Re: micro scantling question
OK, thanks for the replies. I'll try somewhere other than Staples
today.
PAul
> End on, it looks like a 3-pointed star. Mine is colour coded in
red, blue and white in lengthwise channels between the sides.
> > Dyslexia keeps me from remembering which is the engineer's scale
and which is the architectec's, but if the one you got doesn't have
the 1/8"=1',1/4"=1', 3/8", 1/2", 3/4", 1", 1-1/2", 3", etc (12 in
all) then get the other flavor.
> >http://www.officedepot.com/ddSKU.do?level=SK&id=448561
End on, it looks like a 3-pointed star. Mine is colour coded in red, blue
Sent: Thursday, October 28, 2004 6:28 PM
Subject: Re: [bolger] micro scantling question
> Many.
> Dyslexia keeps me from remembering which is the engineer's scale and which
> is the architectec's, but if the one you got doesn't have the 1/8"=1',
> 1/4"=1', 3/8", 1/2", 3/4", 1", 1-1/2", 3", etc (12 in all) then get the
> other flavor.
> Don't look at plans without one. (Actually, I have several 12" versions,
> but a 6" pocket size is great for armchair use.)
> Roger
>derbyrm@...
>http://derbyrm.mystarband.net/default.htm
> From: "Paul" <kayaker37@...>
>> Someone was kind enough to send me a set of unused micro plans. These
>> were from CSD.
>> I have a question on the fastening frames on the Bulkheads. The
>> thickness is given but not the width. Is this supposed to be scaled
>> off of the plans? The scale is given as 1" = 1'0". I stopped by
>> Staples and couldn't figure out what Architectural ruler was
>> appropriate for this scale. I found a 60 scale which was at least
>> disible by 12, but wasn't sure if this was the correct one. It seems
>> the lines in between the 1/12 lines are divided into 1/5. I would of
>> course prefer these divided in eighths. Are there scaled rulers which
>> give 1" = 1'?
>> I thought my Birdwatcher plans gave the actual measurements. Of
>> course I can't find them now to confirm.
> (978) 282-1349
For feet and inches you need an architect's scale,
they can be pretty cheap, buy more than one.
[If you misplace things, like I do.]
http://www.overcost.com/detail.asp?Product_id=STD9871931
Is one online option, there are a hundred other options.
You bought an engineer's scale, not so useful for your purposes.
Many.
other flavor.
> were from CSD.
> give 1" = 1'?
were from CSD.
give 1" = 1'?
Paul
