Re: Payson & PB & F
Assuming that Payson's book just reproduces the original plan at a
reduced scale, there are no dimensions given on the Gypsy plan that
would show a builder how long the legs should be. Nor is there a
waterline or baseline shown on the drawings of the individual frames.
So maybe this is the exception that proves the rule.
There is a longitutidal section, with the waterline and the frames
drawn in. I realize now this would allow the builder to work out
where to place the frames on a strongback, by measuring and scaling
up. With the original plans scaled at 1-1/2" to the foot, there would
not be much potential for measurement error. I guess a first-time
builder would be better off using Payson's building guide like a
cookbook.
(The plans for Diablo, in the same book, show legs on two of its
three frames. The baseline would be taken as the bottom of the boat,
which is parallel with the waterline).
The first post in this thread was talking about the Bobcat; maybe its
plans show a baseline or waterline on the frame drawings.
So perhaps we can agree to disagree as to whether it would be easier
to mount each frame on braced legs, or mount them all on a
strongback. Both methods require the builder to know how high the
frames should be. The strongback method also requires the builder to
know how far apart they should be, measured along the centreline.
Howard
--- Inbolger@yahoogroups.com, cha62759@t... wrote:
> I've got a pile of plans from Mr Bolger. All of them have a baseline
> and waterline. The waterline or consistent offset is marked on the
> legs or bulkheads as well as the centerline. This is the reference
for
> aligning everything on the strongback. There's more but that's it
> generally. If you use Mr Paysons method and angles as you propose it
> would still be necessary to locate the waterline level.
legs or bulkheads as well as the centerline. This is the reference for
Bob Chamberland
--- Inbolger@yahoogroups.com, "Howard Stephenson" <stephensonhw@a...>
> Yes. Looking at the pictures on p. 43 of Payson's "Build the New
> Instant Boats" I can see the triangular pieces of ply on the legs
> holding two of the frames upright. (The chapter deals with building a
> Gypsy). The same page also shows him inserting frame #9 into the
> assembly. This is where I think extra legs would help. It certainly
> wouldn't be easy for one person to fix that frame in position while
> making sure it was correctly aligned in three dimensions on both
> sides of the hull.
> But I can see a problem with my idea in relation to this design (and
> possibly others where the sides are not vertical): how would you work
> out at what height the frames should be attached to the legs?
> Using a strongback is supposed to be the proper way to build a small
> boat. Every now and then we see a post from someone who finds his s+g
> boat is crooked -- too late, after the resin has hardened. But for
> Gypsy at least, you wouldn't be able to mount all the frames in a
> fixed position on the strongback, as there are no measurements to
> show where along the strongback the frames should be placed. Nor are
> there measurements showing how high the frames should be mounted.
> You are stuck with building it Payson's way or using the standard
> stitch-and-glue technique, which is what I'd do.
> Howard
> > This is essentially the method Mr Payson uses. Legs are attached to
> > the two main bulkheads and are matched to the side panels. The
> problem
> > is that they move around. Attaching the bulkheads/legs assembly to a
> > simple strongback keeps everything in place quite nicely.
sides of the hull.
Howard
problem
the two main bulkheads and are matched to the side panels. The problem
simple strongback keeps everything in place quite nicely. I believe
the frames E and B are about 6' maybe 7' apart. A strong back that
length with 2x6 longitudinals, about as simple as it gets, will hold
everything together. The only caveat is make sure the strongback is
parallel to the water line or base line. If you mark the bootstripe
while the boat is upside down you must have the strongback level. With
my latest project I rented a laser level to mark the bootstripe and
that beat out the usual methods.
Bob Chamberland
> I've built two stitch and glue boats, but right way up, not upside
> down as Payson does it. So the following is an untried idea and will
> only work on a flat level floor.
