4s
> with the AC.
> (978) 282-1349
two 6" cleats
one 2"cleat
2qts prime
2qts burgandy paint
2qts cream paint
three 16ft fir 2x4s
with the AC.
