Re: a couple of chebacco questions
I used Richard's variation of the Michalak "Boat Baloney" theory to
calculate the weight of mine.
1) Home built boats cost $2 a pound.
2) I spent about $3500 on Schroedinger.
3) Hence, she weighs about 1750lb.
--- Inbolger@yahoogroups.com, "Howard Stephenson"
<stephensonhw@a...> wrote:
> So my guesstimate for towing weight is 1340 lb., plus the trailer
> course.
> Once you've got the plans, the other way to find the weight (hull,
> empty, towing, total or whatever) is by estimation.
> Start by estimating the volume of ply required, then calculate its
> weight from that number and the density of the kind of ply you are
> going to use. Add about 25% for paint, filler, fasteners, glue,
resin
> and 'glass. Or estimate these values separately and add them. For
> example, a complete paint system is at least 5 mil thick, with a
s.g.
> of about 2. Maybe estimate it at 10 mil to include filler. If you
are
> going to sheathe it, you can estimate the weight of glass easily
> enough, then about double it to allow for the weight of resin. You
> can make similar estimates for the volume and weight of fillets.
> Then just keep on adding estimated weights. I mentioned some of
> items before. Others include windows, hardware, navigation gear,
> wiring, battery, nav. lights, pumps and so on. Some marine
catalogs
> show shipping weights of the items they are selling.
> It's just tedious work with a calculator or spreadsheet, but a lot
> quicker than the actual building.
> Howard
> --- Inbolger@yahoogroups.com, "phlmynrd" <phil@p...> wrote:
> > I was curious about actual empty hull weight and towing weight,
not
> > the displacement.
P.S. I was thinking there was practically no framing timber, but I
suppose there are items like the sheer clamp, stem and maybe framing
for seats etc. So estimate and add these too,
Howard
of course.
So my guesstimate for towing weight is 1340 lb., plus the trailer of
course.
going to use. Add about 25% for paint, filler, fasteners, glue, resin
example, a complete paint system is at least 5 mil thick, with a s.g.
of about 2. Maybe estimate it at 10 mil to include filler. If you are
Then just keep on adding estimated weights. I mentioned some of the
wiring, battery, nav. lights, pumps and so on. Some marine catalogs
Howard
> I was curious about actual empty hull weight and towing weight, not
> the displacement.
the displacement.
--- Inbolger@yahoogroups.com, "Howard Stephenson" <stephensonhw@a...>
> Design displacement of the 20' version is 1740 lb. From that, I
> suppose you could subtract the weight of, say, 2 people plus their
> personal gear at maybe 200 lb each. This would be pretty close to the
> towing weight. Then, depending on what you meant by "empty", you
> could subtract stores, water, cooking utensils, boat gear, ground
> tackle, outboard motor, spars, sails, centreboard and so on. Maybe
> 500 lb is something like the weight of the finished hull.
> Howard
> > > Hi, My name is Phil Maynard, I'm a new member, I have built 3
> boats
> > by
> > > now and I've been looking at the chebacco for a while and I just
> > > ordered the plans from Payson. I still need a place to build it,
> the
> > > boat shed , err, garage is kind of full, but in the meantime...
> > > I noticed in Bolger's boats with an open mind he describes the 25'
> > > clinker version as planning cleanly on low revs with a 15 hp
> motor.
> > I
> > > assume the 20' boat will not plane? I noticed Johanna did not go
> > > faster than 8 kts with a 20 hp honda at full throttle. I did not
> > > notice it at first but the 25' boat has a full width cuddy roof
> with
> > > no side decks to get more inside room, has anyone done any minor
> > cuddy
> > > changes aside from Johanna? I'm curious to maybe enlarge the
> cuddy
> > but
> > > am wary to change it to much so as not to increase windage. What
> are
> > > builders getting for empty weights? Bolger mentions a 500 lb
> > figure. I
> > > do not recall any other mention in the newsletters of empty
> weight.
hmmm, it seems to chop my email address.
phil@...
> Hi Paul,
> Thanks so much for reply. I find your story very interesting as did
> others and would also love to hear the rest of it. I found the photo
> in Roymayne section. I was surprised you were able to enlarge the
> cabin as much as you did to make it possible to live on. I would much
> appreciate the interior shot's, my email is phil@p...
> I did not think the 20 foot would plane, I was surprised the 25 would
> plane and I was just trying to see what others experience was. I would
> probably go with a 5hp to keep the weight down.
> Phil
> --- Inbolger@yahoogroups.com, "paulthober" <paulthober@y...> wrote:
> > Hi Phil,
> > I attempted to reply to you directly, but for some reason was unable
> > to do so I will post my reply here, asking for forgiveness and
> > forbearance from the group for the excessive length of this post.
