Re: 'June Bug' stuff - sheet goods
If there needs to be a delay, make the mast, boom, oars, etc. They don't
take up much room or much material. And if you change your mind you can
use the same rig on a bunch of other boats also designed for it.
You can build Gav Atkin's 8' Mouse with 1 1/2 sheets lauan underlay,
some scrap lumber pieces, Pl Premium and drywall tape for about the
price of 2 sheets of this 1/4" stuff. Get some Walmart paint, throw
together a paddle (say $10.00) and hit the water. You'll have
something fun to use, developed some excellent building skills, have
a hands-on understanding of taped boats and get lots of positive
comments from other boaters. Takes about 12-24 hrs to build, basic
skills only required and easy to store.
--- Inbolger@yahoogroups.com, "Ron Magen" <quohog@a...> wrote:
> Hey, 'dog . . .
> A couple of points -
> 1}All the 'stuff' you have collected has a VERY LONG 'shelf life' -
> especially if stored in a cool place, away from direct sunlight.
> 2}Even with the soaring prices of sheet goods, $36.oo seems a bit
steep
> for ordinary 1/4 ACX. At that price I would investigate MDO {Single
> side}. This would be a better, more uniform material - at the same,
or
> less, cost per sheet.
> 3} Since you are 'in' for almost $300 already - don't waste what
you've
> already invested. 'Worse Case Scenario' is to wait {and dream, make
> sketches, practice your building technique with small samples, etc}
> while you save a bit more cash for the 'proper' hull material.
> Regards & Good Luck,
> Ron Magen
> Backyard Boatshop
> {PS - If you have GOT to build - and I do know the feeling - make a
> small model from 1/8 inch Masonite {or Whiteboard}. If that still
won't
> do . . . many boats have been made from 1/4 inch Lauan {$10 to $15 a
> sheet underlayment}}
> > Date: Mon, 09 Aug 2004 17:28:16 -0000
> > From: "maddogg9000" <maddogg9000@y...>
> > Subject: June Bug stuff
> > I just got all my June bug stuff.
> > 1 1/2 qts Rake epoxy
> Snipping of 10 line items, plus text
> > now all I need is the 4 sheets of 1/4in ply. My lumberyard has AC
> > exterior for $36 a sheet.
> > ive already spent $280 and i really am a little on the broke
side . .
Hey, 'dog . . .
2}Even with the soaring prices of sheet goods, $36.oo seems a bit steep
side}. This would be a better, more uniform material - at the same, or
3} Since you are 'in' for almost $300 already - don't waste what you've
Ron Magen
Backyard Boatshop
small model from 1/8 inch Masonite {or Whiteboard}. If that still won't
> From: "maddogg9000" <maddogg9000@...>
> ive already spent $280 and i really am a little on the broke side . .
