Re: [bolger] Re: mounting my lexan windowsin a navigator?
I in the not to distant past owned a Wharrham Cat---- all the port lights needed replacing--i used lexan-----this is what I was told and did and it seemed to haved worked for two years+. I drilled the lexan every four inches at slow speeds; I use a wood over lay on the outside and a bedding compound they where threw bolted with bolts the same size as the the holes i drilled-----it workvery well-j.e.
dnjost <djost@...> wrote:I did it this way on my Micro, sealed with a good RV sealant and it
looked and worked fine. I would however recommend using the window
gasket that is sold by JC Whitney or any other automotive glass
place. Simply cut the window the size of the hole, place the gasket
around the frame, and then push the locking strip in place. It
really will hold up and is easily replaced if you scratch, dent,
chip, or gouge the stuff.
On my old Catboat, the plexiglass was crazed and this retrofit
worked perfectly.
"gearing up for another season"
worked perfectly.
> Looks like i'll bolt them on from the outside......i'm just toolazy
> to build the frames.Bolger rules!!!
> Jason
Fritz
Are you far enough along that you can see the finish? There will be a
strong contingent from Juneau when you do get to the launching. 2006?
maybe sooner?
maybe sooner?
fritzdfk wrote:
>I have done 16 windows so far on Double Eagle. All are 1/2"
>polycarbonate. I used Sikaflex 295UV sealant, Sikaflex 226 cleaner
>and Sikaflex 209m primer. This is a complete system to bed
>Polycarbonate (Lexan) windows. The windows are mounted on the outside
>of the boat, overlapping about 1.5". There are 1/4" bolts spaced
>about 8" to 10" around the perimeter. The holes are 3/8" in the
>polycarbonate to allow for movement. The primer is painted on the
>boat surface and the polycarbonate and is black which creates a black
>frame around the window. A 1/4" X 1/4" neoprene foam strip is set
>around the perimeter of the opening, this prevents the sealant from
>intruding into the interior. 3/16" nylon spacer washers are set
>around every bolt to maintain the reccommended 3/16" space for
>sealant. Sikaflex said I didn't need the bolts but I feel better with
>them. However, if these windows leak it will probably be around the
>bolt holes. I squirt a little sealant around eack bolt as they are
>tightened. I have put the same polycarbonate in a couple doors and in
>these I didn't use bolts, we'll see.
>The boat is almost completely closed in and I have a diesel range to
>install. I will be working on the interior this winter, floors,
>wiring and plumbing.
>Yahoo! Groups Links
worked perfectly.
worked perfectly.
> Jason
For everyones help on the windows.
Looks like i'll bolt them on from the outside......i'm just too lazy
Jason
Jason
Hi Jason, I have done inside and outside mounted windows.
My opinion is-
Inside-
Looks classier and more substantial
Takes 4 times as long to build
More vulnerable to water penetration, however, using a quality sealer
this does not seem to be a problem (6 years without attention on oval
window in Oink, using german made Seal-Once)
Outside-
Looks a little cheap
Easy to build and maintain
As others say, you need a hole plenty larger than your fixing. I had
a large window (acrylic) crack on my tri because of too small holes,
especially if you are using tinted material which will expand more.
And pan head screws with a washer. I actually used small bolts
because of the thin ply when mounting outside.
Let's face it, a micro is a pretty basic boat, and probably outside
windows are appropriate. Unless she is a lifelong project,the way I
would go if doing it again,
DonB
My opinion is-
Inside-
Outside-
DonB
> Started making some cardboard templates for my windows this evening.house
> Now i'm debating if i want to mount the Windows flush to the pilot
> house cutouts with some framing around the interior rim(more work)
> or to make them slightly oversized and mount them right on the
> exterior.bigger
> Any idea which would look better.My window cut outs are a bit
> than bolger drew so the side windows would be real close to the
> shear line.
> Thanks,
> jason
On my Sneakeasy I used plain exterior clear silicon
caulk/adhesive from Ace hardware with no screws on the front
windshield. I did use screws on the side windows only because
of minimal mounting space. At 75 MPH on the interstate the
windows all stayed in place with no worries. On the trip to
Lake Powell I did have a tarp over the windshield to protect it
from rock chips but it still pressed against the 1/8"
plexiglass. When I got back I decided to make the windshield a
fold down affair and disassembled the side panels. I had to
break the plexi to get it off so I'm convinced that the
adhesive alone does a good job. At least on the 1/8" stuff it
seems stronger than the plexi itself.
So far I've trailer the Sneakeasy about 1200 miles without the
windshields coming off. I would think on the navigator good
adhesive and minimal screws would work just fine. No counter
sunk though because the screw heads won't let the plastic move
with the heat and cooling of the day and will eventually crack.
> Lexan can probably tolerate it, but, in general, countersunk------~->
> fasteners are a NO-NO for plastic. I'd use a pan head with
> a fender washer and a more than slightly oversized hole.
> Also, again, 3M 5200 is for PERMANENT mounting. Lots of
> other goops out there that permit disassembly later.
> Roger
>derbyrm@...
>http://derbyrm.mystarband.net/default.htm
> From: "seagulloutb" <dickburnham1@...>
>> Almost ready to do what you're writing about. So I've done
>> the
>> reading, just not the doing. Here's the stuff I've read
>> (mostly Reuel Parker): 1) Always mount the lexan outboard
>> because of
>> security against a wall of water sort of thing, 2) make a
>> bunch of small holes to take whatever fastener you have in
>> mind -- holes to be slightly oversized to allow the lexan
>> to expand/contract without cracking at the hole(s). For me
>> this will be a series of small
>> countersunk holes since I'll be using s/s screws. (I'm
>> thinking of a thin, shaped wood frame to cover the
>> lexan/trunk joint on my
>> Chebacco. 3) Bed the bearing surfaces of the lexan in 3M
>> 5200 since this goop cleans up with mineral spirits.
> --------------------~--> $9.95 domain names from Yahoo!.
> Register anything.
>http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/_0TolB/TM
> horses - stay on topic, stay on thread, punctuate, no 'Ed,
> thanks, Fred' posts - Pls add your comments at the TOP,
> SIGN your posts, and snip away - Plans: Mr. Philip C.
> 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com
> - Open discussion:
>bolger_coffee_lounge-subscribe@yahoogroups.comYahoo!
> Groups Links
Lexan can probably tolerate it, but, in general, countersunk fasteners are a
NO-NO for plastic. I'd use a pan head with a fender washer and a more than
Also, again, 3M 5200 is for PERMANENT mounting. Lots of other goops out
> Almost ready to do what you're writing about. So I've done the
> reading, just not the doing. Here's the stuff I've read (mostly
> Reuel Parker): 1) Always mount the lexan outboard because of
> security against a wall of water sort of thing, 2) make a bunch of
> small holes to take whatever fastener you have in mind -- holes to be
> slightly oversized to allow the lexan to expand/contract without
> cracking at the hole(s). For me this will be a series of small
> countersunk holes since I'll be using s/s screws. (I'm thinking of a
> thin, shaped wood frame to cover the lexan/trunk joint on my
> Chebacco. 3) Bed the bearing surfaces of the lexan in 3M 5200 since
Hi JASON,
Dick B
Dick B
> exterior.bigger
> shear line.
> Thanks,
> jason
or to make them slightly oversized and mount them right on the house
exterior.
Any idea which would look better.My window cut outs are a bit bigger
shear line.
jason
exterior.
shear line.
jason
