Re: Michalak on Bolger
> Could be. Once or twice I've seen on a Bolger plan a notation
> something like "PCB after SA".
In a MAIB writeup, PCB said that he had ended drawing up some
changes invented by SA "as a matter of drafting skill."
Howard
> > But Bolger on CAD may be a bit premature.
> I don't know this for a fact, but I have the strong
> hunch that Susanne Altenberger has used CAD
> to develop some of the more complex shapes.
> Which PCB then hand drafts.
Which PCB then hand drafts. For instance, the
panels for Col. H.G. Hassler appear to be CAD
developed. [I am only guessing.]
Perhaps also some of the step sharpie fillets.
You are right on the button Howard.
But Bolger on CAD may be a bit premature. He hasn't mastered email yet!
(this is tongue in cheek, before I'm flamed)
DonB
--- Inbolger@yahoogroups.com, "Howard Stephenson" <stephensonhw@a...>
> A hand-drawn, hand-lettered plan is a work of art in its own right.
> It's hard to have the same feeling for the output of a CAD system.
> CAD would have aided PCB in producing complex shapes in sheet
> plywood. He has been limited pretty much to using a few simple
> cylinders and cones, whereas CAD frees the designer to work with many
> cylinders and cones on the one sheet of ply. Michalak says pretty
> much the same thing in fewer words.
> Bolger has described his technique for producing his range of bilge-
> panel ply designs (e.g. Diablo):
> -- draw the side and bottom to the exact shape
> -- have them cut out and assembled over a few bulkheads
> -- place a sheet of ply over the gap between side and bottom on one
> side then mark and cut it to shape.
> -- reproduce the shape of the bilge panel on the plan.
> Using CAD would obviate all this. A look at the Selway Fisher website
> will show numerous examples of ply designs that have benefited from
> the use of CAD.
>http://www.selway-fisher.com/
> Howard
> --- Inbolger@yahoogroups.com, "GarthAB" <garth@b...> wrote:
> > Just read Jim Michalak's bi-monthly online newsletter and in an
> > interesting essay on his design process, he throws in a nice Bolger
> > anecdote:
> > Drawing boats is an inexpensive adventure. With one avoidable
> > exception (determining the shapes of twisted and bent panels) I
> > think no computer gear is required.
That was the theory when I first started writing programs in 1959. One of
these days it will be fulfilled.
> Computers are there to help, not control. They are most useful for just
> this..
> 2 way communication ( I study this stuff ;) )
the use of CAD.
Howard
> anecdote:
Computers are there to help, not control. They are most useful for just this..
> anecdote:
> exception (determining the shapes of twisted and bent panels) I think
> no computer gear is required. In fact that gear might get in the way
> and slow you down. And you might find yourself designing projects that
> are limited by the capabilities of your gear. An inexpensive hand
> calculator is almost always sufficient. Drafting tools can be minimal.
> A three foot by four foot sheet of 1/2" plywood is a good drawing
> board although you will have to surface it with a layer of heavy paper
> to negate its grain. I met Phil Bolger about 20 years ago when he was
> still working in his ancestral house. He was quite famous and seeing
> his drawing room was quite a treat. At that time he had a full sized
> sheet of plywood atop a stack of concrete blocks and could make very
> large drawings on it for some of the very large boats he was drawing.
> There was no computer gear and he had no intention of getting any
> although he said the salesmen were hounding him a bit. Ten years later
> he had moved into his boat home and his drawing board was quite small,
> maybe 2 foot square at the most. Perhaps he had a larger board on
> shore somewhere. At any rate I'm sure he is back on shore now in a
> real office complete with big drawing boards and electronics. He still
> does his drawings by hand and I'm sure most of you know that he has a
> true artist's hand and for him to use a cad program to put out final
> drawings would be a crime.
> I like that bit about "a true artist's hand" and for PCB to use CAD
> "would be a crime."
> All best,
> Garth
http://groups.yahoo.com/group/linux-society
SoyOS and eLSD distros; Thinman Model ->http://thinman.no-ip.com/
Distro Readme ->http://thinman.no-ip.com/eLSD/readme
ThinMan is a registered trademark of CXN, Inc
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
anecdote:
"would be a crime."
All best,
Garth
