Re: Small Engine stuffing box?
In SE Asia they are usually known as long tail boats. You will find
several pictures by searching Google Images on ("long tail" boat),
without the brackets.
Howard
> Sounds like a Go Devil. You can check out
>http://www.go-devil.com/
> The name is actually generic, you can google "go devil" and find
lots of
> references. They are common world wide. If I am not mistaken one of
> James Bond movies had a V8 one in Thailand. It is something to see
> somebody balancing a V-8 on a stick.
The name is actually generic, you can google "go devil" and find lots of
references. They are common world wide. If I am not mistaken one of the
J. R. Sloan wrote:
>>Hey Guys,
>>Years ago I remember someone had a kit or what amounted to a kit
>to use a regular side shaft Briggs & Stratton gas engine to power a
> small skiff or jon boat. So... has anyone seen such an animal
> lately? Got any ideas? Have you dreamed any schemes like this?
>Remember any old popular mechanix that had one of these babies?
>>Thanx, Johann
>JR: there was an article in Woodenboat Magazine in the last year or
>so, describing such a device used in a Louisiana (or other Gulf
>State) pirogue-or-jonboat. Basically, this was a longish shaft
>mounted on a 1"x8"x(maybe)6', so that it was parallel to the shaft
>of a small B&S one-lunger, also mounted to the board. It propelled
>the boat by turning the prop on the shaft using a little belt and a
>centrifugal clutch, I believe, though that fancy a clutch wouldn't
>be essential (it could be direct drive or an idler pulley to tighten
>a loose belt).
>The unique feature was that the boat was sort of "half-a-boat", with
>the front half partitioned off from the back,so the transom was
>actually midships and the sides of the boat extended back an
>additional 4' or so to where you would expect a transom to appear.
>This board with motor simply mounted on a pivot and hung out the
>back where the transom would normally be.
>This thing worked by starting the motor, engaging the shaft, then
>lifting the motor so that the shaft (and attached prop) lowered into
>the water. Forward motion flushed out the aft section enough to
>keep her afloat while moving. If I were doing it, I would put
>flotation chambers on both sides of the mounts for the board in the
>rear section, but the model didn't have them. A very simple smooth-
>water solution to the issue you bring up.
>Incidentally, there used to be a whole class of boats in the upper
>midwest that used a similar mode of motor-powered propulsion. In
>these, the motor was stationary, and the shaft was lifted up into
>the hull somehow. I never saw one, but understand there might be a
>restorer's club around somewhere.
>Using Bolger techniques, a wooden box with a long moveable shaft
>inside could be installed to the interior or aft of a lot of boats.
>Maybe like those SE Asia boats one could see (remember that old
>James Bond Movie?) where they balanced a long shaft mounted directly
>to an auto engine on the broad-beam transoms of water taxiis.
>Best Regards,
>JR Sloan
>Yahoo! Groups Links
The boat was a Chalon. See WB 171.
As for the stationary engine, shaft moving craft, you might want to
check out Dispro (Disappearing Propellor)boats. The company changed
hands and locations several times. Most built in Southern Ontario and
Tonawanda NY. Sold and resold all used over the world including South
America and Africa. Since these are a popular, restorable "classic"
there are any number of them restored to date and there are sources
for old stock and newly manufactured parts. IIRC it's possible to get
most of the parts for the drive assembly. Of course, being cheap, I'd
do some "googling" and work out how to build my own.
Bryant
> > Hey Guys,
> > Thanx, Johann
tighten
> a loose belt).
with
into
boats.
directly
> Best Regards,
> JR Sloan
> Hey Guys,
> Thanx, Johann
a loose belt).
Best Regards,
JR Sloan
Small transmission from a riding lawnmower or simular?
>Hey Guys,
> Years ago I remember someone had a kit or what amounted to a kit to
>lately? I can find parts to do a 4-cylinder engine but really nothing
>less than that and that's with a transmission and the whole nine
>yards.
>Got any ideas? Do you know of any parts warehouses for lighter
>engines? Have you dreamed any schemes like this? Remember any old
>Thanx, Johann
>Yahoo! Groups Links
Hi Johann,
Athttp://www.glenwoodmarine.net/Catalog.htm
... you will see a catalogue of marine hardware. The company can
supply stuffing boxes for shafts down to 1" dia.
You might get answers to your various questions at:
http://www.oldmarineengine.com/cgi-bin/discus/discus.cgi
This is an old marine engines discussion board.
Best of luck,
Howard
Hey Guys,
yards.
Thanx, Johann
