Re: Rustproofing bolts
> What's the best way to rustproofBruce would probably tell you to use Rust Check, were he not in the
> those newly cut ends? Epoxy? Rustoleum primer and paint? Any cheap
> elegant solutions?
middle of his fall rustproofing blitz.
Susan Davis <futabachan@...>
Maybe not cheap but, I feel, more elegant, would be to get some 3/8"
s/s rod, cut it to the right length and have a thread cut on each
end. One day you might need to remove that bolt and this way you have
two chances of having a thread that still works.
Or simpler, get some rod, drill a hole near each end and hold the
assembly in place with a washer and pin (or wire) at each end. No
real need for a thread.
Howard
Howard
--- Inbolger@yahoogroups.com, "GarthAB" <garth@b...> wrote:
> I have several 3/8" bolts through the tabernacle for Cormorant --
> bolts holding it to the bulkhead, bolts holding the transverse
pieces
> where the mast pivots, etc. I used galvanized bolts, but in most
cases
> they're an inch+ too long.
Garth-
Am idea, put a cap nut on the end and epoxy as the rouned end of the cap nut will keep people from getting as mean a cut as a bare end.--j. fitch
bolts holding it to the bulkhead, bolts holding the transverse pieces
where the mast pivots, etc. I used galvanized bolts, but in most cases
they're an inch+ too long. 6" bolts were too short, so I had to use 8"
-- now I'd like to cut off the extra length to prevent someone getting
a hole poked in their skull someday. What's the best way to rustproof
elegant solutions?
Thanks for any advice.
All best,
Garth
(nearing the end of my epoxy season here in the Catskills -- but I'll
keep busy over the winter doing interior sanding, wiring, trailer
welding, pintle & gudgeoning, foil-shaping, birdsmouth mast gluing in
a friend's shop, etc. . . .)
elegant solutions?
All best,
Garth
> Epoxy? Rustoleum primer and paint?I have tried both [plus, I have tried zinc rich paint],
> Garth
and personally feel that epoxy works best.
Garth, I have had good look letting a skim of rust
form, painting that with one of the "rust reformer"
products, and then painting over with some "cold
galvanize" zinc. Sam
--- GarthAB <garth@...> wrote:
Do you Yahoo!?
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
>_______________________________
> Cormorant --
> transverse pieces
> but in most cases
> so I had to use 8"
> way to rustproof
> paint? Any cheap
> elegant solutions?
> All best,
> Garth
> wiring, trailer
Do you Yahoo!?
elegant solutions?
All best,
Garth
elegant solutions?
All best,
Garth
