Re: glass bottom boat
Perhaps this will help:
http://www.pbase.com/dr_dichro/image/8391550
The fellow that did this work also did an article for Duckworks on
glass-bottom viewing stations on boats.
Wayne
Wayne
> > < Stephen Gill wrote:bottom
> > > How do I go about
> > > installing a 12" x 12" glass/plastic veiwing station in the
> > > of a flat bottom skiff that is under construction? What is thebest
> > > material for the "window" and best way to install? Or am I crazy?
A shadowing box, higher than the waterline, removable but well fixed with a rubberseal to the frame prevents flooding the boat if there is a mishap with the glas/plastic. Divide the weight of the boat with gear and human beeings by the area of the waterline, to get an idea what force the glass and frame have to resist.
Dieter
<fountainb@...> schrieb:
Dieter
> > How do I go about
> > installing a 12" x 12" glass/plastic veiwing station in the bottom
> > of a flat bottom skiff that is under construction? What is the best
> I don't see any major problems with this - build a substantial
> frame, bed the glass down in a good bedding goo, make sure it
> is held in well with solid battens around the edge.
> I would use toughened glass rather than plastic - scratching would
> be the major problem here.
> You probably want to build some sort of box around the window
> to keep out the light. Maybe something you can easily remove
> to clean the glass.
> Bruce Fountain
> Systems Engineer
> Union Switch & Signal
> Perth, Western Australia
> Yahoo! Groups Sponsor ADVERTISEMENT
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
to clean the glass.
Bruce Fountain
Systems Engineer
> How do I go aboutI don't see any major problems with this - build a substantial
to clean the glass.
Bruce Fountain
Systems Engineer
Hello,
This may or may not be a new one for this group. How do I go about
Many thank yous in advance!
Best Regards,
Steve Gill
Best Regards,
Steve Gill
