Re: [bolger] micro rudder post.......last question i promise.
If you cut the hole in the bottom of the boat oval shaped,
you can thread the rudder post in at an angle, without
lifting the boat at all. I then screwed on another piece
plywood, and two "C" shaped UHMW pieces acting
as a sort of impromtu bearings.
> Jason
> Micro builders, have you been hanging your keel and the sliding the
> rudder post into position after words or are you jacking your boat
> up 4 foot of the ground and doing it all at once?
I'm leaning towards option one.
Jason
Jason
