Re: [bolger] Micro plans
Sitka spruce?
John Blake wrote:
>For reference for anyone in Aus.
>I faxed FB&F the other day for a price on Micro plans posted to Aus.
>Got the reply today. $150 USD if anyone needs to know.
>Also have been checking out timber prices/avalability etc in WA, and have
>found clear oregan impossible to find (for spars), and *hugely* expensive.
>Does anyone know of an alternative, something that could be laminated up to
>do the job.
It's a bit fussy, but, when doing the rub rails on Dadink, a dinghy, I used
construction grade spruce (think leftover Christmas tree equivalents).
Terribly full of knots and needing to be bent. I was quite satisfied with
the results of "graving" chunks to replace the places where I cut out the
knots. Epoxy is wonderful stuff for us wood butchers.
For a mast, I'd consider wrapping the repaired places with fiberglass. If
you took a strip cut from normal fabric and went up diagonally at a 45
degree angle, you'd have the equivalent of the expensive stuff.
> to
> do the job.
do the job.
John Blakevk6jrb@...
0429 674296
Using M2, Opera's revolutionary e-mail client:http://www.opera.com/m2/