> Attach two legs to each frame (nails or bolts but no glue). Make each
> one long enough so it will just touch the floor when the frame is in
> its correct position (upside down) ready to receive the ply side
> panels. For each leg, get two large pressed-steel right-angle
> shelving brackets (with arms about a foot long). Use bolts through
> the screw-holes in the brackets to attach them back-to-back on the
> ends of the legs. The frames will then stand upright and can be
> shuffled around to match up with the marks on the plywood side panels.
> Alternatively, you could use pieces of plywood tacked onto the legs.
> Just an idea that might be a useful substitute for that extra pair of
> hands and easier than a proper strongback.
> Howard
> >Although Mr Payson does not use a strongback
> > when assembling the hull I would recommend that the frames shown
> with
> > legs be attached to a simple strongback. It is like having extra
> > hands.
> Howard
> with
> > hands.
Howard
with
> hands.
Yes, but not a lot.
Bob Chamberland
--- Inbolger@yahoogroups.com, "JIm Dix" <jdix6@s...> wrote:
> Ok,snip
> Is there anything in the book that I don't have already?
> Great picture!
> Jim
--Hi Jim, I bought the book and plans from Mr Payson. There were few
questions that were not answered in the book or from studying the plans.
The book is essential, the plans are not but good to have anyway. The
book has more information than the two articles in SMJ. A problem was
finding a source for the specified hardware which is available but not
under the name specified. Although Mr Payson does not use a strongback
when assembling the hull I would recommend that the frames shown with
hands. Nothing was particularly difficult.
Bob Chamberland
> I'm looking to buy a set of plans for the Bob Cat aka Tiny Cat. PB &
> F has plans and so does Payson. Somewhere I read that PB & F won't
> give help if you buy the plans from Payson, (makes sense to me).
> Payson obviously has a lot of helpful stuff besides the plans.
> What's the best way, plans from PB & F, rest from Payson?
> JIm
Ok, I've been wondering about this one too.
I have most of the SBJ issues including the ones with the original
cartoon by Bolger and the two construction articals by Payson, heck,
that's how this all got started!
Great picture!
Jim
> > ... not forgetting there is also a Payson book on building this
> > particular design.
> > Howard
> Yes, of course. The book, I think, is a collection of the two
> articles in the magazine Small Boat Journal, issues 50 & 51
> from Autumn 1986.
> Here is a photo of Dynamite in a Bobcat, from those articles.
>http://hallman.org/bolger/bobcat.jpg
> particular design.
> Howard
from Autumn 1986.
particular design.
Howard
> Of course, read both of the Payson Instant Boat books carefully
> as essentially all your questions are probably already answered
> in those books.
Actually I don't think that is true.
Still, bear in mind that questions about 'errors or ambiguities'
in the drawings should be addressed to the designer.
In the case of all the plans sold by Dynamite Payson, so many
people have looked at them before you, that there is zero chance
you will find any true 'errors or ambiguities'.
Phil Bolger isn't a boat builder, Dynamite Payson *is* a builder.
The most likely questions you will have will be the 'builder'
type of question, and Dynamite Payson is more qualified
to answer those types of questions than Phil Bolger would be.
in those books.
Certainly it would be easier to buy both the plans and the book from
the one source: Payson.
No matter which way you go, you will always have backup from members
of this group.
Howard
--- Inbolger@yahoogroups.com, "Will Samson" <willsamson@y...> wrote:
> Hi Jim,
> I've always found Payson to be helpful (if brief!) with regard to
any queries.
> With a set of plans and his book on building the Tiny Cat I doubt
very much if you'd need to bother PCB&F with queries. The plans are
aimed at amateur construction and shouldn't lead to any snags.
> From: JIm Dix
> To:bolger@yahoogroups.com
> Sent: Thursday, November 11, 2004 1:04 PM
> Subject: [bolger] Payson & PB & F
PB &
won't
Hi Jim,
I've always found Payson to be helpful (if brief!) with regard to any queries.
With a set of plans and his book on building the Tiny Cat I doubt very much if you'd need to bother PCB&F with queries. The plans are aimed at amateur construction and shouldn't lead to any snags.
Bill
JIm
Yahoo! Groups Sponsor
JIm
