[bolger] Re: Epoxy Recoating?
Yes, you need to wash off the blush (soap and 3M scrubber) if you let it
harden between coats. Also, a scratch-sand of 80 grit is a good idea.
Gregg
At 06:58 AM 9/28/1999 -0700, you wrote:
>I have had to go away from our Folding Schooner project for a day. I
>put the second coat on within the recommended recoat time. The bottom
>needs one more coat of epoxy to fill all the weave. Do I need to give
>the bottom a light sanding before recoating the bald spots? If so
>what grit would you use? Do you think it better to skim coat the whole
>bottom or can I just bring up the low spots?
>Another epoxy-non-power user Folding Shoonerite
>Leander
>eGroups.com home:http://www.egroups.com/group/bolger
Leander
