Re: 59 square foot sail ?
--- Inbolger@yahoogroups.com, "sctree" <sctree@y...> wrote:
Jim Michalak originally designed Piccup Pram for the 59 sq ft leg o'
mutton sail that Bolger likes...then he changed it to a balanced lug
rig. The COE stays the same with either sail....2' 11" aft of the
mast.
I've tried both and they work well. Currently I have a standing lug
sail on my Piccup as I think it's more weatherly.
You can just go look at Michalak's articles to get the Piccup sails
measurements.
Reed
>sail
> Is there a lugsail version that would replace the 59 square foot
> Bolger uses on Junebug, Teal, Surf, Cartopper etc.?Rick,
> Thanks.
> Rick
mast.
measurements.
Reed
> He also has a lug rig for FASTBRICK?Fastbrick has a balanced lug rig, offcenter mast.
> Nels
My scan is fuzzy, but I think it has about 45SF
of sail area.
The mast of a balanced lug rig is aft of the mast
for a gaff lug rig, so might be more suited for
retrofit on a Teal, IOW it might fit in the same
mast step.
>a 60 gaff rig for Brick, published yearsHe also has a lug rig for FASTBRICK?
> ago in the excellent magazine, Messing About in Boats.
> This idea could probably be adapted to Teal
>http://hallman.org/bolger/brick/gaff/
> Is there a lugsail version that would replace the 59 square foot sailBolger designed a 60 gaff rig for Brick, published years
> Rick
Be aware that the leeboard and the mast would need
to be relocated.
Jim M. has several articles on "Sail Area Math" that discuss this
exact question. Believe me, the math is not that hard - grade 6 level
at best.
Alternatively you could just look at some of Jim's plans. He uses a
lot of balanced lug rigs and posts the area on the plans. I know
there are several boats that use sails in that size range. IIRC
Pickup Pram.
Bryant
at best.
Pickup Pram.
Bryant
--- Inbolger@yahoogroups.com, craig o'donnell <dadadata@f...> wrote:
> >That's exactly what I was thinking... I'm sorta hoping that
someone has
> >already "done the math" and figured out a drop in replacement
lug rig
> >for the 59 sqft spritboomed rig. I want to build a Teal next week,
> >actually two of them, and would really like lug sails...
> Tom Colvin has said the trick with Chinese lugs is to ignore the
portion in
> front of the mast when working out where the center of effort falls.
> So. Draw up a scale sized sail, cut it out, move it around until
the COE
> lines up on the xeroxed plan.
> With the COE in about the right place you can vary the angle of the
yard
> and the placement of the halyard some to fine tune if there is
excessive
> weather helm.
> It's an amusing way to spend an hour or two.
> Jim Michalak put a lug on his Birdwatcher. Same idea -- perhaps he
has a
> essay describing how he did it on his web site.
>http://www.apci.net/~michalakor follow the link to his Way-Back
archives.
> Craig O'Donnell
> Sinepuxent Ancestors & Boats
> <http://freepages.genealogy.rootsweb.com/~fassitt/>
> The Proa FAQ <http://boat-links.com/proafaq.html>
> The Cheap Pages <http://www.friend.ly.net/~dadadata/>
> Sailing Canoes, Polytarp Sails, Bamboo, Chinese
Junks,
> American Proas, the Bolger Boat Honor Roll,
> Plywood Boats, Bamboo Rafts, &c.
> _________________________________
> -- Professor of Boatology -- Junkomologist
> -- Macintosh kinda guy
> Friend of Wanda the Wonder Cat, 1991-1997.
>That's exactly what I was thinking... I'm sorta hoping that someone hasTom Colvin has said the trick with Chinese lugs is to ignore the portion in
>already "done the math" and figured out a drop in replacement lug rig
So. Draw up a scale sized sail, cut it out, move it around until the COE
With the COE in about the right place you can vary the angle of the yard
and the placement of the halyard some to fine tune if there is excessive
weather helm.
Jim Michalak put a lug on his Birdwatcher. Same idea -- perhaps he has a
http://www.apci.net/~michalakor follow the link to his Way-Back archives.
Craig O'Donnell
Jeb,
That's exactly what I was thinking... I'm sorta hoping that someone has already "done the math" and figured out a drop in replacement lug rig for the 59 sqft spritboomed rig. I want to build a Teal next week, actually two of them, and would really like lug sails...
Hey, have fun sorting out that mizzen sail.... Looking forward to your pics and report.
Rick
Jack&Lois <jalo@...> wrote:
I'm
convinced a miniature wind sprint lug (say 65-70 sq. ft.) would work on jb.
She'd plane like a surf board and she'd be reefable.
jeb
Rick
I'm
jeb
Thanks.
Rick
A couple of years ago I came across a net article about double dipping lug
experiments with a June Bug. Struck me as odd at the time but it appeared to
work ok. I had some success with a 72 sq. ft. Tyvek sprit sail with sprit
boom (like the rig used on melon seeds shown in latest Wooden Boat) on my
gypsy. Worked very well until the head grommet got blown out in a gust. I'm
jeb
Thanks.
Rick
jeb
Hi Rick,
That is just what I did with my Teals. I rigged them as standing
luggers as follows:
foot 8', luff 7', leech 12' hollow no battens, head 7'8" laced on
8'x1.5" round yard, throat to clew 10'3".
The mast is 11'x1.75" round, no taper. I have no boom but it is easy
to just put one or a sprit boom if you want a better shape control.
The sail is slightly bigger at 65 sqft but a sail can always be
reduced in size, not expanded.
Hope I answer your question.
Cheers
Thierry, Lunenburg, Nova Scotia
luggers as follows:
Cheers
> Is there a lugsail version that would replace the 59 square footsail
> Thanks.
> Rick
Thanks.
Rick
Thanks.
Rick