> > Paul
> > "Hi Phil,
> > A couple of years ago I built a Chebacco from plans purchased from Mr.
> > Payson. I also wanted a larger cabin as I planned to live aboard.
> > (which I did for about a year) Below is an article I wrote for
> > Chebacco.com which I was unable to locate in the archives of that
> > site. Reading this with a bit of consultation to the plans should make
> > what I did clear - if not, email me and I will attempt to elucidate
> > further.
> > I don't think this boat will plane without a lot of excess power. I
> > had a 6 hp Tohatsu on mine and around 5 knots was the practical limit.
> > This was about half throttle - more power just made more noise.
> > Here is a link to a picture of her:
http://photos.groups.yahoo.com/group/bolger/vwp?.dir=/Romayne&.src=gr&.dnm=Cruising+Chebacco.jpg&.view=t&.done=http%3a//photos.groups.yahoo.com/group/bolger/lst%3f%26.dir=/Romayne%26.src=gr%26.view=t
> > If it this doesn't work, go to the Bolger group, look under "Photos"
> > for the "Romayne" folder. I also have several other photos showing the
> > interior that I could send to you if you reply with your email
address.
> > This boat is quite easy to build and a true pleasure to sail - I wish
> > you the best of luck with her.
> > Paul Thober
> > Samantha
> > In January of 2002 I moved to Portland, ME where I anticipated
> > starting a new chapter in my life. A new job opportunity turned sour
> > just weeks after I arrived. The same day I was fired I was offered
> > another job that I accepted with a starting date in about ten days. I
> > went skiing, relaxed and regrouped; thanking my lucky stars that fate
> > had smiled on me once again. A couple of days later I came home and
> > found a message on my phone from my new employer saying that he had
> > decided not to hire me after all - lucky stars, my ass.
> > So there I was: unemployed, more than a little bit in shock and not in
> > any state of mind to go out looking for another job. What to do?
> > Driving north up the coast one day with my friend Susan, I talked
> > about my long-held dream of building a boat, the Gypsy plans that I
> > had bought many years earlier and had always found some excuse not to
> > build. Now is the time, Susan suggested, I had the time and a bit of
> > money that cried to be spent. It was like a revelation. The decision
> > was made.
> > Within a few days I had rented some "indoor" space at a local boatyard
> > and had started building myself a Gypsy. Little more than a month
> > later I was out sailing on Casco Bay. Then I started thinking about
> > another boat – something a bit larger that I could actually cruise in
> > with a modicum of comfort.
> > I wanted a boat that was small, handy, affordable, and reasonably
> > easy to build, A catboat was what seemed best to me - the most room
> > for a short boat, shallow draft, simple rig and seaworthy. I bought
> > plans for one of Witholtz's catboats from Woodenboat, but was
> > intimidated by the complexity of the construction and returned them.
> > My next choice was Bolger's Chebacco – which I felt confident I could
> > build, as it is the same type of construction as the Gypsy. I ordered
> > the plans and sails from H. H. Payson.
> > The Chebacco did not exactly fit my concept of what I needed -
> > particularly I thought the cabin far too small for cruising comfort.
> > In my opinion the standard Chebacco is really a day sailor that can be
> > used for camp cruising. My solution was to lengthen and widen the
> > cabin and to raise the cabin roof. I also raised the sheer by 4". I
> > eliminated the centerboard in favor of the keel shown on the cruising
> > version of the Chebacco in "Boats With an Open Mind".
> > Samantha is built entirely of common building materials: ACX plywood,
> > spruce and fir. All of the wood and plywood were selected after much
> > shuffling through the stacks - I would estimate that I rejected over
> > 90% of what I looked at. For the plywood I looked for a good C side
> > and for the least amount and smallest voids. For the solid wood I
> > looked for good straight grain and minimum knots. I mostly bought 2
> > X12's and 2 X 10's and then ripped them to the desired dimension. This
> > is quite easily done with a circular saw with a ripping guide. The
> > result can be clear, quarter sawn lumber.
> > Where fasteners are used, they are sheet rock screws and ring-shank
> > nails. The fasteners were almost entirely used to hold things in place
> > until the epoxy cured. I used MAS epoxy for all gluing, filleting,
> > fiberglassing and fairing.
> > All the outside surfaces of the hull, cabin and cockpit are sheathed
> > in at least one layer of 6 oz.cloth. All joints have at least two
> > layers of cloth on the outside and a layer of cloth or a 1 x 2
> > stringer on the inside. The stem and keel have four layers of cloth on
> > the outside.
