[bolger] Re: Question on circular blades
sorry..... try this and see if it works...
http://www.amazon.com/exec/obidos/tg/stores/browse/-/hi/282134/102-6828109-5
720819
Chris Flynn Flynn'Folly
_/)
To: <bolger@...>
Sent: Monday, March 27, 2000 7:43 PM
Subject: [bolger] Re: Question on circular blades
> hey Pippo.... ...in a planner or combination blade look for 35-45
> eeth( combination) to 40-60(smooth)teeth the best thing that you can
look
> for is a carbide tip blade ... on for a circular saw is not that
> expensive... try to find a thin kerf one if possible ( Dave Carnell has
one
> I am told ) Makita also makes a great 71/2 in ( I don't know about metric
> HA!)thin kerf blade... here is the Amazon site with saw blades on it
http://www.amazon.com/exec/obidos/tg/stores/detail/accessories/-/pro-tools/B
> 0000223IS/102-6828109-5720819 Hope this helps....
> Chris Flynn "Flynn's Folly
> _/)
> From: Giuseppe 'Pippo' Bianco <pippobianco@...>
> To: <bolger@...>
> Sent: Monday, March 27, 2000 6:18 PM
> Subject: [bolger] Question on circular blades
> > Dear all - it seems to me that my circular saw blade produces too much
> > sawdust. Is makes a quite wide cut (about 3mm, or 1/8"), and sometimes
> > I have to wrestle against the saw to make it going straight (even with
> > the rip fence on) or stay down on the stock. It's a bit rough: 12
> > teeths only. Now, reading Dynamite Payson's notes, I noticed that he
> > suggests either a planer blade and a combination rip blade. What is
> > this stuff? How many teeth should I look for on a new blade? I use my
> > saw for almost anything, like ripping timbers (maximum thickness 62
> > mm), cutting plywood, making bevels, etc.
> > Thanks, and best
> > Pippo, at 1:10 p.m., still feeling the smell of mahogany sawdust,
> > celebrating his first boatbuilding cut on his right ring finger
> > GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 2.9%
> > Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
> >http://click.egroups.com/1/936/6/_/3457/_/954199137/
> > eGroups.com Home:http://www.egroups.com/group/bolger/
> >http://www.egroups.com- Simplifying group communications
> as low as 0.0% Intro APR and no hidden fees.
> Apply NOW!
>http://click.egroups.com/1/975/6/_/3457/_/954204301/
eeth( combination) to 40-60(smooth)teeth the best thing that you can look
expensive... try to find a thin kerf one if possible ( Dave Carnell has one
_/)
To: <bolger@...>
> Thanks, and best
Sounds like it's dull to me. Are you sure that's not the problem?
"giuseppe 'pippo' bianco" <pippobianc-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=3972
> the rip fence on) or stay down on the stock. snip
Lincoln Ross
taking a break at work and too sore to build at home, tho weather is
now epoxy friendly
Thanks, and best
