[bolger] Re: More on small boats
GHC wrote:
I don't know about reverse, but, for planing, the rocker aft should be less
than about 3% or 4% according to Dave Gerr (ref "Propeller Handbook" or
"Nature of Boats"). I think the Brick would have quite a bit more than
that, and, according to experience, does not want to plane. Not to say it
doesn't move along with a little kicker.
So, if you wanted to plane under power, you need to get the aft end
pretty
flat and level, changing the boat quite a bit. If you want to
plane under
sail, well, that's another matter ;-}
Gregg Carlson
At 08:57 AM 3/29/2000 EST, you wrote:
>Bolger says in the Brick write-up, in BWAOM, that the rocker built
in to the
>aft of Brick could be reduced. He seems to say its only justification
is to
>be able to motor the boat in reverse. If you don't plan to motor in
reverse,
>is it advisable to reduce the rocker?
GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 2.9%
Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
http://click.egroups.com/1/936/6/_/3457/_/954346964/
-- Create a poll/survey for your group!
--http://www.egroups.com/vote?listname=bolger&m=1
So, if you wanted to plane under power, you need to get the aft end pretty
flat and level, changing the boat quite a bit. If you want to plane under
Gregg Carlson
>Bolger says in the Brick write-up, in BWAOM, that the rocker built in to the
>aft of Brick could be reduced. He seems to say its only justification is to
>be able to motor the boat in reverse. If you don't plan to motor in reverse,
<< Bolgerbuilders,
Been thinking about really small boats like Brick and Nymph and Tortoise. I
have a few questions:
- What are the drawbacks to, say, an 8' sailboat other than passenger
carrying capacity?
- I think Greg says the Brick is really very functional or even performs
amazingly well, something like that. What does that mean?
- Some of these boats have the longwise thwart. Does that work for sailing as
well as rowing?
- Any ideas on best rig for a really small boat? Does Bolger have a two part
mast design that could be applied to these boats?
Mike Masten