> > I left all the frames/molds/bulkheads in the hull and they are all
> > filleted and glassed in place. There is a 2 x 4 floor screwed and
> > epoxied to each frame and to the bottom panel.
> > The keel is solid and is made from 2 x 12 stock with ½" plywood
> > cheeks. There is 150 lbs. of lead in the keel. The keel is epoxied in
> > place, has 3" screws down through the bottom panel on 3" centers, is
> > generously filleted to the bottom and the fillets are glassed with
> > three layers of 6 oz. cloth.
> > I used Harken blocks, fairleads and cam cleats throughout. All the
> > running rigging is ½" Dacron 3-strand. All cleats, pad eyes, etc. are
> > stainless. Auxiliary power is provided by a 6 hp Tohatsu 4-stroke
> > outboard that also charges the 80-amp hour lead-acid deep cycle
battery.
> > Electrical equipment includes a VHF radio, navigation lights, a cabin
> > light, a Garmin Etrex GPS, a Ritchie Navigator compass, a Sony Walkman
> > CD player, and a cell phone.
> > The first construction I did was to build a strongback. I used two 20'
> > 2 x 6's spaced 3' apart with the ladder "steps" at the frame
> > positions. I temporarily set this up on legs to use as a surface to
> > build the spars and to scarf the hull panels.
> > The main mast I made of three layers of 1½" scarfed spruce with the
> > scarfs staggered along its length. The mizzenmast, gaff and main boom
> > I made of two layers of spruce. I shaped them with a circular saw,
> > power plane and a belt sander.
> > I cut the scarfs for the plywood with the power plane and belt sander.
> > I glued the scarfs in the following way: first a 4' 2 x 6, then a
> > piece of plastic sheeting, then the plywood sheets, another sheet of
> > plastic, then a 4' x 6" piece of ½" plywood. I then clamped this all
> > together with two rows of sheetrock screws on four inch centers. The
> > scarfs are reinforced on both sides with a 1' wide piece of 6 oz.
> > Fiberglass.
> > I laminated the stem pieces of ½" plywood and shaped them with the
> > power plane and belt sander. I cut out the frames making numbers 1, 2,
> > 3, 4, and 5 taller than they needed to be because I was still not
> > quite sure how high to make the cabin roof - I wanted to get the hull
> > turned over, mock up the seats and actually see where the top of my
> > head would be. I set up the frames and inner stem on the ladder, cut
> > the hull panels and assembled the hull - all quite straightforward
> > except the forward section of the bilge panels. These I laminated of
> > two layers of ¼" plywood as is recommended. This is good advice as its
> > still a formidable challenge to coax these into the correct shape.
> > This was the most difficult part of the construction of the boat. I
> > glued the two layers together with epoxy thickened with wood flour and
> > pulled the panels together with sheetrock screws on 3" centers. After
> > the glue cured, I removed the screws and filled the holes. I backed
> > the joint where the laminated section meets the ½" bilge panel with a
> > 6" wide piece of ½" plywood.
> > I faired the hull, struck the waterline using a T-square, and applied
> > the bottom paint. Ten friends helped me turn it over which made the
> > job quick and simple.
> > I framed in the settees between frames 4 and 5. They are 14" high and
> > there is a 28" wide foot well between them. Forward of and level with
> > the seats is a V-berth. All the volume beneath the seats and berth is
> > storage bins accessible through hatches cut from the top surfaces.
> > To provide clearance for my head while sitting I made the cabin roof
> > 39" above the aft end of the settees. (I'm 6' 5" tall.) The forward
> > end of the cabin roof is 4" above the deck.
> > The cabin roof has the designed curvature and is ½" plywood. Frames 2,
> > 3, and 4 are left in place with a depth of 3 inches at the sides and
> > roof. These frames are solid beneath the seats and berth. The
> > companionway hatch is 36" wide and extends from frame 4 to frame 5 -
> > the sides of the opening are above the 90-degree waterline. I also put
> > a small hatch, 1' foot square, in the cabin roof between frames 1 and
> > 2 for ventilation. Both hatches have double coamings.
> > The interior showing frames 3 and 4
> > The cockpit seats are deck level and the foot well of the cockpit is
> > 14" deep. The cockpit coaming is 9" high.
> > I made the cabin windows from ¼" polycarbonate - two 6" x 12"
> > elliptical windows between frames 2 and 3 and two 10" x 30"
> > rectangular windows between frames 4 and 5, behind the seats. These
> > are bedded in silicone on the outside surface of the cabin sides and
> > screwed on 4-inch centers.
