Re: Micro Mast Question
Ahhhh
the end cap is a great idea. I put a few thick coats of laquer, but I
think next time I'm in lowes I'll pick up a cap...
Mucha Gracias,
A2
Mucha Gracias,
A2
> --- Inbolger@yahoogroups.com, "Aaron Arguien" <aaronthekid@y...>
> wrote:
> > Here's how I did mine..
>http://f4.grp.yahoofs.com/v1/cKksQUJynMvnRAF46wxYIuVuzfwqzk_o04DMqsHW_
> 2pog3R5DWSVBS-yBnIdrn23fsVRmGMHaBnbUG5wFdRaHusIoJBkvkQJfyo/A2%27s%
> 20Micro/3.5%20Top%20of%20Mast
> > Used some rope, to keep the yard from banging against mast.
> > Post up some pics of your micro....please...
> > A2
> I don't have a photo showing how Peter finished off his mast on
> LESTAT, but he did not drill a hole, but instead installed the block
> with a SS strap and two screws. He also installed a chafing strip the
> same way, only he extended the ends to come back down to the sprit to
> also serve as a topping lift so the sprit could support the awning
> over the cockpit. This block must lie more or less flat and in
> alignment with the top end of the sail track.
> He also installed a hardwood cap to the very top of the mast to
> protect the endgrain from water absorption and attop that is the
> masthead light.
> Peter doesn't do things half way:-)
> Cheers, Nels
masthead light.
Cheers, Nels
> Here's how I did mine..http://f4.grp.yahoofs.com/v1/cKksQUJynMvnRAF46wxYIuVuzfwqzk_o04DMqsHW_
> A2
masthead light.
Cheers, Nels
http://f4.grp.yahoofs.com/v1/cKksQUJynMvnRAF46wxYIuVuzfwqzk_o04DMqsHW_2pog3R5DWSVBS-yBnIdrn23fsVRmGMHaBnbUG5wFdRaHusIoJBkvkQJfyo/A2%27s%20Micro/3.5%20Top%20of%20Mast
A2
A2
--- Inbolger@yahoogroups.com, "epoxy15" <cmccabe@d...> wrote:
> Thanks for everyone's replys. A block with a tail it will be!
I think this is the section that says "masthead block 1 1/16" sheave
diameter slung on a short tail through a hole in the masthead, not a
sheave." I should be so far along. Perhaps I will before too long.
Let us know how it sails. Charles Rouse
> I am finally getting around to finishing a "traditional Micro" andI
> must have misplaced the sheet that explains how the Main sailhaylard
> fits at the top of the mast. Does it go through the mast, is therea
> pulley at the top of the mast, etc.? I have the plan and there is
> a "3" next to the top of the mast but I have no other information.
> The mast is finished but I need to know how to finish the top. Many
> thanks in advance.
> I can't find my key. But i seem to recall a block is up there. Ifno
> one else chimes in by morning i'll dig around for it and give you aYes - It's the block for the main halyard.
> definitive answer
> Jason
I can't find my key. But i seem to recall a block is up there. If no
definitive answer
Jason
definitive answer
Jason
I am finally getting around to finishing a "traditional Micro" and I
must have misplaced the sheet that explains how the Main sail haylard
fits at the top of the mast. Does it go through the mast, is there a
thanks in advance.
thanks in advance.
