[bolger] Re: SV: WDJ supplemental ballast
Bjorn and Steve,
I don't know what
Bolger would have said if he had known I was 285 lbs.. light on ballast; but I
would have been less likely to comment on tenderness and the subject might never
have been discussed. I removed 1 foot, which weighed 5 lbs.. from each of the
masts. I hollowed the gaffs, which lightened each by 6 lbs.. The total
reductions aloft were 22 lbs.. Bolger thinks the weight aloft-ballast ratio on
this boat is 1 to 10 so these operations should have equaled 220 lbs.. of
ballast. Also, I hollowed the booms reducing their weight by 6 1/2 lbs.. each
but I assume their lower position makes this reduction less
significant.
The rig works fine
with the shorter masts. The original sail plan still fits. Peak halyard
tension must have increased; but I do not notice the difference.
Steve, the total
sail area is 462 sq.. ft. and yes I have sailed many times with all sail set.
Most of the time, though, I do not use the main staysail (70 sq.. ft.) since it
must be pulled down and reset for each tack. I don't know what the trailer
weight is; but I do feel I've been overloading my single axle trailer so I am
having a second axle added. I pull this load with a 1/2 ton GMC pickup with a
305 cu. in.
engine. I can climb the steepest mountain passes on the interstate at 40
+ m.p.h.
Bill Jochems
To:bolger@egroups.com<bolger@egroups.com>
Date:Thursday, March 30, 2000 11:23 AM
Subject:[bolger] SV: WDJ supplemental ballastBill, that is very interesting. A started a posting this morning actually questioning if Sapphire ever has sailed ballasted and built as per plan. Your first gaffs were solid and the battery ballast almost non-existant. If Bolger wasn't aware of the lacking lead ballast, would he still have recomended the shortening of the masts? I am about to make the masts and must say I would like to keep the original length if possible. Can anybody calculate the effect of removing 2x2 feet of spruce aloft contra adding 350 lbs of lead in the bilge?Bjorn under the treeeGroups.com Home:http://www.egroups.com/group/bolger
www.egroups.com- Simplifying group communications
Bjorn under the
tree