> > I installed the rudder, glassed and painted the boat and then it was
> > time to launch - and none to soon as it was two days before I had to
> > out of my apartment. So down the ramp and into the water she went. And
> > as one of the men at the yard said, "She floats like a duck."
> > It was the end of August, I was planning to sail south and I still had
> > much to do - I worked feverishly wiring the boat, stepping the masts,
> > rigging the boat, bending on sails, going on trial sails, fixing
> > things that didn't work right, building a dinghy (a Nymph) and then
> > finally on the morning of September 10, 2002 I set sail and reached
> > out of Portland harbor and onto the swells of the Atlantic. It was a
> > fine sunny day with a moderate breeze."
Hi Jamie,
I have looked at the archives maybe 2 years ago and I'm starting to
look again. I live just south of Philadelphia, PA. I did see Ed Hein's
new chebacco at St Michael's but didn't spend much time looking at it
and spoke with I would guess Ed very briefly, but seeing it rekindled
my interest in the design. It was much larger in real life than I
expected.
Phil
--- Inbolger@yahoogroups.com, "Jamie Orr" <jas_orr@y...> wrote:
> Hi Phil
> No,the 20 footer doesn't plane, I don't know of anyone who has
> managed to make it do this.
> I know two builders (Randy Wheating and Chuck Gottfried) who have
> enlarged the cabin. If I remember rightly, both made the cabin sides
> a continuation of the coamings, making the cabin about a foot wider
> and leaving narrow side decks. Both also raised the cabin roof an
> inch or two.
> I don't have it in front of me, but I think Bolger estimated the
> weight, with motor, at 1200 lbs, quite a bit more than 500. I
> haven't weighed mine, but I would guess its a lot closer to the 1200
> figure.
> Have you looked at www.chebacco.com? There's a wealth of information
> there that might help you. Where do you live? You might find
> there's a Chebacco close enough to go and see.
> Good luck,
> Jamie Orr
> > Hi, My name is Phil Maynard, I'm a new member, I have built 3 boats
> by
> > ordered the plans from Payson. I still need a place to build it, the
> > clinker version as planning cleanly on low revs with a 15 hp motor.
> I
> > notice it at first but the 25' boat has a full width cuddy roof with
> cuddy
> > changes aside from Johanna? I'm curious to maybe enlarge the cuddy
> but
> > am wary to change it to much so as not to increase windage. What are
> figure. I
> > do not recall any other mention in the newsletters of empty weight.
> > Phil
Hi Paul,
appreciate the interior shot's, my email isphil@...
Phil
> Hi Phil,
> Paul
> "Hi Phil,
> further.
> interior that I could send to you if you reply with your email address.
> Paul Thober
> Samantha
> was made.
> the outside.
> outboard that also charges the 80-amp hour lead-acid deep cycle battery.
> Fiberglass.
Well worth the read, Paul, both in form and content.
After all you the extra stuff you have built into the boat, I was
surprised to see that she seems to float about as deep as her
designer intended.
Howard
> Hi Phil,
It would be terrific, Paul, if you would have the time to write to us
all about the rest of your Chebacco cruise--from Maine to (was it?)
South Carolina. I'm unaware that anyone has taken a cruise in a
Chebacco of such length and duration. Perhaps you could post in on a
Chebacco Newsletter? I know plenty of folks would really enjoy
reading about it. -- Dick
> Hi Phil,
> Paul
> "Hi Phil,
Mr.
make
> further.
limit.
26.src=gr%26.view=t
address.
wish
> Paul Thober
> Samantha
I
fate
in
> was made.
boatyard
in
could
ordered
be
cruising
plywood,
This
place
on
> the outside.
in
are
battery.
cabin
Walkman
20'
boom
sander.
> Fiberglass.
2,
hull
its
After
applied
with
is
2,
put
And
had
masts,
Hi Phil,
Paul
"Hi Phil,
further.
Paul Thober
Samantha
was made.
the outside.
Fiberglass.
Howard
boats
> by
motor.
> I
with
> cuddy
cuddy
> but
are
> figure. I
weight.
Hi Phil
inch or two.
figure.
Good luck,
Jamie Orr
by
I
cuddy
but
figure. I
> Phil
Hi, My name is Phil Maynard, I'm a new member, I have built 3 boats by
clinker version as planning cleanly on low revs with a 15 hp motor. I
no side decks to get more inside room, has anyone done any minor cuddy
changes aside from Johanna? I'm curious to maybe enlarge the cuddy but
builders getting for empty weights? Bolger mentions a 500 lb figure. I
Phil
